Wanted to know if the HKS GTRS turbos work well on an RB26. They don't seem to be a commonly used twin setup. I was after some real world experience from people that have had them in use or been in a GTR with them attached. What are your thoughts?? How did or do they feel.
https://www.sau.com.au/forums/topic/463295-opinions-on-hks-gtrs-on-a-rb26/
They are not common due to a mixture of misinformation and people not using them as part of a complete package. They are a 'bolt on' turbo but personally to get them to perform properly requires more work. Guys like XKLABA have the right idea... didn't Paul Diemar push 500kW with these back in the day? That was on a 2.6 with a lot of head work.
yes
but he also got spanked by a 2.6 -5 powered circuit car on the strip
Put them in the bin. They suck.
Direct back to back between -5's and RS's on a well sorted 2.8.
Gav actually had a massive drag intercooler with the RS's, and changed for a smaller one with the -5s. Not sure how much difference that makes then he went E85 at around that time too.
The last I heard he is changing up again from his gtx's, the dude is mad.
Edited by s2d4
Going from 63's to 67's.
Having RS's and (I admit) it wasn't the optimal setup, they were woeful. However, I haven't come across someone that went from RS's back to the "lesser" -5's or 2530's and wasn't happier with them, regardless of engine size!
They're mismatched.
Cubes hides the shitness of these things! You DO NOT WANT these on a 2.6. 2.8 they still suck, 3.0 just hides the shitness of them.
No need to consider Jurassic park turbos in today's age.
  • Like 2
They sucked on a 3.15lt too.
Shuffled at 2000 RPM making a MAF sensor tune impossible. Despite the averaging the comparator inputs on the ECU working the data from both MAF sensors, getting a consistent 14.7:1 at light load cruise just could not be done. The load cell would move around the map when engine speed and vacuum was not actually changing.
I didn't have the surge issues that the smaller motors have, but the shuffling would happen all the way till the wastegates were open (and probably a little after that too). Full boost was at 4500.
If your trying to hide what your have under the bonnet, and don't mind having a 6000-9000 rpm power band and no low end drivability then they are great!
If your driving the engine under load from below wastegate regulated boost, they will be terrible in comparison to the -5's or anything else.
Paul Diemer's setup used SR20 GT-RS's 0.86 housings, and I believe he switched to the HKS balanced low mount manifolds too, which to a degree will have eliminated shuffle by balancing back pressure to the turbine, reducing the miss-match issue... at the expensive of even more lag. You can bet that Paul was reving the hell out of his 2.6.
Gtx2863s have more air flow rate than the gtrs turbos
The 71.1 mm RS wheel is rated at 44 lb/min each.
The 63 mm GTX wheel is rated at pretty much the same.
Gtx wheel is lighter, still has to get out of that peanut, small ass end. Cold side too big, hot side too small.
Go back through the gtx thread and Simon Haughton who did this exact combo regretted it because of heat issues.
A shiney billet wheel on the cold side doesn't fix the nugget rear ass end.
Can get in, can't get out, why bring more air in. It's farken stupid.
Trying to empty a bath with the plug pulled...but have a fire hose filling it up!
  • Like 1
    • The car/ECU will have all the sensor that it needs and expect to have. I think i do not have to explain to you how the Link is way better specialy if you have swapped engine   I just do not want to deal with any "problems" cuz i have only Nistune which i learned is not that great and in my case cant even deal with that speed problem (Link can) And of course it will be way more easier to tune and diagnose and safe. And for the ECU/speed problem...i dont know.
    • Per Mark Roberts of Sonictune: Mark Robert Author At this time, no. No ETA either 2016-17 models. You will be able to purchase and install a 2018.5+ TCU though   TCU purchasing and pricing info! As we near the release of TCU tuning, I am going to answer some questions I get asked often.   What do I need for TCU tuning? At this time, you will need a 2018.5+ TCU to be able to tune. If you have a 2016-to early 2018, you will need to replace your TCU with the newer version. One good way to know if your TCU is good is if you have auto upshift in manual mode in 1st gear around 6500 rpms. If your manual 1st gear goes to 7k rpm and will hit the rev limiter unless you shift, you have the older TCU.   Why do I need to buy another ecu license/phone flash if I already have it on my ECU tune? The TCU is its own computer module. It is completely separate from the ECU. Because of this, you will be required to purchase a TCU license and, if your tuner has it, the phone flash license required to tune it via phone/bluetooth.   Do I need TCU tuning? TCU tuning is NOT required. However, the faster your setup, the more it will assist in track and dragy time consistency.   If I’m ECU tuned by (tuner A) can I get my TCU tuned by (Tuner ? Yes, since it’s a different module and a completely separate flash, you can have two different tuners. However, it is highly recommend that you have both tuned by the same tuner. For me, my TCU tuning will directly complement my ECU tuning style and features and running my ECU and another TCU or vice versa MIGHT cause some issues. At this time and for the foreseeable future, I will only be tuning my current ECU tuned customers TCUs.     I have a SYVECS AWD controller. Do I still need it? Yes! The AWD controllers main job is to control your AWD system. However, with TCU tuning, you will no longer need the auto-shift function as that will be done through the TCU. The AWD controller will still be very beneficial for racers looking to maximize traction on the launch.     Shift schedule changes: holding gears longer at lower pedal input as well as max shift rpm changes. Please note, the new ECU race rom coming out will address 90% of the shitty drivability issues these cars have through custom maps from myself and Racebox—as well as others I am sure.   Increase shift speeds: as seen in the videos I’ve been posting, the TCU shifts much faster once tuned.   Increased shift pressures: as also seen in the videos, much firmer full throttle shifts.
    • The fancy pants red shock tower brace is finally incoming from MX5 Mania, getting it shipped from 'Merica has been a long and problematic process, and GWR, the 'Merican supplier will not ship directly to consumers outside of the US, Mania basically had to order a heap of them, the colour choice was silver, or red, and we all know anything red adds 5 killerwasps of dynotorques..... Whilst it does fit over a 2.5, and I've seen a few photos and videos of it being installed and fitting, google also says it might get real close to the FAB9 intake front runner, people in the US says it does fit with the FAB9 intake, except for one person who said it slightly touched.......so there is that.....LOL..... As it seems that I am the first in AU to have this combination of parts there's no local knowledge about fitment, so I'm just a willing guinea pig in this endeavour, I'll cross my fingers and toes and hope for the best In other news, I ordered stuff from China  on the same day I ordered the 23° silicone bend from Victoria, the stuff from China arrived a day ago, the 23° silicone bend is still travelling around Australia thanks to Australia Post, and "may" be here next week
    • Very good news...I contacted Racebox about it last night. My car is a 2016 so remains to be seen if it is compatible, requires a TCU swap, or is impossible.
