SAU Nickname: PN-Mad (Alex)
Car Make and Model: 1994 180SX
Circuit Name: Wakefield Park
Lap time: 1:10.5 (GPS timer)
Modifications
Engine: SR20 GTX3071, 44mm gggaaaaaaattttteeee.
Power: 290rwkw
Suspension: Tein coilovers, whiteline bars
Brakes: 324mm fnt, gtst rear, A1RM pads
weight: 1100-1200 plus one fat arse driver
tyres: Federal RS-R 235/45/17
First time to Wakefield, and first time driving the car in anger. Need to install some skills and try again!
New PB for me
SAU Nickname: Ant97gtr
Car Make and Model: R33 GTR
Circuit Name: Phillip Island
Lap time: 1:43.9259
28/04/13 PIARC Sprintshttp://racing.natsoft.com.au/results/#2
Engine: Built RB26
Power: 330kw @ Racepace Dyno
Suspension: Racepace Tien RA's with adj arms
Tyres: ADVAN AO50 265/35/18 mediums
Brakes: CSC 6 piston front and stock rear with RDA slotted rear rotors
  • Like 1
  • 4 weeks later...
This is from a Circuit Club track day at Wakefield in mid December 2012
SAU Nickname: Tim
Car Make and Model: N15 Nissan Pulsar
Lap time: 1:16.075
Modifications
Engine: SR20VE, N1 Cams
Power: 130kw
Suspension: BC BR Coilovers
Tyres: Advan A048 (225/50R15)
Brakes: R33 GTST calipers, RDA R33 GTST rotors (machined down to 288mm) EBC Redstuff pads
Hoping to make a huge improvement on that in the not too distant future.
SAU Nickname: SimonR32
Car Make and Model: R32 GTR
Circuit Name: Barbagallo Long & Short
Lap time: Long = 61.80 Short 53.81
Modifications
Engine: RB26
Power: 600rwhp
Suspension: Basic old Tein Coilovers, cusco arms and swaybars
Tyres: 265/35R18 AD050
Brakes: CSC 4pots with 343mm 2 piece rotors and R34 GTR Brembo rear
Body weight: TBA, full interior etc so heavy
Date: 16/06/13
Lap time: 2:03.826
Timing method: Natsoft
Modifications
Engine: RB26 with PowerFC, Garret -7s
Power: 325rwkw on E85
Tyres: Kumho KU36 245/35/18
Brakes: Stock with A1RM pads in the front
Body weight: Stock minus rear and passenger seat.
SAU Nickname: ssxRicho
Car Make and Model: R33 GTST
Lap time: 1:04.9
Modifications
Engine: hypergear 21U highflow, pfc, greddy cooler
Power: 260rwkw On United E85
Suspension: greddy dampers, BC Racing springs, whiteline bars, cusco front camber/castor
Tyres: Hankook Z222 (RS3) 285/35 R18 (utqg200), RPF1 18x10 + 38
Brakes: ksport 8 pot 330mm front, EBC blue pads
Body weight: no interior + others (1280-1300kg)
Great time Richo. Wakefield is awesome! Can't wait to go back. How did you measure that weight? Very light. Mine is down to 1250 with lexan, gutted doors, and a very, very bare car. You only got a half cage right?
No cage at all.
Weight is a guess, 1380kg on the scales at PI with 1/2 tank when the interior was in. Take 80kg'ish off that, includes the A/C which is gone now.
Mine is pretty bare now as well, though have to retain the glass, dash and door cards.
  • 1 month later...
SAU Nickname: Wag.00n
Car Make and Model: HR31 gts-x
Circuit Name: Eastern creek GP (old track)
Lap time: 1:48.48
Modifications
Engine: Rb25
Power: 240kw @ 14psi
Suspension: k-sport Coilovers
Tyres: Yokohama ao50's
Brakes: k-sport 356mm 8 pot and 330mm 4 pot
Body weight: not sure
Modifications
Engine: RB26
Power: 600rwhp
61.68 long track now
  • Like 1
  • 1 month later...
SAU Nickname: Johnnilicte
Car Make and Model: R33 GTS-t (Fridge)
Lap time: 1:16.8
Modifications
Engine: stock, just turbo back exhaust, fmic & 0.84bar boost
Power: stock-ish
Suspension: some horse shit (probably worse than stock) Pedders springs & shock combo, 24mm F&R Whiteline anti-roll Bars
Tyres: Nitto INVO (Front) & Federal RS-R (Rear)
Brakes: stock, with Intima SR (front) & Bendix Heavy Duty (rear) pads
Body weight: 1500 kg?
2nd time ever at Wakefield Park.
ns nickname: nfi
Car Make and Model: SX Developments S15
Lap time: 1:01.4
Timing method: performance box
Modifications
Engine: Built 2.3
Power: 400rwkw
Suspension: Bilstein
Tyres: Hankook
Brakes: Brembo
Other:
Car weight: Not light enough
Video with data overlay.
Edited by nfi
  • Like 1
