everyone start looking for a new set of front guard for duncan he loves the biffo!!!!!
werd. I have a memory of duncan at turn 1+2 Oran GP track in a daewoo. oh the carnage....
hehehe.
  • 4 weeks later...
SAU Nickname: jlnewton
Car Make and Model: R33 GTR V-spec
Circuit Name: Queensland Raceway - Clubman layout
Lap time: 1:03.15
Modifications
Engine: RB26DETT
Power: 196.7awkw
Suspension: Apexi T-max coilovers with king springs (F 400lbs, R 225lbs), Whiteline front camber bush and pineapples, Cusco adj caster rods and rear camber arm.
Tyres: Dunlop DO2G 235/45 R17
Brakes: Brembos with slotted DBA 4000s front and rear, Hawk Pads front and rear, Braided Brake lines front and rear, Motul fluid and cusco brake cylinder stopper.
Body weight: ????
First time I have run on anything other than road tyres, damn what a difference! Slashed 2.4s of my previous best, unbelieveable difference in grip level.
I did a supersprint at EC yesterday and managed to better my previous best by more than 3 seconds. Funny thing is the car is exactly the same as last time I was there except for rear camber pins and a decent wheel alignment. Goes to show the value of a good wheel alignment.
Best time of 1:51.6 and full results are shown here:
http://www.natsoft.com.au/cgi-bin/results....08/2005.EAST.S1
I managed to beat all other WRXs on street tyres as well as all runners on R-spec tyres as well. The only WRXs to beat me were on slicks running increased capacity (2.2 and 2.5 L engines). All in all a great day at the office! :lol:
There was one VERY fast white GTR running too. Man that thing was quick!!! John was there in the very boosted Zed but judging by his times something was amiss.
Anyway here's the list of specs and mods again:
Modifications
Engine: HiTech 3" SS turbo-back, retuned stock ECU
Power: Dunno-about 170kW ATW
Suspension: Stock with 20mm lower Pedders springs, 22mm rear swaybar and rear camber pins
Tyres: Standard 05 STi Bridgestone RE070
Brakes: Stock Brembos with DBA4000 rotors, DS2500 pads and Castrol Super Response DOT 4 fluid.
Body weight: Pretty much stock STi-not sure.
Well done Ben that's a great time for a hyundai :P
Here's what I did the other weekend:
SAU Nickname: Duncan
Car Make and Model: R32 GTR N1
Circuit Name: Oran Park GP
Lap time: 1.21.2
Modifications
Engine: Standard
Power: not sure yet, standard boost and factory ECU not tuned
Suspension: some jap coilovers
Tyres: Yoko A032R 245/45/17
Brakes: standard (brembos) with hawk pads and lucas fluid
Body weight: 1500
I'll have some wakefield times after this weekend, have to beat Gary's car this time :D
SAU Nickname: AzzurrA
Car Make and Model: R32 GTS-t
Circuit Name: Queensland Raceway - Clubman Circuit - 2.11km
Lap time: 1:09.86 (20/08/05)
Modifications
Engine: K&N Pod Filter & 3" Turbo Back Exhaust
Power: 131.7kw @ Wheels
Suspension:
* Bilstein Shocks
* Kings 'Low' Springs
* Whiteline Adjustable 24mm Front Swaybar
* Whiteline Adjustable 22mm Rear Swaybar
* Whiteline Adjustable Front Camber Bushes
* Whiteline Adjustable Castor Bushes
* Whiteline Adjustable Rear Camber Bushes
* Whiteline Lock & Align Kit (Set up for handling)
* Urethane Lower Control Arm Bushes
* Hicas Lock Bar
Tyres:
* Front: Falken Azenis RT-215s 205/55/16
* Rear: Toyo Trampio GU:WN 205/55/16
Brakes:
* Standard R32 GTS-t M-spec calipers & Rotors
* Motul RBF600 Brake Fluid
* Race Brakes RB74 Compound Brake Pads (Front
* Generic crappy pads rear
Body weight: Full Street Trim (Including Spare Tyre in Boot)
following up from ben that gtr was greg from autosport it was hooking
696 Greg Boyle SSCC Nissan Skyline SVD 24 4 1:48.1900 0:06.1600
only reason i bring this up was cause
John Penlington SSCC 4D 5 4 1:49.6400
seems the slot car got hossed by a street gtr lol
great time gonads (shame you drive like a girl)
anyway i did a good time up and over the hill 3 donuts on the way down and got the hell out of there before being arrested (PB for myself)
love your work pete. next time should be good for 4 or 5 donuts pre-incarceration...noice.
yeah, Greg certainly knows his way around eastern creek. his car fairly hammers too.
I did a supersprint at EC yesterday and managed to better my previous best.......
Hey good work Nads - do you still take turn 8 flatstickfullycrossedupfacingthefarkingconcretewall or have you found a more exciting way round it?
Edited by Bonkers
niccce
good to see a vg car getting its tits thrashed off it
Well done Ben that's a great time for a hyundai ;)
Thanks Duncan. I'm pretty happy with my effort.
Howdy Bonkers! I've graduated from taking turn 8 as "flatstickfullycrossedupfacingthefarkingconcretewall" and now I'm trying to take turn 1 the same way. :) Seems to have worked reasonably well.
I've gotta admit I was shown my way around Eastern Creek by an absolute master! Since the 1/2 day I did with you I've only done 1 other full day at Eastern Creek so maybe I was listening to your pointers?
None of this sticky tyres crap either. Go the street tyres!
So when are you guys coming out to Orange?
Cheers,
Ben
Car Make and Model: R33 GTSt
Circuit Name: Mallala
Lap time: 1m25s
Modifications
Engine: stock rb25det
Power: ran @14psi (unknown exact rwkw), but makes 265rwkw @16.5psi
Suspension: bilstein sports plus kings 1inch lowered
Tyres: RE55s
Brakes: Stock setup using 4000rotors front and EBC greens.
Body weight: stock
Was first time on a track and only ran 2 short sessions so pretty pleased with the time :P
Washing off some speed before throwing her hard into turn one (had the most fun throwing into this corner a bit overspeed then trying to catch the tail before hooking round the hairpin :huh:)
Edited by SLY33
    • Update 3: Hi all It's been a while. Quite a lot of things happened in the meantime, among other things the car is (almost) back together and ready to be started again. Things that I fixed or changed: Full turbo removal, fitting back the OEM turbo oil hardlines. Had to do quite a bit of research and parts shopping to get every last piece that I need and make it work with the GT2860 turbos, but it does work and is not hard to do. Proves that the previous owner(s) just did not want to. While I was there I set the preload for the wastegates to 0,9bar to hopefully make it easier for the tuner to hit the 370hp I need for the legal inspections that will follow later on. Boost can always go up if necessary. Fitted a AN10 line from the catch can to the intake hose to make the catchcan and hopefully the cam covers a slight vacuum to have less restrictive oil returns from the head and not have mud build up as harshly in the lines and catch can. Removed the entire front interior just shy of the dashboard itself to clean up some of the absolutely horrendous wiring, (hopefully) fix the bumpy tacho and put in LED bulbs while I was there. Also put in bulbs where there was none before, like the airbag one. I also used that chance to remove the LED rpm gauge on the steering column, which was also wired in absolute horror show fashion. Moved the 4in1 Prosport gauge from sitting in front of the OEM oil pressure gauge to the center console vents, I used a 3D printed vent piece to hold that gauge there. The HKB steering wheel boss was likely on incorrectly as I sometimes noticed the indicator reset being uneven for left vs. right. In the meantime also installed an airbag delete resistor, as one should. Installed Cube Speed premium short shifter. Feels pretty nice, hope it'll work great too when I actually get to drive. Also put on a fancy Dragon Ball shift knob, cause why not. My buddy was kind enough to weld the rust hole in the back, it was basically rusted through in the lowermost corner of the passenger side trunk area where the wheel arch, trunk panel and rear quarter all meet. Obviously there is still a lot of crustiness in various areas but as long as it's not rusted out I'll just treat and isolate the corrosion and pretend it's not there. Also had to put down a new ground wire for the rear subframe as the original one was BARELY there. Probably a bit controversial depending on who you ask about this... but I ended up just covering the crack in the side of the engine block, the one above the oil feed, with JB Weld. I used a generous amount and roughed up the whole area with a Dremel before, so I hope this will hold the coolant where it should be for the foreseeable future. Did a cam cover gasket job as the half moons were a bit leaky, and there too one could see the people who worked on this car before me were absolute tools. The same half moons were probably used like 3 times without even cleaning the old RTV off. Dremeled out the inside of the flange where the turbine housing mates onto the exhaust manifolds so the diameter matches, as the OEM exhaust manifolds are even narrower than the turbine housings as we all know. Even if this doesn't do much, I had them out anyways, so can't harm. Ideally one would port-match both the turbo and the manifold to the gasket size but I really didn't feel up to disassembling the turbine housings. Wrapped turbo outlet dumps in heat wrap band. Will do the frontpipe again as well as now the oil leak which promted me to tear apart half the engine in the first place is hopefully fixed. Fitted an ATI super damper to get rid of the worn old harmonic balancer. Surely one of the easiest and most worth to do mods. But torquing that ARP bolt to spec was a bitch without being able to lock the flywheel. Did some minor adjustments in the ECU tables to change some things I didn't like, like the launch control that was ALWAYS active. Treated rusty spots and surface corrosion on places I could get to and on many spots under the car, not pretty or ideal but good enough for now. Removed the N1 rear spats and the carbon surrounding for the tailpipe to put them back on with new adhesive as the old one was lifting in many spots, not pretty. Took out the passenger rear lamp housing... what do you know. Amateur work screwed me again here as they were glued in hard and removing it took a lot of force, so I broke one of the housing bolts off. And when removing the adhesive from the chassis the paint came right off too. Thankfully all the damaged area won't be visible later, but whoever did the very limited bodywork on this car needs to have their limbs chopped off piece by piece.   Quite a list if I do say so myself, but a lot of time was spent just discovering new shit that is wrong with the car and finding a solution or parts to fix it. My last problem that I now have the headache of dealing with is that the exhaust studs on the turbo outlets are M10x1.25 threaded, but the previous owner already put on regular M10 nuts so the threads are... weird. I only found this out the hard way. So now I will just try if I can in any way fit the front pipe regardless, if not I'll have to redo the studs with the turbos installed. Lesson learned for the future: Redo ALL studs you put your hands on, especially if they are old and the previous owners were inept maniacs. Thanks for reading if you did, will update when the engine runs again. Hope nothing breaks or leaks and I can do a test drive.
    • No those pads are DBA too  but they have colors too. I look at the and imo the green "street" are the best.
    • I’m not sure what happened I told them about sonic tunes free OTS tune and the next the I know .. I was booted..   To funny
    • Yea - I mean I've seen my fuel pump which is decades old and uh, while I'm not saying this with real knowledge... but I sure get the ick at using anything in the fuel system that produced the state of that pump. Many years ago I went through multiple pumps (and strainers) before I dropped the tank to clean it out with extreme violence. I'm talking the car would do maybe 50km before coming to a halt, which resulted in me cleaning out the filter with some brake cleaner and going on my way. None of my stuff ever looked like what came out of your fuel tank. I don't think I'd be happy with it unless every single component was replaced (or at least checked/cleaned/confirmed to be clean here).
    • I'm not going to recommend an EBC pad. I don't like them. Just about anything else would suit me better. I've been using Intima pads for a while now.
