Engine/Car:1990 GTR
Type of failure:
1 tensioner bearing @110,000KM's
Factors influencing the failure:
bearing rusted out and I didn't think anything of the "red dust" on the plug coils.
State of tune of the engine:
Mines ECU,splitfire coils,HKS pods,stock boost,new NGK (6) plugs gapped .9mm,trust downpipe,jasma 3",hks bov's.
Suspension and tyres:
255/35/18 bridestone Advan SA3's
Oil used and service interval:
Motul 300v 10/40 First oil change since I got the car
General comments:
I live in Canada and just had the car imported from Japan and only put 1,800 KM's on the engine.The engine started making a rattling noise in the top.Next day it stops running while sitting at a stop light and no more compression.The tensioner bearing no longer exists sooo all the intake valves are bent.The entire bottom end is fine though.I pulled the engine and the head needs a rebuild and the stock turbo's are done as well.It was cheaper for me to buy a factory long block from Japan than it was to rebuild it with some upgraded parts.I have been waiting for almost two months for the engine so hopefully it arrives soon.DSCN0400.jpg
This has happened a little too often for comfort Jason and a pity it is too on such a nice car.
For all those following this thread the cost of a set of bearings is just $130AUD they are a worthy replacement item at 100,000km service. Takes around 2 hours to replace them and the timing belt if the front balancer comes off easily enough. The balancer can be a real pig though.
I recently saw a car also have the bolt break through the adjuster bearing. It was a cheap grade 6 bolt and not grade 8 high tensile so it's also worth grabbing a couple of those to throw in as well to be a little more secure. The damage caused is as bad as not running oil but so easy to avoid (not that this prophetic statement is of any help to Jase).
Goog luck on the rebuild and let me know if you need help sourcing parts.
You guys chould get a sick vh commodore like me.
I just blew my motor up reving it up riding the clutch. My dad is a tow truck driver and he wreckens that we can get one for a carton of piss from his mate at the wreckers or we can pinch one out of car with his tow truck
commys are sick as and i blow the doors of gtb's and r39's all day long
Engine/Car: 94 R32 GTR
Type of failure: spun bearing, possiably killed oil pump.
Factors influencing the failure: possiably bad tune, oil pump dieing, no rev limiter and possiably cooking the oil (bad oil).
State of tune of the engine: Remapped ecu, Trust T517z turbos, tomie poncams, full trust exauhst from turbos back, bosch 040 pump, adj timming gears, tomie valve springs with retainer made 255rwkw on 14psi and tuned to 95 octane.
Suspension and tyres: HKS hypermax coil overs, R33 GTR rims 235/40/17
Oil used and service interval: had some sort of penzoil serviced only 1000km before.
General comments: Car had only recieved major mods about 1000km before hand, so tunning wasnt exact, pushed it over 220kmh and over 9000rpm a couple of times and had no oil cooler. when the oil came out it actually smelt like it had burnt and oil pressure gauge never really seemed wright either. always up and down below 4. some say the senders are faulty but i feel it was the actuall pump.
Car: 1990 HR32 GTS4
Engine: RB20DET
Type of Failiure: Conrod bearings starved of oil (No. 6 and No. 3 the worst)
Factors influencing the Failiure: OIL PUMP. It was found that when the engine was pulled from the car,
an inspection of the retaining screws (the philips head countersunk screws)
that are on the back side of the oil pump
had worked their way loose. One was completely unscrewed and the only
way it didn't come right out was because the carnkshaft girdle was in the
way. (passenger side closest to the crank). We have read all the posts about
the standard oil pressure gauge being inaccurate, always reading lower than
actual, never over 4 bar, so we kind of beleived this to be true. NO.
Because these screws were loose, oil pressure would hold until it pushed
past the seal to the rotors, die off and build up again, and so on.
State of Tune of the engine: 12000Km engine previously developed 176 AWKW on 15 pound boost with RX7
550cc, a high flowed ATP internal gated turbo, massive dump and 3" exhaust
system with HKS stainless low mount exhaust manifold. GTR intercooler and
reworked intake, also a remote oil engine cooler.Since that time, new custom
intake manifold,larger turbo, fully ported cylinder head and a remapped ECU.
Oil used: Only the best.
Suspension: JIC fully adjustable with 16X8 BAD Type M wheels.
General comments: Car had developed a slight knock at around 3000RPM. Would sometimes go away
completely then come back. Countless people tried to figure this out to no real
avail, but at the end of the day it was big end rod bearings on the way out. We
finally found out on the Dyno with DR Drift what the knocking was.
A second backup oil pressur gauge would have been nice to see, but we missed
that oportunity too late. Not a pretty job to fix :
I'll be making dam sure that those screws are locked (Locktite) into position before I
bolt the sump on our race RB20DET.
Cheers,
Glenn.
Engine/Car: R32 GTR 93
Type of failure: Rear turbo wheel exploded under boost. Ceramic fragments are causing knocking sound and very low compression (90psi) in cylinders 4,5,6. Not yet fixed!
Factors influencing the failure: Just picked up car from docks with Apexi AVCR boost controller. Unsure of boost level, was running fine until it was pushed past 5000rpm. Then BANG!
State of tune of the engine: Trust intercooler, Mines ECU, HKS pod filters, full 3" exhaust, Apexi electronic boost controller, Blitz BOV's..
Suspension and tyres: Bilstein suspension. 18x9" Work wheels.
Oil used and service interval: Unsure, but engine oil and coolant were clean.
General comments: Very unfortunate, turbo blew before the chance to dyno tune. Car in very good condition (85,000kms) full Jap service history. I'm guessing boost controller was to blame for high boost (although it only displayed 0.65 bar)..
ANY SUGGESTIONS ON A BUDGET REBUILD OR REPLACEMENT? (CONSIDERING STANDARD NISSAN PARTS WITH UPGRADED TURBOS ONLY...)
HAS ANYONE EXPERIENCED THIS?
ANYONE KNOW WHAT INTERNALS WOULD BE AFFECTED AND WOULD NEED REPLACING/REPAIRING?
Please reply here: http://www.skylinesaustralia.com/forums/in...T&f=10&t=116306
Edited by CRZY32
Pete, that's unfortunate but common enough. My front turbine on the RB25DETT blew at 5 psi limiting me to 25psi comp in 1,2,3.
This thread is not about discussion on engine rebuilds but is for failures so I suggest a search, then maybe start a new thread and link to it from here to direct anyone who wishes to offer advice, just to keep it tidy and on topic.
Turbine you will be pleased to know that you are not the only person that has had an oil pump failure / oil pump cover screws coming undone.
It would be interesting to hear anyone with theories about why, maybe we should loctite those screws.
12,000klm is disgusting from a brand new factory part.
Duncan I am not really that pleased to hear this if it has happened to you to :rant:
Glenn slipped on the Klm's by a 0 so actually 120 Thousand ks on the RB20 :D
I was kicking myself a bit on this one as I was ignoring the Oil Pressure gauge telling me there was something not quite right with it mostly low but sometimes full scale. Just thought it was a faulty sender. Bought a decent gauge but did not connect it just made it look pretty in the mod GTR centre housing :rant:
Looks like a good excuse for an RB25....
Sorry Geoff, will delete this in a few days to keep it tidy.
I'd prefer you leave it Greg. Failures are what we want to know about, and I'm about to commence collation for a document to advise of the most common failures and their root causes.
r32 gtr failure: melted no 6 piston, cracked no 5 piston ring land, no 6 main bearing failed, rear turbo exhaust wheel exploded, no oil psessure, front turbo siezed, most seals blew out caused by excessive crank case pressure from 5 & 6 piston. The cause was : a lazy fuel pump (it ran lean) in 3rd gear up a long hill at about 8000+rpm with 16psi boost, rear turbo failed cause of heat, front was lack of oil or heat? state of tune: was pretty stock, had hks boost controller, hks cams and 3 1/2 cat back exhaust. suspension: is greddy springs and std shocks and std gtr rims. oil used????? only had it 2 days!! (bugger) now mobil 1. general comments:no signs before failure at all, am a mechanic and i checked every thing except fuel flow (pressure was good), i went nuts with the fuel system on new engine and run an exhaust temp gauge. was planning 2 rebuild anyway but not this soon. now runs nearly full hks engine and custom garrett turbos, am very happy with new engine but was pissed off that had car for 2 days and didnt get 2 drive it again for 3 months, it was worth the wait?
Edited by gtr sleeper
gtr sleeper - Chris had my car for 2 days also, now having to do a complete rebuild.
Are you able to PM me with the parts you used for the rebuild? Also any advice you have regarding: piston types, crank, garrett turbos, etc. would be very useful to me as I am currently planning a complete rebuild.
Thanks
Pete
Thanks
Pete
Theres stacks of build up/rebuild threads on these forums already, do a bit of a search, should come up with alot of different options.
Engine/Car: rb25det
Type of failure: idle bearing stud snapped, causing the belt to skip, valves gone yet to pull it fully down
Factors influencing the failure: idle bearing not ceased still spinning freely, the car was cruising at about 60 through a town on the way to heathcote drags, timing belt replaced only 2-3000ks ago
State of tune of the engine: afr's 11.5 with 203rwkw
Suspension and tyres: stock
Oil used and service interval: motul, only serviced twice as as only been in aus for about 8000k's 110000k's on engine
General comments: just really shocked, I have heard of ceased bearings causing dramas but my bearings were fine so who knows. :sweat:
Yeah true but I'm pretty sure the workshop would of done the job properly re tension.
I've been told by other mechanics that you would hear if it was overtension and to be honest the car was running queitly. Infact I was really happy with it so who knows?
My turn :P
Engine/Car: 1990 GTR
Type of failure: Massive pinging and massive blow-by
Factors influencing the failure: Possibly tuning (although its been fine for months) and ring/s worn out are the most logical
State of tune of the engine: 11:1 AFR's throughout rev range. 260rwkw. OEM turbos at 15psi. Full exhaust. Microtech ECU. ARC airbox etc
Suspension and tyres: Tein suspension, 18x9.5inch rims with 235/40/18 cheapo tyres
Oil used and service interval: was Motul 10w40 turbolight for most of its life until recently i started with Penrite 5w60
General comments: I had overfilled the oil up to the bottom of the dipstick hump after a series of mates wrecked their motors from oil starvation. Only found the blow by problem at Oran Park on a drive day which was a great way to waste money, and wreck a fun day out. It would pop the dipstick out after a lap or 2 flat out, i assume this was caused by the high sustained boost compared to street driving. I will see later today with the hand controller for the ECU how the AFR's are at the moment.
It will be rebuilt with the Mines spec2 motor specs downloaded from their site.
Edit, here's the culprit
    • Just wanted to pop in an update on my setup. The CD swap has been great, I love the mazworks housing for the overall simplicity. I ended up sealing my trans tunnel with a thin sheet of aluminum reused some of the holes on the trans tunnel, and laid some window sealing EPS foam around the edges. Works great, really quieted things down and sealed up the car.  As for the power comment. Right now I am also running about 650whp. with the way the bell housing is attached to the face of the transmission I have zero doubts it would be fine, mainly because the input shaft and main shaft bearings are seated into the bell housing adapter. This means the load is NOT on the bolts to maintain the power, rather into he casing of the bell housing; Yes the bolts are doing some work there, but with both shafts locked in zero worries.  End of the day, the Mazworks solution is the easiest and safest. no need to take your trans to a shop to get milled perfectly, it fits with minimal clearancing, and you can use all your existing clutch and flywheel.  Driving wise the CD has been great compared to the big box, I'll probably swap my final drive at some point. The serial 9 shifter is gooooood, my only qualm is how tight it is, it takes a fair bit to get use to, 5th and 6th are a bit eh/hard to find at times, but maybe I need re-adjusting, and I think my clutch master is very tired and needs a rebuild.
    • If you are keen, have a look at my build thread. Car is for sale for the right money or straight swap for a F80 M3 LCI.
    • Welcome mate.  No point in over thinking it, buying any one of those cars you mentioned is not a smart or logical choice with the availability of many "better" (re price to performance) cars available to you.  The heart wants what the heart wants, buy whatever it leads you too.
    • Hey everyone! Im so grateful to be apart of this community and ill do my best to be apart of this. Firstly, i'm not disclosing my real name due to in real life circumstances surrounding my privacy and public image (sorry lol) Secondly, The only thing personal I am willing to share is that I'm from Sydney and a descendant of one of Sydneys largest mortgage firms. I got gifted my first ever car, a 2022 Porsche Cayenne and I love it to death. Ive been driving it for about 5 or 6 months now and honestly Im so grateful for my parents for gifting me this vehicle. However recently I've been working my ass off to afford my second car (which I need help deciding soooooo community help me out please?). Once decided, im planning to try modify it myself. Recent I've been thinking about getting a Skyline, particularly a 25GT or GT-V, yes I know overrated as hell, but I'm also considering a Chaser which I recently came to love. However my dream is to one day own a 180SX (So hard to find clean versions and im not really into importing).  Lastly before I send this off, I want to apologize if I sound tacky or pretentious. I try not to and want to genuinely learn from everyone and anyone. (Im no expert in this area) Thanks for reading!
    • I've got three stashed away but it's starting to get silly with the prices
