A bit on cyl 5 mate & im thinkin that cyl was the one not firing, i got plugz n stuff but need to swap plug tool tomoz for superchep.
If you have oil in the no 5 runner of your single setup you have most likely blown the piston ring, if it wasn't firing because of no spark then the engine would run rough and the runner would most likely smell like fuel.
I think you have popped a ring.
SO i need some f**king help, heres how it iz:
bought car after sitting 2 years and forged motor with 20k km on it, blown turbo rear housing (turbo removed & gone), seller lost interest and boought an f6.
came with an f6bb turbo i fitted and made lines n dump etc. I finally started it fine and then found it to be very smokey when revved. I pulled turbo intake off and BAM oil everywhere, took dump off and BAM oil everywhere.
runtime 5 min with 1mm restrictor. I figured well seals are f**ked for oil to get into front and back.
Prev owner said turbo only had 10k km on it and was very surprised & gonna look into it.
So i buy a r33 turbo just to get this car moving & regod and.............BAM same thing again oil in front and rear housing after few min startup and no restrictor and now im furious.....well at the time i was, but the guy gave me his word hed give me money back if it was blown as he didnt use that turbo.
NOW im thinkin do i have that bad a luck where i make 2 turbo setups work and there both f**ked ?? f**k this i should just buy a newby.
WHAT i did notice is with the r33 turbo the car was missfiring and i did notice oil was in cyl 5 from the looks of the head and manifold, so i checked the manifold from the f6 setup and there too was a bit of oil in cyl 5 there too, But surely that cant get into the front turbo housing.
SO WHAT DO YOU THINK ?
a combination of 2 f**ked turbos and oil in cyl 5 like the head gasket is f**ked or what.
SO i got a r34 op6 and made sure it was not f**ked, guy showed pics of upgraded turbo he put on and stocky was taken off in running order with 140k km on it so today i hope to fit it and see what up !!! wish me luck f**kers
Peace
do u speak engrish
Please explain.
Thankyou, im hopeing no rings are f**ked as it a low km rebuilt forgieieiei, ill find out in a few hours. cheers
you may find that the only thing forged in that engine is the lies that the previous owner told you about it. lol. I hope not for your sake, time will tell.
Im friends with the prev owner fool, if the motor is in fact f**ked i will be able to sell the billet 31 spline full spool to recover my costs. EAD MOFO
What has the spool got to do with the engine? And why do you have it?
Aren't BW78 full centres on ebay for 100 bucks?
You should probably choose your friends more wisely ya wanker troll dole bludging loser son of Rajab bitch. Lick my chocolate starfish tosser. Lol:lol:
  • Like 1
    • Oh, I forgot too, all the multimedia stuff captured and sold through things like people playing Pokemon Go. Pokemon Go specifically, can actually be traced all the way back to a CIA investment company too. So yep, they're watching everything. Not to mention the new stuff where they've worked out how to use WiFi signals to be able to map occupants inside of a building. That one would be something that I see being more used in public/government buildings, as you need to understand the signals when the room has no one in it first. It's not as easy as Hollywood would like you to think it is.
    • Followed ☺️ Assuming those are NEO rods, then at least 400kW all day.
    • Lets keep this going , Spotted this very stock V35 in Penrith and also saw a nice R32 FLY past me on Castlereagh rd , sounded really good.
    • Great work! Give it a clean up with some Emery paper, and I'd run a thread die over the threads too to clean them up. It will make reinstall much easier, and also life easier for the next time it needs to come out.
    • I'm not a fan of high humidity, it's one reason I don't mind being further inland out Ipswich, except the last 3 odd years, the drought broke, and it won't stop raining, which is making the humidity nearly unbearable when the rains are in during summer! For me, my body hates the cold, once the cold sets into my body, I'm totally screwed. I end up with severe muscle spasm in my back/shoulder muscles, and it feels like someone is trying to tear the muscles out. I have no issues with it getting stupid hot, so long as the humidity goes away. So the last 3 years as above, have been woeful! Ha ha. However, June 1st, and I'm only just converting from shorts and a tee, to long pants and a t shirt. And that's mainly as it's a bit wet and miserable and I wanted to work on a car.
