Have updated the list, cheers guys!
Already looking like a good turnout :)
How far in advance do you need to know if additional people are coming?
Week prior should be fine to confirm numbers.
  • Like 1
I'm in for this one.
+1 for lunch. Hopefully they have GF options!!!!
No work that weekend so good to give the car a run!! :-)
will probably have to bring your own girl friend.
  • Like 5
Please add Charles and Clinton to the list.
I am still having trouble talking the wife into coming along as it is 600 km and 8 hours driving for the day from down in Wollongong.
I also hope we have better weather than last year as we were caught up in the "storm from hell" on the way home.
  • Like 2
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
