SAU Nickname: Ronin 09
Car Make and Model: GTR32
Circuit Name: Sandown
Lap time: 1:33
Modifications
Engine: Turbo back exhaust, rich-as spec factory computer (smoke anyone?)
Power: 200?? awkw
Suspension: Kei Office drift spec Mr Bouncy
Tyres: Cheaters, RE55s SR compound
Brakes: std, RB74 pads
Body weight: fat bastard
Car Make and Model: R33GTSt
Lap time: 1:38
Modifications
Engine: FMIC, turbo back exhaust, pod, Greddy intake, Profec B 14psi
Power: 201 rwkw
Suspension: Stock
Tyres: Pilot sports 235/45/18 & 265/40/18
Brakes: std, endless Y-sport?
Body weight: Full body
SAU Nickname:GTR032
Car Make and Model:1994 R32 GTR SKyline
Circuit Name:Wakefield
Lap time: 1:10.1s
Modifications
Engine:HKS front pipes, 3 1/4" TRUST cat back exhaust, removed boost restrictor, K &N panel filter
Power:190awkw's
Suspension:Tein Type Flex, several new bushes all round
Tyres:Bridgestone Potenza RE711
Brakes:Fronts are DBA4000 slotted with bendix ultimate pads, rear stock discs with kevlar type pad
Body weight:??
Was at a track day organsied by the Pulsar GTI-R club september 2003. Time was taken with stopwatch, I was a little sceptical with time initially but 'Duncan' was doing 1:11's same day and didn't pass me with several laps close to one another.
SAU Nickname:Boosted Zed
Car Make and Model:1991 300ZXTT
With 320rwkw
Wakefield 1 min:6.57
Eastern Creek 1 min 43.54
Oran South 47.99
Modifications
Engine:rwkw's
Suspension:Tein Flex, custom Rose jointed suspension. Kaz diff custom 1.5way R32 GTR Diff custom fit to cradle.
Brakes: 6 piston AP's 365mm rotors, 330mm rear slotted rotors, Ferrdod DS3000 pads with custom peddle box and in cabin brake bias adjustment.
UAS valve springs, Ferrier valves and GTR valve retainers, UAS custom cams,GTRS turbo's, ACL pistons, Scatt Rods, ported heads, 4 adjustable cam gears etc 325 rwkw circuit with boost button and 456rwkw Drags on race fuel.
regrind of cams so will make more power. Also makes 200rwkw at around 3,400 revs. Car is lightened with big dual layer carbon race wing and carbon front winglets and rear diffuser. etc etc
Edited by Boosted Zed
SAU Nickname:Abo Bob
Car Make and Model:1999 R34 4 door
Lap time: 1:18.25 timed 1:17 stopwatch
Modifications
Engine:Full zorst, panel filter, later a little boost
Power:162rwkw's for 1:17's
Suspension:Stock
Tyres: Real shitty compliance Falkans
Brakes:bendix ultimate pads,
Body weight:1440?
Haven't timed the creek yet, can't wait.
__________________________________________________--
EDIT
Lap time: 1:12.04
Circuit name:Eastern Creek
Lap time: 1:55:351
Circuit name: Oran Park GP
Lap time:1:24:379
Modifications
Engine:highflow turbo, cams, etc
Power: 257rwkw
Suspension:Bilstein shocks, king springs
Tyres: RE55's
Brakes:Ferrodo DS2500 and DBA4000 rotors
Body weight:1580
SAU Nickname: SW20-GT
Car Make and Model: 1991 SW20 MR2 GT
Circuit Name: Wakefield Park
Lap time: 1:16.68
Circuit Name: Eastern Creek
Lap Time: 2:05
Modifications
Engine: Cat Back exhaust, Pod Filter
Power:115rwkw (before the exhaust and filter)
Suspension: 1" Lowered King Springs
Tyres: 5% tread Falken ST115's rear, 15% tread Falken FK04's front
Brakes: Bendix Metal King Plus pads
Body weight:1180kg
Wheels are Racing Hart CPO35R light weight forged,18 by 8.5 and 9.5 rear with 245 front and 305 rear but now have 250 front and 280 rear. I really need wider rims to use 305 slicks so might get a pair of same wheel but in a 10 or 10.5 inch wide, offset in a little more as there is more room there.
Forgot to mention I now have custom alloy tank with 2 Bosche 044 pumps and a oil cooler used as a fuel coler on the return line which sits up under therear of the car.
Duncan says BLA BLA lets see it go though. OK will be soon.
PS More GTR parts going on teh Zed, as I ordered some N1 crank and cam seals from Nissan which are silicone I think, prob better for higher temp, and they don't cost much more. Yes thanks to Nissan they keep things universal rather than re tooling as skylines and Zeds have same crank and cam seals, spiggot bush and other items. Also has R33 GTS-T Nismo gear box mount come to think of it.
But hey GTR's use Zed AFM's but I think this is about as far as it goes.
SAU Nickname: justinfox
Car Make and Model: 1993 BNR32 GT-R
Lap time: 1:55
Modifications
Engine: Cat Back Fujitsubo exhaust, Apexi Pod Filters, HKS dump/front pipes/oil cooler, Apexi AVCR at 0.9bar of boost.
Power: ?
Suspension: Whiteline Works package
Tyres: Dunlop D02 semi slicks
Brakes: Lucas TRW pads
Body weight:?
I just did this today guys. Average lap time was 1.58. So how's 1.55? I am still getting instruction and damn how awesome is instruction huh? Before today my quickest was 2.01 I had a lot of bad habits. I am hitting the Apex ok but not using enough of the track when powering out of the apex and that's what I got better at today (yes got the tyre off into the sand a few times trying!) and it brought my times down a fair bit! Hope I can better it next time.
Yeh 1:55s is moving. :) Do you still have your speed limiter?
Im going to have to get back to Sydney with some better rubber and with my speed limiter removed, im about to drop out of the Top 10 ;)
Cheers guys.
Roy: Yes it must be removed as I go way over 180 on the straight.
It's only my 3rd time on track with the GT-R. Last time I had no brakes or boost and the time before that my intercooler pipe blew off before the day even started AND I had to get the car towed!!! (what a waste of track time and ca$h!).
I just didn't have much of an idea if it was a decent time or not. I was hesitant to let the guys time myself as I knew that once I did time myself I would only want to beat my own time and thus everything gets that little bit more dangerous! Playstation is one thing but doing it in real life is... well.. fun! :D hehehehe.
I was quick to jump on the idea of modding my car even more to get more power out of it to bring down my lap times but then I realised that this isn't such a great challenge. Instead I am going to leave the car the way it is for now and just get better at driving it to bring my times down.
So here's to looking forward to the next track day, more instruction and getting to know my GT-R! Hooray!
Thats kind of the way i look at it... :D
Obviously Production Cars run much more serious suspension and tyre packages then most ppls road cars, that said if you look at the fact that an STI runs 1:45s around Eastern....well one day i wouddl at least like to see those times out of my car. Im reasonably confident at the miute my car should be capable of between 1:48-1:50s since i now have better rubber, spee limiter removed and mroe power :) .... just need to get the driver up to speed :D
...after that its going to get lot harder to wipe of another 5 seconds
yea baby
Yeh i dont think i will ever match the times of the STI production cars. A friends 200SX does 1:48s so i look at that car and the guys driving ability as a bench mark for what i can achieve.
1:45s are the target, doubt i will get there though. But im hoping you are right. 140-150rwkws with speed limiter and road rubber hitting 180 down the straight and all thru turn 1 = 1:56.
So with R rubber no speed limiter and 240rwkws i would hope i can at least match my friends time of 1:48sec...but it took me 2 years to get to 1:56 so i dont think my driving will allow me to dip down to 1:50 straight away, i think i will have to learn how to drive the car with the new power :D
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
