I think the biggest difference was made by the pads, of course the rotors and ducts would've helped a bit. If you're not regularly tracking I wouldn't bother with braided lines if your stock lines are in good nick. If you have to replace because they look suspect then definitely worth it. My 2c[emoji4]
Glad I could help :)
Check out adms15' video on how his SR pads performed at Sandown.. pretty damn good!
They're no Project Mu HC800 pads but they're close enough and at half the price, it's perfect for a weekend track warrior
Furthermore, happy to report after a week of normal Street duties that the track day didn't effect the pads at all. Unlike other Street track pads I've used that have become noisy squeely junk after a good thrash. Sr[emoji106]
  • Like 2
  • 3 weeks later...
So I've decided to install the pads and discs myself after looking at guides.
Is the caliper bolts torque spec the same for gtr as gtst? Guide says 92-118nm
On 10/10/2016 at 8:23 PM, admS15 said:
Furthermore, happy to report after a week of normal Street duties that the track day didn't effect the pads at all. Unlike other Street track pads I've used that have become noisy squeely junk after a good thrash. Sremoji106.png
I got sent Intima SR instead of SS, they're great, Needs a couple of hits for it to warm up but perfectly driveable on the street (slow, daily driving). Once they're warm, holy shit they stop. Overkill for daily duties but works. Not that dusty either (especially compared to A1RM).
  • Like 2
So managed fronts yesterday. Drivers side was stuck but improvised with a clamp to get the disc off.
Tried the rears this arvo. Rear left easy.
Rear right is stuck and giving me no love. So I'll prob need to get some bolts to screw into the two holes do you guys know the specs on what I'll have to buy?
Yes use the bolts but also bash the drums all round with a big hammer to loosen things up (assuming handbrake is not binding). You may need to clean up a bit of a lip inside the drums before you put them back (unless you have new ones).
thanks guys ended up finding a couple of spare bolts from my top feed rail that fit the holes.  Managed all four discs and pads over the last couple of days, rain, darkness and the one stuck disc made it more than a day, as well as taking my time on the first one. but overall pretty easy job.
Thanks for your advice and esp thanks to Johnny and STT
  • Like 1
  • 4 weeks later...
On 03/10/2016 at 0:44 AM, admS15 said:
The car is a R33 gtst, stock sumitomo calipers, plain rda 324mm rotors with adaptors up front and rda slotted/drilled standard sized rears with sr pads all round, penrite 10 tenths fluid and stock brake lines. Small 35mm agi pipe ducts run from front bar to back of discs on front.
How are you finding the RDA's on the track Bill, any issues with the heat? Have you run DBA's before, for comparison?
I'm getting an annoying squeal (yes have added copper grease) and some shudder on the front right and trying to diagnose the cause, someone suggested the classic 'warped rotor' but will need to investigate further. My current DBA T3's have been skimmed once, there's maybe one more skim left in them, but in case I need to replacement I'm wondering if RDA's would do the job for ~60% of the price...?
Hi Jussi, so far so good but they've only really copped 1 hard track day. I need to put them through some more torture before I can give a decent assessment of how they cope under extreme duress. Haven't had dba before, just Nissan oem which held up well over multiple track days. I'll keep you posted in the future.@V28VX37
  • Like 1
On 10/3/2016 at 10:23 AM, MatthewT85 said:
Thats good to hear!, looks like the bigger disc/cooling ducts are making a big diff,
Yeah I had my Brakes go dead after 3 laps at Symmons. Im not chasing lap times, but just want something reliable.
Do you guys think its worth swapping to braided lines as im redoing pads and discs?
I think the theory with braided lines is the same as M/C stoppers: more instant reaction when you hit the brake pedal i.e. no initial flex of the bulkhead or expansion of the rubber brake lines.
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
