Shockworks Presents Round 9 - Sandown Raceway 1st Oct | Grand Final Day
Hey guys I have fixed the track day requirements link for anyone not sure what is required for a car and driver to attend.
http://www.sau.com.au/forums/topic/453779-track-day-requirements/
  • Like 1
Cams Manual Schedule D - Apparel
http://docs.cams.com.au/Manual/GeneralRequirements/GQ05-Schedule-D-2016-1.pdf
We're "Race" / "Multi Club"... So Helmet level is "B"...
In the table it seems to list "E22 (with 03, 04 or 05 amendments)" which looks like your helmet. But don't quote me on that, that table is confusing as hell.
  • Like 1
Ha ha yeah thanks for that@Odium i found that table super confusing too ! Just strange you dont need a as/nzs sticker on a road approved helmet
Sorry was busy earlier could not reply in length.
the ECE is accepted by vic roads as well now so it's not just CAMS that are accepting it.
so Snell, ECE, AS and BS we accept.
  • Like 1
Thanks Martin :)
Yep in my search for the answer I came across an article saying that they were road legal in Victoria since mid 2015, but still illegal if you travel to certain other states on your motorbike (ridiculous considering that you can be considered "Safe" in a $75 helmet, but not in a $750 helmet)
Thanks for the clarification
Hello :-)
I just bought a fire extinguisher, its a 1kg cams approved, the date on the neck is 03 2016. The lovely man at the shop assured me that it was the make date i just want to confirm. Is it valid 3yrs from that date? Im having trouble getting my head around whats an expiry date/make date. Any help would be appreciated. Tegan
that is correct 3 years from the date stamped on the bottle.
so good till march 2019
make sure it is bolted in, no cable ties/tech screws and such.
M
19 minutes ago, fdrx7 said:
Hello :-)
Yes that is correct. 3 years from manufacture date
Unless it specifically says "Expiry Date" then consider it a Manufacture date, as different uses have different time spans (for the same equipment)... Stupid I know.
  • Like 2
On 9/26/2016 at 10:35 PM, acsplit said:
I was just about to post this, yep contact brendan during office hours garage $50 can fit two cars
Damn that's cheap, PI was like 4 times that
    • That was the first session so not a lot to take from the day. It was low 20s ambient and the coolant had got to 110 (and obviously had some pressure!) so that still needs to be addressed. I haven't downloaded the data yet but will. I had refilled the auto trans with Redline DT6 because it claimed the best viscosity I could find at 100o. It wasn't really long enough to get a good feel for that; while the trans got to 100o in the session it still wasn't shifting crisply as I hoped. I think I'll try a few more sessions before judging. No steering motor overheat but I'd hope not in only 1 session! But finally the suspension; it was night and day over the standard stuff and the car was a couple of seconds quicker on the same crappy tyres, which is a huge difference. I'll stick with that and get some sway bars and a mechanical diff sorted too and see how that all goes together
    • I guess it’s partially a compromise of how my car is used, wanting to be able to switch from drift to grip with track side on-car adjustment. Also partially with the way the knuckles are set there is more static camber but less dynamic camber gain.
    • OK, so update from the track day on Friday It was a classic "an unfortunate series of events'. There were a few cars around and when i checked my mirror coming out of the fish hook I notice some smoke from the rear of mine. Looked again and it was getting much worse, I figured I'd blown a turbo or something to got off it and pulled off the racing line. However.... since it is a left hairpin into a right kink, I was on the inside of the next corner. There was a car passing me on the left and a big drop off over the ripple strip on the right......and someone had knocked the witch's hat that was on the apex about 1m onto the track. So, between those 3, I decided to mow down the cone and not damage my car/the other car. Right choice, but surprising result.  The car decided the cone was a small pedestrian so it blew the rear bonnet hinges up to protect their head in the upcoming person to car impact....I didn't see that coming and like an airbag deployment it happened super fast. Straight into the pits from there, everything was driving fine but it became clear it was a coolant leak not smoke, it was billowing up onto the windscreen. Onto the trailer and home. I'll do a separate thread about the repair (once I work out what it is ), but the immediate problem was the bonnet wouldn't open because the front was pinched onto the front bar and would not release. Ultimately we unbolted the hinge from the bonnet, pulled it back a little and it released from the front OK. "There's your problem", the top radiator hose had popped off at the radiator.
    • Yeah that looks like great caster, but I'd suggest trying less front camber some time and seeing if it helps with braking without reducing mid corner speed too much
    • I ended up setting the rear 5mm higher than normal to give some clearance.  My plan is to run the least camber I can in the rear which I think with the extra width is going to need to be -1.75 to -2.00° just to get clearance.  Guards have been rolled and pulled as much as they can/I would be wanting to.  front has the Acostal knuckle with the KPI change and the drop etc. So should be okay with the existing settings I have run with AR1s etc Front: Toe total -2mm(1mm out each side) Caster +7.5° Camber -3.8° Ackerman +15°
