Small update,
Extinguisher and bracket fitted under drivers seat. Pretty straight forward really!
New window retainers fitted..
And thought I'd treat myself to a brand new KL0 badge!
11 hours ago, okooko said:
Nice badge. I still haven't put on my new set of KLO GTR badge and Nissan boot badge.
Have you got a pic with the ganadors on?
I'm still buffing/polishing the Ganadors, so I should have them on this weekend if all goes well.
1 hour ago, Clintox said:
Where did you get the window retainers from? ive only seen them for like $13-1400.00!
http://www.kudosmotorsports.com/catalog/weatherstrip-retainer-upper-window-nissan-skyline-gts25-door-coupe-p-1840.html
http://www.kudosmotorsports.com/catalog/weatherstrip-retainer-upper-window-nissan-skyline-gts25-door-coupe-p-1839.html
3 hours ago, Marko R1 said:
I can't believe the price of those weatherstrips...the 32 is becoming the equivalent of an old school aussie muscle car in terms of parts & price
In Japan they are going for $1k per side.
  • Like 1
Now I have a pic with the ganadors on!
Only thing remaining to set it off is a good set of wheels.. Soon!
7 hours ago, okooko said:
Awesome! I managed to pick up some as well in CF last week.
What boss kit is that?
And what rims are you thinking? Omori LMGT4's? haha
Cheers bud! Can't go wrong with Ganadors lol
Works Bell boss kit...
Too many people have LMGT4's but I need something that will fit R35 Brembos
  • 1 month later...
Haven't updated in a while so here's a few more additions to the inventory that have occurred in the past month..
I had the front half of my car wrapped with clear stone guard protection from Ozicozi.. No point taking photos as you can't tell it's on the car!! But it's an amazing job and will serve it's purpose on the road/track and save me from repainting panels in the future.
SARD Fuel rail
Also picked up an R33 GTR Powersteering pump for when I get the hicas removed, no photo for this.
SPOON Rigid Collars for the rear,
I had these fitted in recent days (did not get an alignment, this will be done when all the new arms are fitted) and I can say I'm extremely happy with the result.. A few problems have been fixed by fitting these including backlash from the rear subframe.
I will be getting the front set in the near future to have everything 110% straight.
Ikeya Formula Front Camber Arms -10mm version which I believe will allow about 3 degrees negative camber..
And finally, I have been looking for this for the past couple of years and never found one for sale.. So when this popped up on yahoo japan I had to have it without question..
ARC 100mm Titanium Exhaust, 130mm tip !!
  • Like 3
Nice one, did these fix your issue with the wheels poking out 3-4mm to the left?
They have helped move it back about 2-3mm to the middle now but I just need to get a wheel alignment for it to be 100%
  • Like 1
3 hours ago, willL said:
Mate, that freshen up of your front and rear seats looks great.
Do you know what was done to achieve it or who did it in Japan?....looks like they were dyed to bring back factory colour?
Hey Will,
It was done while the car was still in Japan by Garage Yoshida..
I'm not sure on the exact process, I think it is a dye of some kind but the seats feel completely normal and there is no sign of the colour fading. All in all, i'm extremely happy that I had it done!
http://garage-yoshida.net/process_seat.html
Edited by GRKGTR
9 minutes ago, GRKGTR said:
Hey Will,
Ahh thought it would be Yoshida, was literally on their site yesterday.
Thanks!
Edited by willL
  • Like 1
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
