Pete your entry looks wrong, it says skyline not filthy cheater evo?
Its a good long entry list overall, so hopefully the event will last a few years unlike last time. Some very fast stuff in the supersprint group too...
Ok here are the people I know from VIC on SAU
Lightning Sprint Group B
7    Christopher Thomson    Scottsman    Nissan GTR    FB    VIC
Lightning Sprint Group C
21    Andrew Richmond    Snowman    Porsche Cayman GT4    AA    VIC
79    Matthew Lowth    Matthew Lowth    Lotus Exige    AA    VIC
Thunder Regularity Group A
31    Andrew Collins    acsplit    Nissan R31 Skyline    VIC
93    Craig Ferdinands    13 Crag   Audi RS5    VIC
86    Jonathan Lawson/ John Richardson    Jonathan Lawson/ssrRicho    Subaru V5 GC8    VIC
Thunder Regularity Group D
555    Christopher Starr/ Chris Madden    Christopher Starr    BMW 328i    VIC
On 11/7/2016 at 6:24 AM, Roy said:
I cancelled in disgust. Too many VWs and EVOs and only  one real man in an R31
Well there is Lee in the 260Z, still L engined too, very experienced driver in what would be around the oldest car in the Sprints. Going to get blown away on the straights :)
Edited by 260DET
Last time the event got cancelled by the council due to the event organizers doing naughty things rather than due to a lack of support.
James O'Brien (original 12hr guy and current 6hr guy) is running this so I think it will remain strong. This year there was a clash with 12hr cars and the trip to NZ for the Highland 101 so I expect next year you'll see a LOT more 12hr cars etc at the event and it will be a real testing showcase. Hopefully we can still get sprint spots in road cars. I'm hoping to crack under the 2:30 mark in the mini croc. Have now gone over 1s faster at PI than I have in the EMO and I was oh so close in that at Easter this year.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
    • Well the articals keep saying a Q50s (Skyline in Japan) with a new Manual gearbox. I like the talk about the new looks with the round tail lights. I hope they bring back the retro look like they did with the Z
