11 hours ago, PranK said:
Blah. New app versions are shit. I'm working with them to fix the problems, just need some patience atm sorry guys.
Yeah, I'm sure it will be worth the wait :)
I have just removed the app and reinstalled on Android and I'm posting this from it. I made some changes to server config which I think may have helped.
Confirming my Android app does the same thing. Works fine once upon reinstallation then when you close and open again it does not let me login even with my correct details being entered. I have downloaded tapatalk for the time being.
1 hour ago, luke gtr said:
Got a new phone, and no longer having the issues.
*note, didn't get a phone specifically to fix issues.
Haha! Thats dedication!
What phone is it?
17 minutes ago, niZmO_Man said:
Use imgur
Or our gallery. :thumbsup::)
Tapatalk are still working on the app issues. I'm sorry guys. Hopefully not much longer. :(
  • 3 weeks later...
Ok, found to attach images on the app, must use the 'plus box then select "attachment" rather than image.
Haven't had any other problems so far.
I thought that too but then discovered app has a mind of its own and wont let you attach images whenever it feels like it.
  • 1 month later...
I see some ppl have their donation, member and moderator info back.....is this still rolling out or did some miss out?
As far as I know - paid 3 or 5 years worth I thought, will have to ask - I am a NSW member, have donated, and also paid the membership to this forum - and got the merchandise pack :).
So I would expect something to appear?  But nothing so far.
Hmmm, seems the donated icon is missing (i should have one too).
The NSW membership icons are managed by NSW club.
Consider me investigating.
  • 2 months later...
Since the mobile app upgraded, I have noticed that a lot of advertising is now displayed. Is this to be expected@Prank?
Also, the Notifications view / function is still not working.
Cheers
Rob
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
    • You don't have an R34 service manual for the body do you? Have found plenty for the engine and drivetrain but nothing else
    • If they can dyno them, get them dyno'd, make sure they're not leaking, and if they look okay on the dyno and are performing relatively well, put them in the car.   If they're leaking oil etc, and you feel so inclined, open them up yourself and see what you can do to fix it. The main thing you're trying to do is replace the parts that perish, like seals. You're not attempting to change the valving. You might even be able to find somewhere that has the Tein parts/rebuild kit if you dig hard.
    • Can you also make sure the invoices on the box (And none exist in the boxes) are below our import duty limits... I jest, there's nothing I need to actually purchase and order in. (Unless you can find me a rear diff carrier, brand new, for stupidly cheap, that is for a Toyota Landcruiser, HZJ105R GXL, 2000 year model...)
