just wondering which transmissions are a good swap option?
i have been hearing about using the trans from a 350/370z as well as the 5 speed swap and the getrag swap.
all im looking for is to change from my auto trans to a manual.
what do you guys have for options if they are not listed here?
https://www.sau.com.au/forums/topic/464843-manual-swap-options/
those Series 2 350Z boxes, aka CD009 will happily hold 1000hp (or 700hp AU numbers, 30% yanky inflation).
Chris Forsberg's twin turbo 370Z uses the stock box (essentially a CD009).. makes silly power and gets drifted off it's tits.
Cheaper than the likes of OS Giken, PPG, PAR, etc...
The cost of those mentioned gearsets will be a brand new box delivered to your doorstep.
There are a few kits to slap them to SRs however nothing noted down for RBs
The problem with the 5 speed swap is the transmission is getting hard to get a hold of in and around Canada because all the 240's the s14/15 and Silvia guys are converting their cars to the 5 speeds from the r cars because it's a better trans
And I would prefer something in a 6 speed setup as I do lots of highway driving
Edited by taz2069
If it were me looking for highway gearing I'd be putting some 3.7 gears in the diff. Would work well with the 5 speed.
The other thing people are doing to get 5 speeds is getting the (apparently) same gearbox from D22 Navaras and swapping the bellhousing half of their old/worn out RB25 box.
Putting VQ gearboxes behind RBs has been thought through, but like Johnny above, I'm not aware of too many that have been done.
there's this:
http://collinsadapters.com/index.php/rb26dett-rb25det-ka24de-to-350z-350zhr-370zransmission-adapter-plate.html
but no one I know has used it b4.. in theory seems easy enough, however theory usually always translate to real-world.
You are going to have to change diff ratios as well if you want to match or drop the revs you are doing now on the highway. The auto box has a 0.694 4th gear ratio, the 350/370z has a 0.794 6th gear ratio and the RB25det has a 0.752 5th gear ratio.
Cheapest option (if you don't want a second hand gearbox) is buy a brand new 5 speed and change the diff ratios.
Another option is a Tremec T56 and adaptor plate
there's this:
Missed the never part lol
Is there 14mm of meat that can be safely taken off the bellhousing without trashing the strength of it?
Just found this
http://alphaomegaracing.com/i/15/Z33-Z34-6-Speed-Gearbox-Conversion-Part-1-Adaption.html
http://alphaomegaracing.com/i/16/Z33-Z34-Gearbox-Conversion-Part-2.html
http://alphaomegaracing.com/i/18/Z33-Z34-6-Speed-Gearbox-Conversion-Part-3-Finale.html
Alpha omega wouldn't machine more than 9mm off the bellhousing.
Toyota have a 6 speed Getrag - maybe someone in the States makes an adapter plate - and get an R34 GTR diff (3.545:1)
Just had a look on TradeMe and used RB25 boxes are $2k - $2500!
Have you checked to see if you can buy them brand new from Japan?
There are a couple of threads on this site with instructions and a parts list for the manual conversion - the centre console may be hard to come by as well.
the toyota 6 speed getrag is just to expensive for just a swap as its around $8000us. for the build i plan on doing down the road it will be perfect,
and by the time i import the used 5 speed box it will be around the 4-5k, im looking for something i can use without costing crazy money until i do my build.
Edited by taz2069
    • Nope.    Grab a varex and turn it down as you get close to home, win win?
    • So, I've had my V36 for about a month now and have already copped an "excessive exhaust noise" notification from QLD TMR, reported by someone in my local area. It's a twin as per the original, and can have a bit of a throaty note to it when idling cold 😄 and if I do get up it a bit, it can be noisy, but it did pass a roadworthy inspection before sale, so.... ... but in the interest of being a good neighbour, I do want to quieten it down a bit. Is anyone here running a quiet aftermarket cat-back on their V36 or 370Z? And the big, bold question: does an aftermarket cat-back really make much of a performance difference on these cars?
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
