Ken's z31 I wanna go fast build
I am Ken from the Seattle area USA. I bought my 1985 300zx GLL non turbo 5 speed in 2011 with the impression it had blown head gaskets which only an RB  swap would remedy. I replaced the bad thermostat and drove it for 4 years.
Opportunities arose and I purchased a wrecked 87 300zx with what I assumed was a stock rb20 silver top and 5 speed swap for $800 usd. Car had been sitting for 6 years after the owner wrecked.
  • Like 1
https://www.sau.com.au/forums/topic/467848-kens-z31-i-wanna-go-fast-build/
Engine was siezed so I started to take it apart. What I found blew me away.
Internal:
.015" over custom Wiesco pistons
spool rods
full balanced rotating assembly oil snout to pressure plate
spec stage 3 6 puck sprung clutch and flywheel
acl bearings
hks step 1 cams 264/264
adjustable cam  gears and greddy timing belt
bolt on:
rc racing 750cc injectors
precission 5557e dual ball bearing with billet wheel
z32 maf
aeromotive fpr
Nistune type 2 board
The list of parts well exceeded my $800 paid for the siezed block.
I discovered the heard was ported by a hydroplane mechanic.
I have no idea as to what power the car made or what psi the tune was done at. All the info I have is the car ran for two weeks and then it was totaled.
Welded in a nipple for the iacc and Aacv as well as a flange for the synapse engineering synchronic bov.
Also a 3 core s13 radiator modded to fit and a custom made shroud for the 14" fan. Unsure on cfm but the shop who built the car for the previous owner had used an oem vgz31 radiator and shroud with this fan tucked inside very crudely. Lower coolant hose is fitted with a temp switch for the fan relay.
  • Like 1
Also when the previous owner of my 85 had taken the car in for diagnostic the brilliant mechanic decided to dump head gasket stop leak into the system and I did not want to chance the  heater core to fail and fill my fresh rb and radiator with stop leak.
My Z has modded knuckles, running s13 Lcas and tie rods with the rack moved forward 25mm to prevent over centering. Of course I have no pictures of my own parts. S13 coil overs front and rear and s14 tension rods. Welded diff and poly bushings but one day will have s13 subframe.
I will attempt to snag some photos in the day light.
Edited by Zrbsliding
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
    • Hi.. Just another problem. So maybe you can help. I(my mechanic) done swap from my RB20DE NEO to RB25DET NEO. Everything is OK but we have a boost cut. Coils/Plugs are ok...AFM is ok. ECU is ok. I have Walbro 255 but it "changed" sound few months ago(you can hear it ouside) you did not hear that when it was new(maybe faulty?) Sooo...what now? What can cause this boost cut? It is even when you standing still...
