Buying a GTR, and I need your help!
Hey guys, I've been looking for a clean BNR32/BCNR33 for a while now. I've mostly looked on carsales and it left me with a few questions, hopefully you guys would know the answers,
  • The price range of the cars? How much do they go for these days? Didn't make sense to me how a V-Spec33 would be cheaper than a normal BCNR on carsales...
  • Importing? Costs vs benefits?
  • What should I look out for when buying a GTR? Never bought a car this age before.
  • For the long time owners, reliability issues?
Thanks in advance, I'm looking forward to your replies.
https://www.sau.com.au/forums/topic/467706-buying-a-gtr-and-i-need-your-help/
Hi........ I don't have time at the moment to answer all your questions but this car seems to be a pretty good indicator of where the market is at.
http://www.carpoint.com.au/all-cars/dealer/details.aspx?R=OAG-AD-13728478&Cr=9
Please note I have NO VESTED INTEREST in this car but like the basic original presentation of the car.
That said, the N1 add ons are desired by many but not me.
18 months ago a similar car would have been $25K but the facts are these cars have zoomed up in value.
To import, compliance and register a grade 3.5/B car your looking at around $30-$35k.
This car is slightly better than that and you can see and drive it.
Anyway, this gives you a starting point.
Cheers,
Bob.
  • Like 1
check..
rust under the boot & around strut towers (under the hood)
do a leak down test
compression test 145psi or mor is ok
drive behind it and see if it blows smoke on WOT
spend the extra and get it inspected by a mechanic (no one young)
3 hours ago, GD51LA said:
check..
do a leak down test
I've got nearly 0 experience in mechanical stuff (changing perishables and coilovers in my c63 is the furthest i've gone)
I'm located in VIC but seeing the majority of the cars are located in NSW, any of you know good mechanics/workshops I could call to do all the inspections and testing?
Few good threads, info is subjective though.
Best when you find a car, let us know what area it's in, and we can recommend a shop near there.
http://www.nissansilvia.com/forums/index.php?showtopic=194777&st=60
http://www.evolutionoz.net/forums/index.php?/topic/54945-good-places-to-get-evos-servicedmodified/
  • Like 1
  • 1 month later...
    • That sounds like an excellent idea. But total self-sufficiency means exactly that. You have no-one else to blame when your system faults out and you have no power for a week or two while it gets fixed. You'd have to go the whole hog and get a diesel genny and all the switchover gear, to get you through such times. And, despite the fact that over 20 years, my system has been pretty reliable**, I have seen so many inverter explosions (or less dramatic deaths), panel and roof JB fires, and so on, over that time, to know that the stuff is the same as any other bulk Chinese manufactured stuff. The failure rate is well above zero - both on the equipment and on behalf of the meth addled installation labour force. And then..... warranty and means of redress against the supplier you bought the gear from. Best I can tell is that only a handful of solar companies are still around within 5 years of starting their advertising pitch. They disappear and phoenix like crazy. So, as per 1st paragraph, I suspect the only way to is go balls deep and spend maybe 2-3 times as much as you might think, so that you have every base covered. Plus, know and understand your gear intimately, so you can diagnose problems, sort them out yourself, etc, etc. Plus, probably have to consider upgrading various parts as the years pass, to maintain compatibility with newer stuff, performance and reliability, etc, etc. Whereas, remaining attached to the grid has an ongoing cost that keeps going up even if you use bugger all power from it. But it does provide the fallback in case of the worst case with your own gear. You either pay up front or as you go, I suspect.
    • Add more solar panels to the array. Call the electricity company and tell them you're moving out... Live off grid electric wise
    • Hi Jasmine. How's the war going?
    • I'm extremely suspicious of the VPP stuff. Best I can tell, you surrender any and all control of your panels and battery to the VPP, because there's no way that anyone could write a sufficiently useful set of "rules" as to how much you would be willing to let out of your export meter at any given time. If one of your main interests is to have enough in your battery every evening to get you through the night without having to import, you could easily find yourself with nothing in your battery at the end of the day, or part way through the night, and then be paying import pricing instead of paying nothing. I cannot see how this cannot come to pass.
    • majority aftermarket is an10 yes, but majority of OEM is An12 r35 OEM cooler lines at close to an 12, the hard line that car uses is almost 20mm  Porsche OEM is also AN12   i figure, if our power levels are close to 1000hp, then AN12 should be a must if many OEM standard power vehicles use AN12
