Is that not part of the conversation though?
The status of classic that is.
We all probably agree the Z tune is a classic and that rare examples like N1, 400R, etc will hold some value, but it's not like all XYs are worth 150k.
Likewise I don't see ALL GT-R's skyrocketing, and holding, that value.
  • Like 1
On the contrary.
Flow on.
All GTR's will skyrocket in price. Just some more than others.
As for holding value possibly, possibly not. I'd say the rare ones will, but the normal ones will drop off a bit after peaking. But eh. Sell before that happens lol
You'll thank yourself later.
Just get a 33R. And you'll get 50% less wanker factor with purchase.
I'd love an R33 GT-R, I think they look cool (pumped guards FTW), plus Gran Turismo memories. They are also better engineered. But R34 is the dream car, now it's at dream prices sigh.
Anyone wanna swap R32 for R33? lol
Buy nice R31 GTS R, apart from the R32 GTR that would be a nice Skyline to hold on to with the view of making a few bucks in the future, or at least not lose 50% of the cost price.
Much safer bet if you ask me, there may be a demand now hence the inflated prices, what happens in 5 or 10 years, I wouldn't buy a 34 as a investment, yes its the most advanced Skyline GTR but being the most advanced or last model doesn't mean its a worth while investment, a car needs history.
Ask any modern fan boys about their cars, Honda S200, Toyota GT4, Mazda RX7, Subaru 22B, Falcondoore VLXRSS8, every one says their cars will be collectable.
Anyways, keep up the good work.
Disclaimer: I could never keep a car nice enough to be classed as investment quality, some smart bugger once said something like, "Not driving your car is like not sleeping with your girl so she is more desirable to the next guy".
LOL, cars as investments, good luck with that.
  • Like 3
If you can buy a car that is not loosing money , you are way ahead :)
I spent heaps on mine, but it looks and drives the way I want it, worth every cent!
Cars not much use if you do not drive it, BUT I like the idea of being the next guy :)
With respect, I would disagree with some of your statement.
The 34R DOES have history. Not as much as the 32R in terms of racing pedigree, but more so in Pop Culture.
Look at the major brands who have succesfully made an impact in Pop Culture.
Aston Martin and James Bond
Toyota 2000GT in James Bond
Trans Am in Mad Max
Dodge Charge in Dukes of Hazard
Deloreon in Back to the future
AND
R34 from Fast and Furious.
These cars are worth money in part because of Pop Culture. This will add value in years to come.
I'd like to see a mad Holden Bommodore that is globally recognised in Pop Culture. It's only the Aussie/NZ market that really know about them.
  • Like 2
Trans Am in Mad Max
AND
Let him go. Structured reasoning and numbers sometime don't work with some people. :)
Conjecture on the other hand....
A world famous car with only 12,000 ever produced going up in price. Crazy talk. Buy an R31. You'll be a millionaire.
Trans Am in Mad Max
AND
i can 1 up all of those..
AE86.
It's a f**king piece of shit. Look at the prices those things command.
  • Like 2
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
