  • 2 months later...
Update time:
Took out the floating barge shit box to Wakefield with the same tyres, same alignment just a new turbo setup and better front brakes.
Managed a 1.11.05 according to the Q-Starz. Pretty happy, my other mate (more experienced driver) did a 1.10.02 and not to mention it was his first time behind a floating pile of shit R33.
Pretty happy with the performance of these coilovers - however I sense I need some form of basic aero at the rear because I can really feel the "sloppiness" when I lift off into turn 1. Driving my mate's 180SX with a basic front splitter and a massive Voltex wing it feels so much more planted around corners albeit he actually has softer springs too.
No real warscars this time, just:
  • drove home with metal to metal rear brakes (had to shift down to stop like a mad man to reduce braking usage)
  • snapped off an exhaust bolt after I ran over a fire hydrant hose on the freaking track
  • new dead bugs and more rock chips lol
For next outing:
  • GT-R wing
  • New rear pads, will be going Intima Type-D rears to match the fronts
  • New bucket seat, my current Brix 1.5 doesn't hold enough
Hey Johnny - Curious to get some more info on height adjustment if you're willing to share.
I read on their old website somewhere that they recommend adjusting the spring perch (which would effectively change the spring preload) Is this correct?
yeah easy man!
yes they recommend adjusting the spring seat to adjust the height of the car.. I believe they recommend this to 1. pre load the shock so you're not always at the top of the shock stroke and 2. you won't bottom out the car.. the car would essentially hit the bump stops instead of the ground.
so the free play experienced when the car is lifted is quite normal. Japanese and decent Bilstein, KW, etc.. all have helper springs to avoid the free play/spring drupe.
  • Like 1
yeah easy man!
Makes sense! Thanks - Guess this is why my non base height adjustable pedders have that helper spring on it (which after 8 years is now essentially useless - They are cactus now)
Pedders = BC BR = Blitz ZZR
They're identical... however not sure if the valving is identical.
Have been in both BC BR and Pedder equipped cars and both felt harsh considering both were your run of the mill 8/6kg flavours.
MCA even advise me to get softer, but I ended up with 10/7kg but I like it very much the way it is. I've dropped both ARBs to the softest setting and utilise the stiffer springs to reduce the roll. Car feels very compliant on the track and when the dampers are clicked back for the drive back home they're honestly just as comfortable as my old Bilstein shock/spring combo (of course hitting a pot hole or running over reflectors aren't as comfortable but you get the idea).
Ahhhh - yep they are very harsh but these are the old ones, not sure if they are the same. I have the receipts for them at home too from the old old owner and they weren't cheap either.
That's the new Pedders stuff yeah? I thought the old 'package' they sold were Monroe dampers and whatever springs they had.
Mine are the old ones, so they may be the Monroe ones. Either way, horrible suspension.
  • 5 weeks later...
UPDATE time betches!
  • Car doesn't dose well anymore (new turbo)
  • Car has literally no traction now (running normal street tyres, Nitto NT05)
Anyhow enough of the silliness, last night was the first time ever I have taken the R33 shit box on Parramatta Road with the MCA X-R.. at first I thought I would pop a few discs out of my spine however it was quite the opposite. As the car is now being used for more daily use (gave our daily to the missus' sister) it's on 98RON and also has a set of Nitto NT05 on 18x9 wheels... no silly stretch or poke homo shit too.
Front dampers were set to 3/12 and rear dampers set to 4/12. Very surprised that the ride quality was decent, considering i'm on 10/7kg springs which are considered a little on the stiff side. I would dare say it was more comfortable than the basic Bilstein Shocks & spring combo I had on the car before.
So there you have it, you can have comfort and handling all in one package.
  • Like 1
Good to hear! My X-R arrived today so this is comforting to hear.
Oh wow, 3 & 4 are quite low. Have you gone for a run on a stiffer setting to see if theres any major differences?
Yeah I usually drive to the track on 5/12 front and 6/12 rears with about 80L of extra fuel ontop of the 60L in the tank + 2x semi wheels (I drive down with front street tyres and rear semis) + a full tool kit lol.
It was on the spongey side, but not crashy and floaty.. still very composed.
  • 2 months later...
UPDATE TIME CNUTS!
So went back to Wakefield Park again yesterday and managed a 1m09.6s around the circuit. Only difference this time was a GT-R rear wing, set to 3/4 setting (nearly max angle) and only fekkk the rear end grip changed dramatically!
No more dori dori across the track like a mad man. Everything else remain the same.
  • Like 1
    • Order for the 2025 model R35 GT-R were accepted from 3rd March and 26th August the last order rolled off the production line at the Tochigi plant. Concerning the R35 GT-R replacement, current Nissan CEO Ivan Espinosa said "Nothing has been decided about the GT-R at this time, but we are well aware that everyone is waiting. The GT-R will evolve and reappear in the future. Please be patient until that day comes." Nissan has a lot of issues with management and finances so take Espinosa's words with a big grain of salt. From what discussions I've had and read about here in Japan, not a lot of people are confident about Nissan's future, let alone the next GT-R.
    • Thanks. We getting some parts along too so he will be solving the speed issue like next week so i will let you know what he came up with.
    • 21 is explicitly the coils detected as the issue. Is it guaranteed the actual issue? No. Just the ECU thinks it is. When you say rattling, describe it better, get an audio clip as best you can if possible.
    • Yea got me coppers. Bad news is I just put them in and the car still has the light and shakes. I also noticed I hear like rattling coming from the exhaust piping right under me. Does 21 also have a possibility of being O2 sensors?   So, coil packs are good, the harness is good, the MAF is working, and obviously the spark plugs just replaced and working.
    • Make sure you drop the GTT base tune back in, and set your injectors again, this will remove anything playing up with it you may have removed. Possibly lean there as it's normally a fast transient going THROUGH atmospheric pressure, and a turbo motor would then quickly go richer as boost builds. The only worry you MIGHT have is ignition timing, as the DE is higher compression than the DET from memory. But again, you're not in boost, so the DE motor will be a lot more forgiving at atmospheric.   Get Murray, Kinkstahs, and Johnny's input on tuning haltechs, those guys have played with tuning enough in the past to be able to help now you're past the trouble shooting stage of the MAP issue
