They are a "Thule" brand Rack but could not find anything at all for a 2 Door skyline (which wasn't surprising) So I had to buy a rack for a Toyota Yaris, cut the mounts up and modify them and moulded new feet out of silicon sealant so they matched the roof profile properly :)
  • 3 weeks later...
Yep that was me, Had just left Brisbane and was heading for Sydney :)
Extremely happy with the GTR, Over 8000km across all but one of Australia's Territory's with the only issues we had being:
-Clutch clevis pin popped out, must have been missing the split pin (5 minute fix)
-Horn jammed on when I turned steering full lock, have not investigated why yet, just pulled the relay for now (1 min temp fix)
-One of the adjustable castor suspension arms unwound itself after we went off road for about an hour down one of the tracks SIRI sent us down making the steering wheel 1/4 way off center (15 min fix)
-Close call with a small roo/other car
-Too low for the crazy eastern states driveways that dip 1000meters into the gutter, even tho the car isn't that low! (scratched up the front lip)
Best we got was 11.3L / 100km with the average around 11.7L/100
  • Like 2
  • 3 weeks later...
So had a good look under the car just inspecting for any damage/wear from the trip... Besides being absolutely filthy (dirt/dust) everything seemed pretty good, being aftermarket arms with heim joints I pulled them all apart and gave them a clean out... Found abit of crap got into one of the rear traction arms and noticeable wear on the rod end so will replace that.
Also found the drivers side outer steering tie rod had abit of play... I happened to find these tie rods on UAS which they say help fix some of the bump steer issues when you lower the car.
http://www.uniqueautosports.com.au/Parts-Shop/front-bump-steer-correcting-tie-rod-ends-584.aspx
But then found these from the guys at Shift Performance Parts, Inner and outer rods that look identical.
https://www.shiftperformance.com.au/product/n1-suspension-nissan-skyline-r32-r33-gtr-gts4-14mm-steering-tie-rods-ends-2/
Anyway bolted it all up today no probs, (obviously changed both driver and passenger sides)
Original:
"N1" Parts, The angle that the balljoint is mounted on the end of the tie rod was quite different compared to stock.
Another interesting this was the inner tie rods had "rack spacers" built into them, Unlike the originals which I purchased a pair of "rack spacer washers" from GKtechIMG_1118.JPG
Setup the toe as best I could with a tape measure, will book for an alignment next week
  • Like 1
So my gearbox wasnt doing so well, 1st Gear was terribly hard to engage even at a complete stop and If I tried to shift into 4th or 5th gear at anything other then grandma speeds she would crunch crunch... even worse at higher RPM.
So abit of research many people recommended "Redline Shockproof gear oil" Now I had recently replaced the oil with some Penrite stuff not too long after getting it licensed and even added some additive (cant remember what it was but supposedly gave smoother shifts etc) so I was a little sceptical that the Redline stuff could be that much better.
Oh how wrong I was... Took it for a fang and not even the slightest crunch! 1st gear is even easy to engage! this stuff is truly Magic!
  • Like 1
I hear that!
My gearbox was woeful changing down to 4th but after it was changed to redline it was a different car.
It really only masks the problem and I know that I will be up for a new gearbox but it has lasted a year and hasn't gotten any worse (yet).
  • Like 1
  • 3 weeks later...
Small update, I bought myself a early x-mass present in the form of a Whiteline adjustable front & rear swaybar kit :)
New Vs Old (had already fit the front one before I took a pic)
Rear Fitted:   (underbody still filthy from the road trip)
Front fitted:
Also picked up and fit a set of solid steering rack mounts:
Last not least, the exhaust system had two mufflers... which was great for passing pits and not annoying the gray nomads at the caravan parks while on the road trip but decided to delete the center muffler hoping for abit more of a note.
Section comparison:
Didn't have any bends and since it was only one decided to just lobster it:
Idle was noticeably louder and deeper as expected, Is noticeably louder while driving but surprisingly not all that much. Only been around the block a few times so cant comment on the swaybars/steering rack bushes just yet... Will take it out to some twisties tomorrow :)
  • Like 2
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
