  • Replies 76
So the petrol gauge went up off empty but still no start but I've got that cat over heat light still on when I try to start it. Does anyone know if that will stop it from starting, if so can I just simply take the fuse out or how can I resolve that, Tomoz arvo the fuel line comes off from the rail to double check fuel, and a new fuel filter also goes in Walst im there.
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
