Sorry for delay guys, been busy. May be a quiet day at work tomorrow. I'll see if I can get those pistons under the big lit magnifying glass our sparky has on his work bench.
Head was dropped off yesterday, shop says I should have it back by the end of next week. Nissan stuffed me around with replacement piston circlips. Ordered 12 (was showing heaps of stock) but somehow they only had 10. Should get last 2 by next week. I hope anyway.
I mentioned to engine builder that I had 11 pistons and asked if I should aim to run the 6 that came out of the motor that's being rebuilt. Before I could finish my sentence he said he would pick out the best 6 from the pile. So that's what I've been doing.
Out of the 11,  2 where ruled out because of the maybe or maybe not cracks. 1 other was ruled out due to a tight 2nd ring groove (I may or may not have dropped this, lol). Out of the 8 useables, they where weighed and then the 6 closest weights where picked.
Nissan did a damn good job casting RB pistons. They're within 0.7 of a gram. Could have been 0.5 but I didn't like the look out of 1 of the other 8. There was 1 outlier that was over 1.2g heavier The 6 selected range from 404.08g to 404.78.
The piston pins are within 0.24g across the 6.
With some rearranging of the pin locations the total piston/pin weight comes down to  0.46g
Once the rod weights are factored in the variance comes down to 0.2g. if I shave a tiny bit of 2 pistons I can get it down to 0.07g.
I know this will make stuff all difference but I'm here and will take bugger all time to do.
Question time. Should I even bother with rearranging the pin locations or leave them in their original homes? If I don't the variance will be 0.43 with rod weights accounted for. Or do I go all out, shave a few pistons and end up less than 0.05g variance and call it balanced and BILLprinted.
Anyway here are my workings.
Thoughts gents.
  • Like 1
  • Haha 1
On 15/11/2023 at 12:15 PM, No Crust Racing said:
Given the are already so closely matched, do not touch them is my advise or you risk adding stress risers unnecessarily.
That's incredibly close.
Oops, my bad. Lol. I decided to leave the pins in original spots but went ahead and shaved around 0.15g from the 2 heaviest pistons. Going to take 0.10 off one more and call it done. BILLprinted baby.
This is the area I shaved material off from
KangaMotorsportsDatsun240zEngineBuildPistonAssemblyBalancingAreastoRemove.thumb.jpeg.fdffe2a075f36249e9dc0bc72b28e697.jpeg
On 15/11/2023 at 3:45 PM, Duncan said:
original locations, because then you don't need to worry about any sizing differences
As above decided to leave them in original locations.
  • Haha 1
As long as it's smooth and transitions from one plane to the next uniformally it'll be fine, I was removing 5g on some pistons and they've seen 800ks and 7k rpm already.
Doesn't mean they won't explode but who knows when ;)
  • Like 1
Just checked the ring gaps. Thanks Mr Nissan for being spot on and not needing adjustment. OEM is life.
Around mid spec for all. Starting to assemble the pistons now. Got 2 done so far, will continue at next opportunity.
  • Like 1
Geez man, where do you find 5 grams to remove. I only took .2 of a gram and was scared I was taking too much off.
Pic of my work
Shaved
Will clean it up and a bit with some fine paper tomorrow.
Unshaved
Rings are all installed now, will re weigh all pistons tomorrow with rings fitted up. I doubt there's much difference in the ring weights but you never know.
  • Like 2
On 15/11/2023 at 8:52 PM, r32-25t said:
The oil splashing on them will probably create a bigger weight discrepancy then you’re trying to shave off
Most probably true but what's done is done
On 15/11/2023 at 9:03 PM, No Crust Racing said:
You work all 4 sides of the pin boss taking them from square edge to tapered round edge all the way to near the crown.
Risky business lol
Yolo lol
Final numbers are in after ring fitment and arrangement. Variance is down to 0.12g worked out well, may be able to improve a tiny bit more with the arrangement of circlips once they all arrive.
Billprinting almost complete
I've ended up with 3 pistons from each motor. The 3 that came out of this one will go back to their original locations,  the others will be measured up and a spot selected for them.
Opened up the box of goodies from EFI solutions yesterday. Must say they're a well organised mob and everything they said was in stock actually was.
  • Like 3
EFI Solutions is a well oiled eComm powerhouse!
They probably have a proper ERP running, thus have real-time stock display on their eCommerce site. Not many car related businesses can do this, not even Sparesbox (Shitbox really).
  • Like 1
15 minutes ago, admS15 said:
You mean dropshipbox
Yep!
Waited a few months for my turbo, they then couldn't get the turbo, then offered a larger GTX3582R Gen 2, which I then agreed to, but what I received was what I initially ordered lol.
Wrote a bad review on Google, Facebook, etc. they then apologised and offered a free turbine housing 🤣
So yeah that's the story of how I got my Garrett turbo cheap.
Started on assembly on the weekend. I checked the mains clearance with plastigauge.  Was surprised to see bigger clearances with the ACL race bearings.  Was concerned the readings weren't right, so I disassembled and reassembled numerous times, measured with micrometre and bore gauge. The mic readings where close to the plastigauge but slightly tighter. I did the readings 3 times and although they where a tiny bit different each time, they where close enough for me to be confident what I'm seeing is correct.
Clearances on the mains are between 2 - 2.5 thou or .050-.063mm I was initially concerned as that's outside of Nissan's ideal range so I stopped assembling and considered running a -.010" bearing on 1 side in a mixed pair arrangement, sounds dodgy but apparently it's a done thing. You obviously need 2 sets of bearings. I have since been told that my numbers are fine, between 2-2.5 thou is good and I don't need to change anything. The avge across the 7 is around 2.3thou.
The rod bearing clearances where checked with the mic and they're a bit tighter at 1.45-1.77thou or .036-.045mm. Again I'm told that that's good and even a little looser would've been better. Will see what engine shop has to say about these clearances when I pick the head up.
Atm, the crank is in and torqued down, will start putting the rest together when I get time.
So the plastigauge turned out pretty close, if only I trusted it initially, could've saved hours of measuring, cleaning and unnecessary stress. Better to be sure than find out the hard way I suppose.
  • Like 3
  • Thanks 1
    • That is surely the biggest gathering of Stageas in North America, ever!
    • Remember kids - if you can't afford to buy 2 GTRs......
    • I know people cry at the price of the Getrag 12-14k for a conversion now, but it really is a nice mid point. Not going to get change from 10k on a gearset installed.  $30k++ for sequential.   I know you run the risk of a damaged used one and parts are hard to get but as a street car gearbox its really hard to beat. If you enjoy a more traditional manual, its the choice no question.
    • Time to decide what’s more import, your power level or your budget because you’re going to struggle to keep both
    • Our Southern Highlands Cruise is proudly registered with “R U OK?” Day.  Sometimes the best way to check in on your mates is by getting out for a drive together. Sharing a common passion like cars creates the perfect space to chat, connect, and support each other.  A simple “R U OK?” can make all the difference. Let's enjoy the drive, the company, and look out for one another. PLEASE WEAR YELLOW FOR “R U OK?” DAY Sunday 14th September 2025 9:30AM Meeting Crossroads Homemaker Centre 10:00AM Cruise Departure Via Old Hume Hwy 11:45AM Arrival at Mittagong RSL Club Meet Location: Crossroads Homemaker Centre Final Destination: Mittagong RSL Club *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
