Shameless plug warning!
If anyone burned through the last of their tyres at Sandown, give a thought to this pair of 265/35/R18 AD08Rs I'm selling...
http://www.sau.com.au/forums/topic/462561-fs-ad08r-26535r18-x-2/
I had an awesome time with some decent track time for once and I knocked my PB down to 1:24.7.
Also I noticed in the sup regs that there were awards for different categories on the day? Were these decided as I wasn't there right until the end...
Yep it was a pretty good day and well organised. Weather was also great. Thanks to all the organisers and volunteers who put the hours and effort in to make days like this possible. You guys are awesome and much appreciated.
How'd that oil leak end up?
It ended up not being from the oil cooler setup. Was from the only proper braided Teflon speed flow fitted hose on the car. Turbo oil feed. User installation error, too close too turbo flange. Cooked it and made a pin hole in it. Rob sabbaddin happened to be around and fixed it up for me, shortened the hose and got me back out for another session. I again installed it the same way and it failed again. You live and you learn I suppose. I live just down the road from sandown and made sure the oil was topped up and cruised it home. Fixed it properly the following day. Now I just have gear box issues to worry about lol.
Ah ok. Bummer. But good it was fixed close to home.
    • UPDATE: Yes the GSP Axles are compatible. I installed it on my R34 today and they are working a treat! Turns out that the S13, S14, S15, and 200 SX all used the same axles as the HR34, and ER34 NA models. Which is 2 bolt x 3 pairs.
    • Also build this EH ute with 370z motor and gearbox with a couple of turbos just for fun.
    • Got the passenger door on plus the master cylinder and booster. Loaded up to take it home. At home, the colour changes a lot in the light.
    • Nothing cheap, but I have seen the AC Hydraulic DK13HLQ which is pretty close to what you're asking for. The problem is the hydraulic cylinder mandates that the back of the jack be a certain height and Skylines have fairly deep inset floor jack points. A more certain and cheap option is to get some nominal 2x10 inch lumber boards and have one board be 1.5 feet, the other board 3 feet. Glue it all together with lots of clamps to maintain pressure. Make two of these. The ramp suggested above is a good idea, it takes quite a bit of clutch slip to get over each of the boards. I only need the first ~1.5 inches for my low profile jack on a standard ride height car but a lowered car you want to go up to the full ~3-3.5 inches. Paint it or store indoors if you want it to last.
    • Ok. And Nistune? I read (here too) mainly on Stagea threads that it can by "turn off" with Nistune. But they say they still had the sensor plug in. Next week iam going to the Nistune(and other ECUs) tuner so i can finally make it work. I drove the car home and apart from the cut it drove great. No misfire no smoke no hesitation or rough start...so hoping it is this sensor that is missing
