Hi all,
I was working on the car recently and noticed a curious discolouration of my front rotors. It's only on the inside edge of the disc on both sides of the car. Otherwise the discs look fine, even wear and no signs of cracks.
I have DBA T3 4000 Series slotted rotors all around with the standard R34 GTT Sumitomo calipers, Remsa 650C pads, HEL braided lines and Dixcel high temp fluid.
The rotors have about 15,000 km and two Sandown track days on them.
Has anyone else seen this, is it anything to worry about?
Could the inside of the disc be running hotter because of the backing plates and less airflow?
Cheers
My guess is its just some water splashed up on the inside then dried off. The paint stripes (there's three IIRC) are temperature indicators. Google for details on that.
If there's no issues with brake operation and feel, I would ignore.
Thanks Adam. Yep I know about the temp indicators, it's just the rotor colour that got me puzzled. There's no effect on braking performance that I've noticed.
Not sure what you're asking from the pics?
Nothing looks out of place either way.
And also, next time you can - cut off the shield on the inside face off the rotor. It just keeps the heat in :)
  • Like 1
Cheers. See how half of the inside 'edge' part of the disc is gray instead of rusty red like the rest of the disc edge? That's what I was referring to.
But yeah I'm wondering if I should DIY some brake ducts, might save the heat shields for that :)
Ah, yeah ok. See what you mean.
It's more protected there I guess with that heat shield on - or could be, because the heat is being kept in :)
But 100% cut the shields off, if doing brake ducting that'd also be good
You could be right.
Notice the temp paint has lifted off that area? Probably cooked it good and turned the rotor blue on the inboard side. :)
Edit, what colors are the 3 temperature markers going from left to right?
If they are White Yellow White, you cooked that baby good, well over 650 degrees, id say the inner part of the rotor went over 900 degrees and glowed a nice cherry red color, hence the burned off paint. :D
Edited by GTRPSI
This is interesting. Has anyone else cut off the rear shields??
Pretty much anyone who does track days down here mate, has cut them off their cars, whatever model/make they may be.
You cant get ducting working that well generally with them anyway.
Weird it's a SA defect item. I mean, if you cut them do it looked factory... They wouldn't even know?
Depends on who is looking. Your average cop might or might not have any idea. The dream boats that are all gung ho about busting modified cars will know. The guys at Regency will all definitely know, and if your car is defected for something else and is in for an inspection, or you're getting an engine transplant signed off and getting it inspected, then they will look and they will see. What happens then depends on why you're there, how nice the guy is and whether anyone else is watching. The guy who inspected my car for the engine transplant was really nice, a real car guy, and he let me go with a couple of small things (with a polite demand that I deal with them) rather than failing the inspection. But everything else on the car was tested and inspected. Dash lights and dimmer, demister, rubbers on the door catches, ride height, dents in the chassis rails (none, because I fixed them), etc etc. Any of those things failing can be your undoing here.
Yuh, I think it is something that falls into the category of "modifying a braking or steering system" (to paraphrase their various publications) on which the rules are pretty much "don't touch anything unless you get it engineered"....and they apply that rule in blanket fashion as it is easier than thinking. Rock shields might not do much......but they are there and they were put there by the factory, so there they must say unless someone smarter than all of us says they can come off.
  • Like 1
Ok cool, do you just cut around the hub or do the shields come off somehow?
You could be right.
Yeah I'm pretty sure they'd be cooked, my December track day at Sandown was in 37 degrees :woot: That said I did do heaps of cool down laps and never noticed any degradation of braking performance.
I'll check the temp markers when I get the car back, it's at the shop getting the steering rack recoed.
Note to self: Never move to Radelaide. That Regency thing sounds like a major PITA.
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
