Here is a graphic example of the problems associated, it starts at the divider (where there is lack of clamping) and this diminishes over time significantly as this part of the manifold distorts and falls away so to speak, then its a slippery slope to turbo hell.
Ironically its more of a problem in road cars that run all the time at 1.000 Lambda and non optimized ignition settings, remember 98% of the time in a street car literally is spent here, and EGT can get very high.
The secret is run the car with a bit of excess fuel here to cool the exhaust and you will increase durability 10 fold.
It not an issue of bolt clamp loss rather the material distorts (on the manifold) and the turbine housing to a lesser degree, then its game over. I put above a worst case scenario and simple color chart shows that on the flat flange area the temps you can use an aviation product (I have worked with it to 750 deg C) on outer of flange!) typically this never gets over 550 deg C as its transferring allot of heat by that time to the surrounding engine bay air.
The whole problem though starts at the center divider where there is no/little chance for heat transfer and its more RAPE than Mr Fritzle family fun times.
16 hours ago, sneakey pete said:
Welp....
f**k.
Seems like the gasket has gone through or at least into the inlet to the turbine. Not yet removed manifold but i'm expecting to find chunks of gasket sitting in it.
What are my options now?
damn dude, you're really not having much luck with this engine/turbo combo :(
Yeah its been a struggle. Has been in all of 12 months and 6-7000km and 2 track days.
I do wonder if bolts loosening have accelerated the process. Previous gasket i took off (after probably only 2000km) looked perfectly fine. Pretty sure this only blew out at the 2 sessions i got in at QR. The missing side of the gasket was on the looser side (nuts on studs instead of bolts).
Also I wonder if it was something with the tune also that may have not helped, unfortnatly my logging wasn't setup properly so I don't really have any useful info. Cruise wise EGT's aren't really that high for my setup currently as there hasn't been any setup completed on a wideband cruise, so thats probably not going to be it.
IMG_0009.thumb.jpg.3fbdb65c3649a9961190c7765da2114e.jpg[IMG_0011.jpgimg]http://cdn.sau.com.au/monthly_2018_09/IMG_0009.thumb.jpg.4fdf4843f28279d641774cbbcfc8cb6e.jpg[/img]
Street driven Rotary, bit of half throttle boost gets this hot. My gasket fell apart too!! Now it makes sense what RICE said, egt’s get really high just cruising, because it doesn’t as hot when you’re trashing it.
Yeah been around them too long (since 1995) first T04 set up. My current combo is a BW369SXE and Tial V'Band single entry housing, no gaskets or dividers to get chewed, have a great pic of one housing where the whole center divider was eroded away from thermal fatigue... split pulse is a nice idea but shite in practice I found.
I’m actually going to a Borgy369SXE soon, Precision is getting tired and rear end is only .84 which is a bit small for a bridgey. I’ll look into the V Band option if that’s possible.
5 hours ago, burn4005 said:
Sparesbox have 20% off on eBay all the time but I'm not sure they actually can get their hands on them/have stock
Do yourself a favour and don't use sparesbox.
I waited 10 months for mine to arrive and it was always coming 'next week'. Even getting my money back was a pain.
  • Like 1
    • Kinda glad I never got to this ..    https://www.facebook.com/groups/1483859159195077
    • @GTSBoy This method was able to get readings of -10 to -2, so it looks like its monitoring.  Now I need to figure out why the vacuum on the line provided isn't alternating with manifold pressure.  I went with 2 lines that an RB25 tuner recommended but I'll get a longer hose and try directly off the back of the manifold.  He may have been used to OEM intake setups while I have a DBW setup that removed the MAF and IACV.
    • I work at a car detailing and tinting shop called Quark which gets all manner of German cars in usually (mainly due to a contract with Mercedes Benz Kita Osaka, BMW Nishinomiya and others) but every once in a while something special comes in, like a fully restored 1972 HS30 Nissan Fairlady 240ZG... The shop owner had immediately started applying film to the windows as soon as it was in the shop so the interior was completely covered in towels and plastic sheets. But I could get a few photos of the engine bay which was restored like new. Such an amazing car to see in pristine condition in Japan these days.
    • Was going to say the car pulls up nicely everywhere, especially going into that last long right hander before the main straight. Looks like a lot of fun.
    • Hey Dave, welcome aboard! Good to see another soon-to-be Stagea owner here. The wagons are awesome — plenty of space, still got that Skyline DNA, and loads of potential if you’re into mods. Definitely post up pics when you get it, everyone here loves seeing new builds. What model/year are you looking at?
