Now that just sucks - doubly so. You can't fight them on fuel quality. I once went through 20L in 25km. Car was billowing black smoke the whole time. It was clearly poor fuel in the stock auto GTS25t and it compensated by going mega rich and using as much as it needed to protect the engine.
The bolts are definitely a no-no to re-use.
Rebuilding my engine last time I was torqueing them up and one kept turning a bit too far, then bang. It was nowhere near first torque and had failed. I measured the rest and found some were a fair bit longer than the others so got new ones from Nissan.
So is the builder springing for the new work or was it your decision to use the old bolts?
Initially he was going to get me to spring for it - act of god he called it.
Thing was - it was his decision to re-use. Could have turned out nasty, but he has come good and is paying for the new block, all labour and all machining. As it turns out there is a fair bit salvagable from the blow up. I am paying for 3 new pistons, bearing and gaskets and of course bolts. Not too bad considering - just pissed off that I have to go through the whole bedding process again. Haven't been on the track now for nearly 4 months. <_<
  • 1 month later...
i got a qestion need answering iv got a mate with a R31 that f*king boots his turbo is at 15 PSI n he wants to turn it up 2 17 u rekon thats a smart move or not?
Need more info on the engine mate, what motor? what turbo? kms? condition? blow smoke? rattles? leaks?
how longs a piece of string?
Another one to add to the pile.
R33 GTST 95 mod.
Unichip
Intercooler
GCG hi-flow
Finer filter panel
Full exhaust & split dump
Bosch pump & sard regulator
215rwkw
very happy !
Unfortunately this is where it all goes wrong.Developed a small hiccup at 2,000rpm then 2,500 and took it to biggest most expensive u-beaut tuner in sydney.On the dyno and he says crank angle sensor gone.Removes unichip and cas is fine.So must be unichip.
Couple of days later same hiccup.Then it is fine.Then really bad.Back to dyno.He says must be cas.So I had one ready and away we go.Car drives great.Couple of days and no power below boost but goes good on boost.At this time I decide to install pfc and hi-flo injectors.Hope pfc will fix problem.225rwkw and running great.Before I get home notice lack of power below boost and slight hiccup.Take it to Advan who kindly run it up on the dyno then street test and we confirm timingis rooted.Back to original tuner and dynoed.Tickles pfc and says it`s fine.Go to start it and won`t start.
Timing belt has let go when I turned it over to get off the dyno.All the trouble I had been having was in fact the belt which had lost 30% of it`s teeth.Belt had done 30,000km`s but looked like 200,000.Cheap belt from f#@%$wits are us.Cheap-skate so called engineer who`s favourite colour is green possibly damaged it when installing.
  • 4 weeks later...
Engine/Car: r33 series1 rb25det
Type of failure: Number 5 piston letting go and destroying block and crank and deep grooves in head. Oil pump failure. Dads a mechanic he told me it was probably a sticky valve making noise, should have checked oil pressure. Noise was piston hitting head!
Factors influencing the failure: Warm weather, Oil pump, Motor had a couple of dodgy coil packs leaning out and detonating. Poor maintanece really. Learnt that mistake
State of tune of the engine: FMIC, cat back 3.14, hks pod, n1 water pump,
Suspension and tyres: kyb struts, jap springs of some sort, pinaples, control arm bushings. 235 45 17 pottenza reo 40
Oil used and service interval: Good sythetic oil cant remember, Serviced approx 3000km before this
General comments: Very inconvenient time for this to happen. Has made me slightly wary of rb25det now. Had a sylvia before this gave it hell still going strong! I want a head up display oil pres now!
we could barely make out mitsubishi stamp.The rubber had completely fallen apart.
Have a mitsubishi belt on mine at the moment, just gone 20,000kms old and it looks like rat shit... must be a common problem.
Got a brand new HKS one sitting in is box waiting to go on.
Engine/Car: r33 rb25det
Type of failure: broken ring on #6 piston.
Factors influencing the failure: had the car tuned on 12psi (safc2), while at the drags the dodgy bleed valve spiked to 18psi and actually held it there during my burnout. it was smoking all the way down the line.
State of tune of the engine: 3" turbo back, fmic, pod, safc
Suspension and tyres: stock
Oil used and service interval: nulon synthetic.
General comments: DO NOT USE A BLEED VALVE. THEY SUCK.
  • 5 weeks later...
Me again
Engine/Car: R33 GTR
Type of failure: Spun bearings due to suspected oil surge. <_<
Factors influencing the failure: 2nd lap of a track day. Fairly warm day.
State of tune of the engine: approx 700bhp (fly)
Suspension and tyres: Ohlins / Eibach running Dunlop D02g's
Oil used and service interval: Motul Race Oil - changed after every track session.
General comments: After last rebuild used Tomei sump baffle kit, cam cover baffles, gallery restrictor and Accusump. Obviously not enough. Currently having the sump modified by Performance Metalcraft. Hopefully this should do the trick :P
  • 3 weeks later...
R32 GTS4 - RB20det
Type of Failure: Spun bearing - oil surge
Factors influencing failure: A litre down on oil, round a corner 5k revs, third gear full noise, bang
State and tune of engine: 3" cat back, pod filter, ran well for 15yr old
Suspension and tyres: stock suspension, new 16" rubber
Oil used and service interval: Castrol magnetic (daily driver) only serviced it once in the month I owned it b4 it blew...
General Comments: The one time I didnt check the oil b4 going for a drive, and I find out now what they mean by a cheap car isnt cheap if you cant afford to fix it when it goes bang... The replacement engine went in this weekend - what a mission! I have never done a swap b4, but I had a friend who has, it took us 4 days. I have bought some nice synthetic oil now, and looking for a 5" oil pressure guage :)
    • Yeah, hard to find and a pain in the ass to change with the transverse engine. I’ve worked on a GTiR before and it’s not a job I’d ever want to do again. theres a company in South Africa that makes RS3 gearbox adaptors for the AWD SR20 including gearbox mounts, so I could modernise it and go a dual clutch with paddles. For now tho, it ticks all the boxes. Super cheap, can throw the kids and their junk in the back, and SR20 that I can turbo cheaply, a CVT that’s not a dog’s breakfast like the V35, and has 80% interchangeable parts with stuff I can source from the wreckers cheaply…. But it’s still unique. I love the wagon back of the Autech version. It’s cheap enough that I can buy another stock manual FWD Primera with SR20VE, swap the gearbox to the N15 pulsar short gear ratio box, swap out the brakes to the R32 ones I pulled off my 32, register it on club plates and take it racing. $1300 shipping from NZ. Heaps of parts and aftermarket builders for transverse SR20’s in NZ.
    • Hard to say, just pop the rocker covers off and have a look if you think it's cammed. You probably need to replace the valve cover gasket/half moons anyways.
    • From my youth: GTi-R clutch change is a massive pain. The gearboxes are fragile? But the car is super cool and I want one 😢
    • Remember this is 1988 tech.
    • Driveline vibration is resolved. I ended up loosening all my engine mount and trans mount bolts, giving it a good shake then retightening everything and it's gone... Let's just say I was surprised that fixed it.  I've been happily driving it around again but unfortunately put zero time into my direct port/constant pressure WMI setup. I'm on vacation next week, so I'll try and finalize it then.  On a different note, I spent all week fuel/ignition mapping 2x 216L V16 engines. Turbo's were burning glycol and we swapped them out for larger units. We also had planned emissions testing on site, so I figured I'd be there the same week to use their instrumentation and massage any emissions issues out if needed. This was a first for me. Fuel management is similar in certain ways to automotive (i.e air density as load variable) but very different in others. It's all PLC based and AFR's are controlled by air and not fuel. They use a control valve between the turbo and air manifold to control pressure which in turn controls AFR's. Due to this, target AFR tables supplied by the OEM are in pressures and not mass which really through me off. They use air pressure vs fuel pressure tables. I also relied on an O2 concentration sensor the emissions team had in the exhaust. Ignition timing was also all over the place and we were losing a fair bit of power. They're now happily sitting at 16-40BTDC depending on load. We were making about 1600kw at 900rpm at 90% load. Engines were running a lot smoother as well.
