So I've just had my 32 GTR tuned, she made 309 rwkws & 20psi tailing off to 18psi. Basically made the power I was expecting so no dramas there.
The issue of concern is where she's not making full boost til ~5000RPM, reading the RB26 results it would appear virtually everyone with similar mods and power levels are seeing full boost by ~4000RPM.
Below are my mods:
Rebuilt forged RB26
R34 GTR N1 turbos (GT2860-7)
Splitfire Coilpacks
Sard 650cc injectors
Nismo AFM's
Greddy cam gears (2 degrees adv. on inlet, 4 degrees ret. on exhaust)
Nistune ECU
Blitz SBC
Walbro 460lp/h fuel pump (12v direct feed)
Stock airbox with K&N panel filter and CAI
Full custom Exhaust (2.5" twin split dump pipes (350mm separation-1.5" wastegate pipes) into 3" collector into 3.5" decat and all the way to the tip 3.5" with two mufflers)
All intake piping is stock
I did have a boost leak which is now fixed and when doing so and pressurising the system we checked actuators were opening together and they all looked good, the turbos were checked over when exhaust was done and all appeared in good nick <200kms ago.
So any thoughts?! car feels great, mind you I do now have 100+ rwkws more at the wheels so that is to be expected...but on paper it just doesn't seem right.
So you're getting 10psi at 3800. Should be more like 14 at 3800. What did the tuner say?
I'd be looking at exhaust restriction or boost control setup. Eg. did they wind some preload into the actuators?
I dont think "full boost" is a useful term, better off saying X psi IMO.
Get a passenger to watch for you. See at what speed or rpm it hits 20 psi.
BTW boost tails off slowly straight after hitting 20 psi - is this normal for these turbos?
Are the internal wastegates working properly? Not catching anywhere?
Did the tuner spend some time on the adjustable cam gears (I have no idea what the settings should be for your engine)?
If you get the same result as your chart consider changing the boost controller if adjustment doesn't fix it.
Crappy HKS style split dumps ain't helping, nor is the 3 inch small point in the exhaust.
How would they slow spool? I thought the argument against these dumps was boost creep. FWIW, i have the xforce knock offs and have neither issue.
actuators have the typical 4-5mm preload on them, boost control has been played with (gain etc.)
I spent quite a bit of time reading the threads on here with bellmouth vs. split dump pipes etc. and came to the conclusion that provided the split was long enough the benefits of either were negligible. I've attached a pic above of my system so that you can see its quite different to the HKS / X-Force style dumps you are referring to.....not saying that my system style still couldn't be the issue...though I thought it would have had an affect on power output too?!
didn't spend a heap of time with cam gears, tuned with them set to '0' and got to around 283kws @ 18psi from memory then from the research I did on here set the cam gears at 2 degrees advanced on the inlet and 4 degrees retard on the exhaust and netted 309kws @ 20psi (went to 20psi and tailed to 18psi without actually touching the boost controller settings.) so I was relatively happy with that change and didn't play around any more...
interested in this too...
It's probably in the tune. We need real world not stupid dyno paper
as I mentioned the car itself feels great.....though I'm not sure if that's because I've been driving it around with <100kws less or if its just the dyno sheet playing funny buggers with my head ;)
Yeah, I notice a difference in hitting "full boost" on the street compared with my dyno sheet.
The way you load it up makes a big difference, well in my case. But I have a turbo that is too big for the engine.
Definitely hear what you're saying, I had an RB30/25 with and XR6T (35/40 - 1.06 e/h) and that was my definition of lag yet that hit full boost around the same as this motor.
Just getting my head around it all I think...and the different types of power and curves....
Edited by mr_rbman
When the car is on the dyno I think its worth paying the tuner as long as it takes to get the camgears right - makes a huge difference on a 26.
I realise this is a completely different turbo set up (GT 3540 on an RB30) but achieved rock solid boost control with a Link, Mac Valve and a Synapse 50mm wastegate:
That's more like what I expected to see Bob, I know my Blitz SBC unit isn't by any stretch top of the line but from what I'd read before purchasing it was a pretty good electronic unit but the boost curve looks more like one controlled by a bleed valve :-/
I have similar mods to you except on an unopened motor, and on an R34
Did a test just now actually.
On my HKS EVC6 at 3900 rpm (or around 96km/h) I get 13.9 psi of boost in 4th Gear. It's an average mild day in Syd - roughly 22 deg and its not crazy humid.
I adjusted the "offset" map feature in all my RPM ranges on my controller and push a tonne more offset than the default 100% as per HKS.
Tune has a massive influence. My last tune with a different tuner was absolutely shite and was a laggy pos with -7's.
Thanks for that input.
Can gears are setup for peak not response. There is 500 to 650rpm in fixing the cam timing.
Status, what settings would you suggest for more midrange/earlier boost?
I did search here before having it tuned and the settings I went with were the general consensus for good midrange?!
^ haha.. that's IP man, most tuners won't give that out :)
but generally advance intake, retard exhaust.. the magically number really needs decent dyno time to overlay the graphs.
Settings can only be determined on the Dyno (or repeated back to back street runs). As always every car is different and a good tune is never cheap if you take the time to do it properly.
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
