Hello every one!
I recently bought a skyline gts-t rb25, and I need to replace the clutch because it is slipping. I have been trying to research but cannot decide what would be best for my needs.
I will only be driving on the road, and not track, and the car is not highly modded. I understand a puck or ceramic button type would not be suitable for this.
Therefore I would not like something with an extreme clamp pressure? what is the stock clutches clamp pressure ? what is high ? what is low ? is this the only thing that effects stiffness of the pedal?
Is it worth getting a "heavy duty" clutch? or will this be too stiff or cause unnecessary wear and tear ?
what is meant by stage, 1, 2 ,3 and 4 clutches ?
what are the pros/cons between single and multiple plate clutches? are they equal in difficulty to install ?
Also finally, I would like to ask, if the clutch has been slipping, how likely it is the flywheel may be damaged and need replacing?? (I know you can get it machined, I just mean cracked or scorched or whatever.)
I whole heartedly thank anyone who can help me with advice, or perhaps link me to some already on the internet.
xoxo
https://www.sau.com.au/forums/topic/465109-which-clutch-to-buy/
Same clutch here. Glad to know yours is holding up fine at that level, hoping to nudge 350kw when I install my 30DET.
Same here. 4 years on NPC 10" single plate carbotic. 2 years on 300kw 25. 2 years on 340kw 25/30 and has done 6/7 drift days and thousands of street km.
have done the cheeky 2nd gear clutch dump stationary too :)
I have done more than my fair share of that too haha. Have dropped third on the spot with shitty old 215's as well haha. Decided I should cut that out because I really do like my gearbox
haha 2nd and 3rd are being being too gentle I do 4th stationary limiter drops nismo twin and box still live on haha
  • Like 1
Exedy Cushion Button :yes:
No
Mine failed after about 8 months with 250rwkw
NPC is much better. Never ever had a drama. Got it rebuilt when I put my new engine in but that was only to extend the life. Still looked great after 3 years
    • That sounds like an excellent idea. But total self-sufficiency means exactly that. You have no-one else to blame when your system faults out and you have no power for a week or two while it gets fixed. You'd have to go the whole hog and get a diesel genny and all the switchover gear, to get you through such times. And, despite the fact that over 20 years, my system has been pretty reliable**, I have seen so many inverter explosions (or less dramatic deaths), panel and roof JB fires, and so on, over that time, to know that the stuff is the same as any other bulk Chinese manufactured stuff. The failure rate is well above zero - both on the equipment and on behalf of the meth addled installation labour force. And then..... warranty and means of redress against the supplier you bought the gear from. Best I can tell is that only a handful of solar companies are still around within 5 years of starting their advertising pitch. They disappear and phoenix like crazy. So, as per 1st paragraph, I suspect the only way to is go balls deep and spend maybe 2-3 times as much as you might think, so that you have every base covered. Plus, know and understand your gear intimately, so you can diagnose problems, sort them out yourself, etc, etc. Plus, probably have to consider upgrading various parts as the years pass, to maintain compatibility with newer stuff, performance and reliability, etc, etc. Whereas, remaining attached to the grid has an ongoing cost that keeps going up even if you use bugger all power from it. But it does provide the fallback in case of the worst case with your own gear. You either pay up front or as you go, I suspect.
    • Add more solar panels to the array. Call the electricity company and tell them you're moving out... Live off grid electric wise
    • Hi Jasmine. How's the war going?
    • I'm extremely suspicious of the VPP stuff. Best I can tell, you surrender any and all control of your panels and battery to the VPP, because there's no way that anyone could write a sufficiently useful set of "rules" as to how much you would be willing to let out of your export meter at any given time. If one of your main interests is to have enough in your battery every evening to get you through the night without having to import, you could easily find yourself with nothing in your battery at the end of the day, or part way through the night, and then be paying import pricing instead of paying nothing. I cannot see how this cannot come to pass.
    • majority aftermarket is an10 yes, but majority of OEM is An12 r35 OEM cooler lines at close to an 12, the hard line that car uses is almost 20mm  Porsche OEM is also AN12   i figure, if our power levels are close to 1000hp, then AN12 should be a must if many OEM standard power vehicles use AN12
