nice to see a tuner ramping in power instead of having the 5000rpm torque mound.
would be a hoot to drive.
For context, I have 490rwkw at 27psi on a 2.6 8374 and that was doing 126,000rpm on the turbo (maxed) so there would still be a bit left in the 8474 for sure.
Edited by burn4005
  • 3 weeks later...
On 1/18/2024 at 8:10 PM, Komdotkom said:
Thanks gents, your input is very much appreciated
Clearly I'm not smart enough to work this out, who do you engage as a consultant to spec a turbo for something like this? I wouldn't know where to start looking for the right kind of boffin for this.
Turbomachinery engineers. They're just mechanical engineers who generally studied in universities focused on oil and gas, aviation or that had a formula SAE competition team. We have an entire team of them in our engineering department... they geek out over data and performance testing. I worked with them a lot when we developed an anti surge system for centrifugal compressors ran by electrical motors (~20 000-50 000HP) to avoid surging on accidental power loss.
They laugh when I mention automotive turbochargers.... it seems they're lightyear's behind in technology due to poor funding. If you think formula 1 spends a lot of money, a single turbine/centrifugal compressor package in my line of work including the balance of plant equipment generally ranges in the 150-250Million range depending on size.
  • 3 months later...
  • 3 weeks later...
Has anyone seen any results with an 8370 on an rb26 yet? Seems like it could be a good option sitting between 7670 and 8374
https://www.full-race.com/borgwarner-efr-8370-turbo
Restrictive when flowing close to 500kw though yeah? just thinking if 400 to 450kw is the goal then the 8370 fits in that spot. Is the 70mm rear going to be restrictive at that power level? On the 7670s isn't it the compressor running out of puff at 400kw rather than the rear being restrictive?
  • 8 months later...
On 27/08/2024 at 7:49 PM, Borci88 said:
Just trying to revive this thread... Probably a few months off completion though.
Bit of an update to this one.
Having some issues on the dyno that held us back (boost spiking) and I want to pass some info over you guys and see what you think is wrong with my setup. The current readout on this dyno is 462rwkw on a low reading dyno so keep in mind it is a real world 500rwkw setup on a hub dyno. Don't read into the power figure too much as a sign of the issue.
The short and curly of it is:
2.8 Litre Racepace build
RB25 NEO N/A Head with VCT (internally standard however )
Borgwarner EFR 8474
Turbosmart 50mm Straight Gate + Mac valve
6Boost Manifold
4" dump to full 4" exhaust (nil restrictions) Wastegate plumbed back in and all angles in the exhaust system are acceptable and not too sharp.
GFB SV52 BOV in cooler piping
Turbosmart BOV in EFR Housing
The issue we are having is it comes onto full boost for example at 4000rpm and spikes to 24/25psi, before dropping down to 17psi before slowly rising back up to the target boost of 23psi. It was extremely uncontrollable and the tuner actually had to ramp in boost progrssively with each 1000rpm on each boost setting we selected to try and reduce the amount of spiking. Sometimes we would see a drop of 10psi from the peak at the beginning of the run, to the low, until it took the next 500-1000rpm to stabilise back up to the target boost.
The tuner is pretty confident that the straight gate is just a poorly designed product and leaks too much boost upon cracking the gate open and theres no way to fix it other than going to a poppet valve. He's also confient theres no ignition breakdown or floating valves. The fueling is extremely stable as well. Turbo speed is somewhere around the 109,000rpm area.
The spanner in the works for me is that prior to this Borgwarner and StraightGate, the car was tuned on -5 twins at a diferent tuner, and he also had issues controlling the boost with it spiking around the same rpm range, so to me this sounds like the same issue and it can't be anything on the turbo side as this was all changed and I think the behaviour is extremely similar, if not the same.
We also removed the mac valve and did a run on wastegate pressure and it still spiked and had the same behaviour.
My thoughts on possibilities are:
Boost Leak
VCT Cam Gear isn't reliably activating consistently - (On this however, we did a run with the VCT disabled and the boost still spiked)
Turbosmart BOV is not handling the boost? However this seems unlikely to not be able to handle 20psi.
I have a couple of logs that I can't make sense of if anybody knows how to read them and can obtain further logs of other parameters if they are not enough, happy to pay for anyones time.
The dyno readout with the power figure is the most recent last week. The other picture is from two weeks prior to that where we couldn't break 400kw (we removed the cat), however the issue of the boost control persisted.
@Lithium @Piggaz @burn4005 @GTSBoy @discopotato03
I've tagged those that were quite active in recent pages here, no disrespect to those that know turbos well but I missed tagging.
Cheers
A few things that seem a bit off here.
- why is there 2 BOV’s?
- the turbo smart BOV on the compressor housing, is it turned up ALL the way? I have seen this become an issue on old man Pete’s car. It would push open and recirc, turbo speed would rise and the boost pressure would do weird things.
- stock head? Does that include springs?
- tried a different MAC valve? Is it plumbed correctly?
Posted (edited)
What transmission are you running?  It's a bit tricky with the scaling, but at face value the power "curve" looks more like a "line" which is a bit odd... basically a lot more like a dyno plot I'd expect with a highish (compared to a factory auto) stall torque converter type setup.
If this is running an auto then this kind of boost control challenge is definitely a thing, the rpm scale on the dyno doesn't reflect what the engine is actually doing (unless the dyno has access to the engine's ACTUAL speed electronically) and what you'll get is a big rpm flare up as the engine torque launches past the converter pump's ability to resist torque at that rpm, then as the converter starts picking up rpm it will kinda even out again and the engine rpm will pick up more steadily.
The trick with this "flare up" is if it's kinda near the boost threshold for the turbo then the engine's airflow requirements to maintain the previous boost level will outrun the turbo's ability to supply that boost - so you end up with a natural flattening off, if not dip when that happens.   If you are running closed loop, or even tune the "feed forward" wastegate duty cycle to deal with that rpm spike then when the engine starts settling to a more typical climb you'll actually have a situation where the gate is "too closed" and boost will run away for a bit, then have to pull down again.
It's not trivial to get this perfect as most boost control systems are generally expecting more predictable engine rpm rates of change, but if you *know* that's whats going on then you can at least "accept your fate" and realise getting that area perfect is kinda chasing your tail a bit, and assume that if the rest is working sensibly and the spike/dip isn't completely uncontrolled then you should be good.
Sorry if I've gone off on a tangent, but the dyno plot and boost control behaviour look a LOT like what I've seen tuning autos in the past.
What ECU are you running? Could possibly be convinced into looking at logs if I get too bored this weekend haha.
Edited by Lithium
3 hours ago, GTSBoy said:
Photo of manifold showing gate location? I mean, it's 6Boost, so we probably shouldn't be worrying, but always wroth knowing what the layout is.
Plumbed back to atmosphere? Or into the dump?
Thanks for the quick replies guys its appreciated. A small extension was welded onto the standard 6boost external gate pipe which you can see where the pipe goes from black to stainless just below and to the right of the rear housing in the first picture. Overall I would say the flow is pretty good other than 6boosts choice to come straight off the collector at a decent angle..
500110206_1247678203383684_8388098167480809807_n.thumb.jpg.1580d4d83232deb30562bd401a06cb13.jpg492454186_2735183620009414_75065699984617187_n.thumb.jpg.afa4702740695856bf0dc1383d482728.jpg
Not sure why I went with two valves, I originally replaced the stock twin bovs with the GFB when I had the twins on. When I purchased the EFR it came with the Turbosmart Kompact BOV so I figured that would be a better option than the stock EFR Bov. I don't believe the Turbosmart BOV is adjustable? When I get the spike and then sudden dip in boost pressure, the turbo speed does drop as well.
Stock head size wise however I believe it has Neo Turbo springs and a Neo Turbo intake camshaft and an aftermarket exhaust camshaft in the vicinity of 260 degrees.
We didn't try a different MAC valve, we tried two different ways of plumbing it and we also tried removing the mac valve entirely and just having the boost source from the turbo directly connected to the wastegate and it still spiked / dropped and exhibited the same behaviour.
494834403_1685184388804498_3884582342719705931_n.thumb.jpg.8dbcfe24f2c7bde60a5262302de36a0a.jpg
Standard R33 GTR 5 speed tansmission. I'm running a Haltech Elite 2500 and can provide some logs if you. I understand what you're saying in that it looks like an auto plot however no, it's still a manual and it just has a lot of torque down low, for all intents and purposes it's a very impressive street car.
I've attached a photo of the quickbitz dyno plot which was when the only difference is I was running -5 twin turbos with a mac valve. As you can see theres a decent dip in AFRs between 125kmh and 135kmh. Our problem now is not that the AFRs are dropping, just the boost pressure is dropping, however it is evident in the same RPM range of the map, coincidentally or not.
3 minutes ago, Piggaz said:
Big question… have you decided on a gearbox? Because it’s going to come… and a gearset ain’t going to do the job.
save your pennies 🤪
I've got a spare standard box sitting in the garage :117_eyes:
I know it will come one day though, but it's driven pretty tamely on the four times a year it gets out...
Heres a dyno log comparing
MAP
TPS
RPM
TURBO SPEED
Each hump is 2nd, then 3rd then 4th gear. This particular log is using gate pressure with the mac valve completely removed.
As you can see it spikes to 23psi, and then drops to 20psi over the course of approx 700rpm, this is the minimum pressure the system will run using a 12psi spring. I think my next set of logs will be changing the spring to the 6psi spring and going out and doing another set of logs again and see if the spike is as dramatic.
As you can imagine if it spikes 3psi on wastegate pressure, that increases to 5-6psi of difference in the higher boost levels approaching the 28psi target with the mac valve.
I even have a few logs here where with the mac valve targetting 28psi, the haltech is seeing 38.6psi....
Just now, acsplit said:
Can you vent the straight gate to atmosphere easily for testing?
Not without making up a new screamer pipe from scatch I don't think based upon the angles of the current return.
Backpressure shouldn't be an issue though as the straight gate isn't affected by backpressure in the same way that a poppet valve is, and on top of that the exhast system is 4" all the way through so there should be minimal pressure if any to begin with.
18 minutes ago, Piggaz said:
-5’s did it.
8474 did it.
Not hot side related.
ECU related? 🤨🤪
It could be in the tune but in both cases it couldn't be completely solved or eliminated by some of the best tuners in victoria so I'm DOUBTFUL that it's in the tune or ECU but stranger things have happened of course.
3 minutes ago, GTSBoy said:
I'm thinking it is skinny NA Neo port sizing and cams. Somehow.
I've pondered that theory too but is there any theories that thinner and smaller ports overall would cause a turbo to spike? I would've thought it would just restrict it in general if it was small enough to make a difference. I wouldn't expect it to make a different at what is essentially sub 300kw at 4000rpm anyway.
I think the next step is going to have to be the 6psi spring to rule out the idea that the gate is cracking open far too wide initially. At least that is the cheapest (free) thing to check initially.
My theory would revolve around the ~4000rpm point being peak torque territory on an RB, where you're supposed to be looking at max efficiency of the head, etc, and....just not having it because the skinny ports are doing something to f**k it up.
I'll admit, it's a loose theory.
    • I'm looking for some real world experiences/feed back from anyone who has personally ran a EFR7670 with a 1.05 exhaust housing or a .83 I'm leaning towards the .83 because its a street car used mostly for spirited driving in the canyons roads. I"m not looking for big numbers on paper. I want a responsive powerband that will be very linear to 8000 rpm. I dont mind if power remains somewhat flat but dont want power to drop off on top. The turbo I've purchased is a 1.05, although the mounting flange T3 vs T4 and internal vs external waste gates are different on both housings, I not concern about swapping parts or making fabrication mods to get what I want. Based on some of the research I've done with chat gpt, the 1.05 housing seems to be the way to go with slightly more lag and future proofing for more mods but recommends .83 for best response/street car setup. AI doesn't have the same emotions as real people driving a GTR so I think you guys will be able to give me better feed back 😀
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
