It probably does. They are just R200 housings. The front flange should be the same (both have CV joints there instead of a Uni). The axle flanges should be the same. The front subframe mounts should be in the same location (although I suspect the R34 housng would have larger holes because it would use bushes, where I think R32 housing have small holes just large enough for the bolts because no bushings.) The rear plates are probably different. 2 bolt vs 4 bolt, but rear plates are easily changed.
But keep in mind, just in case you didn't expect it, that you could not swap in an R32 diff and its 4.11 gears without doing the front diff too.
  • Like 1
Shaft lengths are different too IIRC, ideally you still want a R33 Non VSpec rear, for what you are doing :)
So R33 GT-R rear diff should be able to bolt straight in then? Ie - shaft lengths arent different?
The R32 GTR uses bushes at the front of the diff, the bush is the same across the R32, R33 and R34. The rear diff cover on a R32 GTR is 2 bolt not 4 bolt, only the GTS variants run the 4 bolt rear diff cover. With the 2 bolt spacing on the R32 it's the same as the R33 and R34.
I can confirm the R32 and R33 rear half shafts are the same length. Nissan lists the same part number across the R32 - R34 GTR's Left 39601-05U00 Right 39600-05U00.
The only thing you can run into with the R32 diff is the early model ones had 30 spline axle flanges and the later model had 31 spline. Nissan FAST lists the changeover as February 1993. If you are only going to rebuild the stock 2 way mechanical diff or run the nismo GT pro (it comes with new axle flanges) this won't be a problem, if you are going to run the quaife ATB helical LSD you will need the 31 spline axle flanges.
    • oh they were with that motor, you need to remove the engine to change the spark plugs (don't have to, but it does make it easier)
    • I certainly fall into the annoyed camp, but glad to hear that if it's happening at low boost then I'm not likely going to blow a turbo and end up with metal shards in my oil. Just feels like it prevents me from really driving it without hesitation and "peak" performance. Wonder if it's the VCAM, it did an impressive job of shifting the torque curve and faster spool, but maybe now it's "too fast" and there's too much air for how open the throttle is.  Based on some other threads, will also do some reading on synchronizing the actuators. They are the default actuators that come on the Garrett's and I would think they would be set the same coming from the factory, but if the turbos don't actually work exactly the same way at the same time as previously mentioned, it would be worth making sure the actuators are actuating together properly
    • I went down this rabbit hole before, ended up sourcing a motor from the UK (I'm in Japan) which also didn't function correctly. With the original motor, I disassembled it and reassembled it and it works somewhat, sometimes. What I could deduce from all my screwing around is that there is calibration of the gears on the inside of the motor and two ramps on the main gear which activate switches that operate the motor and move the sunroof either to retract into the roof or tilt. Where I got stuck was that, it seemed in my case that one or both of the switches that are activated by the ramp on the gear did not always activate and thus the motor did not move, causing it to sometimes not retract or tilt (apologies, I've forgotten which way it didn't work.).  Of course this part is discontinued at Nissan now, it's the same part in the S15 but no other models. I also contacted the manufacturer of the component for schematics - forgot the name, they're based in Gifu - but they declined to share the information due to being bound by an NDA, sadly. Looking through my pictures now, it seems I last had a crack at this in 2022. See, I so kindly wrote "open" and "close" next to the switches. If you figure it out, please do tell me. Those little switches, with the red buttons may need to be replaced.
    • It says 300ZX, does that make it an Aus delivered car? Funny how back in the day I just couldn't care less about Z32's and these days I am just in love with them. Back when Nissan was into pushing the envelope. 🤣
