Im 17 of age and im thinking of getting an R32 GTST as my first car of my own. Ive done previous Go-Cart racing and have had some experance in 180sx and have a growing have a fascination for the cars . The thing is im unsure of what exactly to get and what not to get in a first car.
I have 15 Grand to spend but i dont know exactly wat to expect.
https://www.sau.com.au/forums/topic/46086-1st-car/
$15k should buy a nice, clean R32 gtst with a few mods. With all cars, don’t but the first one you see. Check out a few, and I would suggest maybe taking the car to a workshop that knows skylines, and get them to give it the once over.
Also remember to factor in insurance, as that can be a real killer for some one so young, with a turbo import.
To give you an idea of what to expect for your budget, check out the for sale forums on this site , www.carsales.com.au and keep a close eye out on www.tradingpost.com.au
https://www.sau.com.au/forums/topic/46086-1st-car/#findComment-936862
keep in mind that those r33s for 15 g would be absolutely shithouse. For 15g, you'll probably get a 93 r33. but then again, the r32s are starting to get a bit old too. How about a late model 200sx or a 180? I mean, jeez, an 11 yr old r33 that has been thrashed for most of its life? The r32 would be worse.
https://www.sau.com.au/forums/topic/46086-1st-car/#findComment-939629
if the cars worth 15k... after just over 4 years of insurance (@~$3.5k) you will have spent the cars worth! (minus the fact that your insurance gets better as you go on... so maybe 5 years i guess)
so... i'd rather get 2x r32 gtst's (+ 3rd party) and have one as my insurance (panels etc :P ). all i have to do is write a car off every ~4 years to break even with full comp.
*this has it's faults, i know... and i'm not serious :)
https://www.sau.com.au/forums/topic/46086-1st-car/#findComment-940559
Bare in mind that you may need extra money to fix stuff that goes wrong, particularly on a 15 year old car. I mean, i only got my '96 R33 last week and already i've had to replace a battery, get a timing belt changed, have my injectors cleaned (or something...) and have a broken castor bush replaced... make sure you have extra cash to cover things like this!
https://www.sau.com.au/forums/topic/46086-1st-car/#findComment-942483
I'm sure an R32 GTR can be bought for $15k :thumbdwn:
Ummm yeah u can, u can get an 1989 R32 GT-R for 16 grand. I found one in perfect condition. Thats the price for it to be fully complianced and shipped to Autralia. You just gotta get off your arse and look around and u can easily get an r32 GT-R for that price.
https://www.sau.com.au/forums/topic/46086-1st-car/#findComment-942700
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
