Good morning everyone.
I am about to embark on a build to make 450awkw. The car is a 1990 gtr.
The mod List so far:
Power fc D-Jetro
800cc Sard Injectors
Trust Drag intercooler
Custom intake piping
Custom Exhaust
A/M Turbos (Searching by the serial number they came up as a "Le-Mans" turbo 330-350hp each)
twin plate clutch
Hicas Gone
350awhp
The car developed a leak in the headgascket. it was still drivable but due to various family reasons, it has been garaged for about 4 years. I am now in the position to give it a lease on life and if after the build it sparks a fire under my ass, I will keep building it. if it doesn't then it should be very easy to sell once finished.
the plan:
2.8L stroker (want to keep the 86.5mm bore for strength reasons and leaning towards the Spool kit.)
270ish by 10.5ish cams on both sides
low mount roller bearinbg turbos
cure for the oil issues via a bigger sump
and if the gear box goes, an os 5 speed rebuild.
The question:
With so many strokers out there, is it really worth while spending the money on a top of the range kit or will a $5-$6k kit be ok for my power needs?
will my 800cc injectors be up to the task?
will low mount turbos (want to stay low mount for police reasons) able to deliver the flow needed for 450awkw?
I tried to search some reviews or comparisons on stroker kits and it seems that in general there really isnt a bad one. As with any build, I dont really want to spend the money on a kit that is rated for 1500hp if I dont need to.
Thank you in advance for all and any advice
https://www.sau.com.au/forums/topic/464074-rb28-build/
Why such long duration cams? no real benefit.
A GTX3582 in twin scroll, twin gates will be a good choice with fantastic response on a stroker.
It seems that around that duration I will get even better mid range torque and response. As for the torbos, I was really hoping to have something that bolts on to std manifolds Edited by khezz
https://www.sau.com.au/forums/topic/464074-rb28-build/#findComment-7707576
You mean you'll get more lag and shift the mid range higher up the RPM..
Longer duration cams are not the answer to getting better response or making better mid range.. Yes you will make more torque yes you'll make more power but not where you want it.. and that's nice and early.
https://www.sau.com.au/forums/topic/464074-rb28-build/#findComment-7707588
Something we can agree on, Unigroup Engineering do a 260x10.85mm custom cams, I have just fitted a pair of these and they are a good peice of gear
GTX2863Rs cores can be fitted to your Nismo turbos, are a good match for a 2.8 and will easy make north of 450rwkw with the right supporting mods providing they are the .60 front covers
800cc injector may cover you on 98 but not on E85 and with the SS injectors available I would and did go that way, ID1300s
https://www.sau.com.au/forums/topic/464074-rb28-build/#findComment-7707591
I am happy to stay with 98ron fuel. E85 is still not that readily available in Perth. So for cams stay 10.5 lift or more but keep duration under 270. Got it.
Is there an I tank pump that will give me enough flow? Has a Bosch in tank now but I know it won't cut it.
Wow. Thanks for all the info.
What about my choice of stroker kit? Spool ok?
https://www.sau.com.au/forums/topic/464074-rb28-build/#findComment-7707613
Walbro 450L F9000267 by TI Automotive will do it.. just need to wire it up to at least a 30amp relay and at 25amp fuse on some decent wiring.
get 260 degree cams (there abouts) like the other boys....
yes big duration cams go brap brap brap brap at the lights.. but when you get flogged by a Golf GTI it's embarrassing .
https://www.sau.com.au/forums/topic/464074-rb28-build/#findComment-7707620
You will get reversion through the exhaust with the overlap too...
https://www.sau.com.au/forums/topic/464074-rb28-build/#findComment-7707654
I would rather go for a pair of new turbos. In my limited experience old turbos are just that, old turbos. What ever happened to the t517z and t618z turbos?
https://www.sau.com.au/forums/topic/464074-rb28-build/#findComment-7707678
New turbos (from Full-Race Geoff):
- when a tall RB30 block is used, I suggest twin EFR6758 (or twin EFR7163 depending on fuel and boost target). The twin EFR setups are not for everyone - there is more piping/lines/two turbos ... twin EFRs fit better than a large single in these cars - and for a responsive 750hp there is nothing that can touch this. We make the downpipes and charge pipe so this is a bolton affair to replace the existing -5s
nissan-rb26dett-efr-twin-turbo-kit-1-con
  • Like 1
https://www.sau.com.au/forums/topic/464074-rb28-build/#findComment-7707685
they're junk, pieces of shit.. even a single one on a SR20 (which I mainly play with) are horse shit.. make crap all power and lag.
https://www.sau.com.au/forums/topic/464074-rb28-build/#findComment-7707690
the best, read all you twin fan boys:
https://www.turbobygarrett.com/turbobygarrett/differences_between_turbos
Quote (also the best): "In most cases, for top performance, a single turbo is preferable because larger turbos are generally more efficient than smaller turbos. However, often there is not room for one large single, or the tuner wants the visual impact of twin turbos."
  • Like 2
https://www.sau.com.au/forums/topic/464074-rb28-build/#findComment-7707694
    • Waaay ahead of ya....(evil laugh!!) Will show the fitment and spec details later when it isnt as rainy !
    • Thanks Dose.....    I appreciate it!!
    • I'll probably be putting the shit box back on the dyno again soon, I want to dial in the closed loop boost control properly. I'll have a camera facing the car/motor for fun too. Just note, there are essentially 3x 10AN inlets going into the catch can and 1x going back to the intake pipe. Most of the time the catch can "return" to the sump actually is the crank case breather, pushing air out.
    • I have the R3C with a Nismo slave and by no means does it behave like a stocker, it ain’t THAT bad. On take off just give a bit more throttle than you would say a coppermix and it’s fine. It will not slip though.
    • Okay. Final round of testing done. Got a friend to hook up a fancy scanner to the car and we also ran some compression and leakdown tests, she is healthy.  The MAF was definitely the culprit. So for future reference anyone with similar issues that find this thread. I suggest the following steps, in order of affordability:   Check your spark plugs for any fouling, replace plugs if they are bad or re adjust the gaps making it narrower (0.8mm would be good). Check every coil's resistance with a multimeter. It can be done by probing the IB and G pins on the coil pack. Resistance should be around 1.4 (+/- 0.1) Ohms Check the MAF. If you have Nissan connect or a good scanner with the 14 adapter it should allow you to see the voltage on the MAF reading should be around 1.1 - 1.2V when car is idling. But if you don't, buy a new MAF from Amazon and test, then return it. (For instance, I got a Chinese one for $40 that was reporting 1.3v on idle). If you still have scanner, you can run tests on the injectors to see if they are working, just remember to unplug the fuel pump fuse/relay and have no pressure on the line. Then listen for the noises that the injectors make. Clean/replace injectors as needed. Once you find the issue and fix, order thousands of dollars worth of OEM parts to refresh unrelated things (Optional)   PS: Thanks to the absolute legends of this forum for the responses and help to someone that went a bit over their head. (me)
