Don't put a 2.6 crank in. Pay the coin and out a 77.7 or larger in.
You can still put the Pistons in depending on rod length. The HKS 2.8 uses stock length Rods (121.5mm) for the 2.8.
*Tomei use 119.5 mm rods for a 77.7 2.8 stroker.
https://www.sau.com.au/forums/topic/461866-rb26-28-dilema/#findComment-7657944
awesome soo i can use my rods? on an 2.6 build?
Rods will be fine to re use though.
What's actually wrong with the crankshaft?
mechanic put the lines on the oil relocator kit wrong soo it was pumping threw the outlet and passing threw the inlet dame shame too here are some pics of the car, when we opened up the mains were gone, thank god my reimax oil pump was still good my head fine, ive got an hks built head on the car, i was looking at the step 0 hks crank its only 1900 dollars i think im going to go with that
12312422_10156309487640182_69799159_n.jp
12348182_10156309487685182_760042887_n.j
12278068_10156309487630182_816281595_n.j
12336219_10156309547425182_924797934_n.j
Edited by Regan2860
https://www.sau.com.au/forums/topic/461866-rb26-28-dilema/#findComment-7657969
So the mechanic owes you a new crank then right? That's a noob error.
unfortunately he would owe me a hks step 2 crank and a gt block... but thats like what ? 8 thousand dollars? he doesnt make that in a year, 3rd world country man, im just going to put a stock freshened up short block, goin to tune it down from 750whp to 550 witht the water meth injection low timing itll last years, i have to sale the car anyways moving to austin texas, got an awesome job at boostlogic, wana hop into an r35 as soon as i get their
https://www.sau.com.au/forums/topic/461866-rb26-28-dilema/#findComment-7658421
He doesn't have insurance?
https://www.sau.com.au/forums/topic/461866-rb26-28-dilema/#findComment-7658459
    • I thought it could be an issue because the standard plate was flexing when stressed. Maybe the original gear set will hold a bit better without flex? Last time on the dyno it made around 670nm at the hubs. Now it have bigger turbo and better intake but have not been on a dyno yet. The car is being used from family trips to drag race events. So the shifts can be a little violent. It is grinding if I shift to fast so was thinking I should overhaul it soon.
    • From the factory on RB26s there's a fitting on the intake manifold collector/"plenum" that provides pre-throttle boost signal. That's how they did it back in the day, I figure it's fine to replicate it.
    • I would be surprised if that wasn't the issue. It's probably telling you, that even if you remove the plastic liner, you may have some other clearance issues that may occur too in some scenarios. IE, tyre to guard. It looks like someone has already rolled the lip, but you may still have issues in the future IE, turning and hitting a bump etc. The fact it changes how bad it makes the noise when you are going backward vs forward is highly indicative that it's the tyre rubbing. They do make a terrible sound, even if you're only pushing a project car that has a liner hanging down on a tyre!   Has the car been lowered? If it has been, what is the measurement from the centre of the wheel hub to the lip of the guard straight up?
    • Summernats cruiser?
    • Mark's a bit smarter than people give him credit... He'd convince the person that is to become dead, to drive him to the forest first. That way his car has no evidence in it, and he's free to dispose of their vehicle permanently how he sees fit too...
