Ken's z31 I wanna go fast build
I am Ken from the Seattle area USA. I bought my 1985 300zx GLL non turbo 5 speed in 2011 with the impression it had blown head gaskets which only an RB  swap would remedy. I replaced the bad thermostat and drove it for 4 years.
Opportunities arose and I purchased a wrecked 87 300zx with what I assumed was a stock rb20 silver top and 5 speed swap for $800 usd. Car had been sitting for 6 years after the owner wrecked.
  • Like 1
https://www.sau.com.au/forums/topic/467848-kens-z31-i-wanna-go-fast-build/
Engine was siezed so I started to take it apart. What I found blew me away.
Internal:
.015" over custom Wiesco pistons
spool rods
full balanced rotating assembly oil snout to pressure plate
spec stage 3 6 puck sprung clutch and flywheel
acl bearings
hks step 1 cams 264/264
adjustable cam  gears and greddy timing belt
bolt on:
rc racing 750cc injectors
precission 5557e dual ball bearing with billet wheel
z32 maf
aeromotive fpr
Nistune type 2 board
The list of parts well exceeded my $800 paid for the siezed block.
I discovered the heard was ported by a hydroplane mechanic.
I have no idea as to what power the car made or what psi the tune was done at. All the info I have is the car ran for two weeks and then it was totaled.
Welded in a nipple for the iacc and Aacv as well as a flange for the synapse engineering synchronic bov.
Also a 3 core s13 radiator modded to fit and a custom made shroud for the 14" fan. Unsure on cfm but the shop who built the car for the previous owner had used an oem vgz31 radiator and shroud with this fan tucked inside very crudely. Lower coolant hose is fitted with a temp switch for the fan relay.
  • Like 1
Also when the previous owner of my 85 had taken the car in for diagnostic the brilliant mechanic decided to dump head gasket stop leak into the system and I did not want to chance the  heater core to fail and fill my fresh rb and radiator with stop leak.
My Z has modded knuckles, running s13 Lcas and tie rods with the rack moved forward 25mm to prevent over centering. Of course I have no pictures of my own parts. S13 coil overs front and rear and s14 tension rods. Welded diff and poly bushings but one day will have s13 subframe.
I will attempt to snag some photos in the day light.
Edited by Zrbsliding
    • So stock ECU does not like anything above 10 psi?  That Nistune one is just for "try" if it will be any different, I know it need to be tune for that. I know but YOU may know about these problem but i/we dont. They few little Skylines here let alone people who know anything about tham so that is why iam asking here
    • So now we have a radiator with no attachments whatsoever. It lifts up with a particularly tight spot between the drivers side air box mount and the lower radiator outlet, but if you've got this far you will sort that too. This is the lower mounts with the rad out so you can see where the rubber bushes go, it is a straight shot upwards Done! Assembly is the reverse of disassembly, with blood less likely to be shed.
    • Right, onto the second last trick. The Air Con condenser is mounted to the front of the radiator and stays in the car when the radiator is removed. There are 2x 10mm headed self tappers holding the top of the condenser to the radiator, remove those The bottom of the condenser is attached to the radiator with clips. You need to lift the condenser out of those clips and clear (up, then forward). f**ked if  could work out how to do that last bit with the front bumper on. I hope you can, and you share the trick.  Bumper removal probably deserves its own thread one day once I've recovered the will to live, but basically you need to remove the wheels, front inner guard liners (clips and 10mm headed bolts), the self tapper between the guard and the bumper at the rearmost point of the bumper (same as an R32 that bit), any remaining clips at the top/front of the grill, an absolute bastard design with a plate that holds the top of the bumper above the headlight each side (only 1 bolt which is tricky to get to, but the plate catches 2 places on the bumper and must be removed....carefully!) and push clips between the bumper and guard under the headlight. If you've done all that you will be faced with wiring for the fog lights on both sides and in ADM Q50 RS at least, 4 nasty tight plugs on the driver's side for the ADAS stuff. So, the clips at the bottom look like this on drivers side (looking from the front) And on the passenger side (also from the front), you can see this one is already out Clearance on both of these are super tight; the condenser needs to move up but the upper rad support mount prevents that, and the radiator can't move down far because it is (rubber) mounted. Once you achieve the impossible and drop the condenser off those mounts so it does not stop the rad moving, you are good to go
    • OK, next the shroud needs to come off and there are a couple of tricks. Firstly, there is a loom from near the passenger side headlight to the fans, coolant temp sensor etc and there is no plug to undo.  In my case I was OK to leave the shroud on top of the engine so I just undid the passenger side fan plug and about 10 of the clips which gave enough free wire to put it aside. The fan plugs were super tight, the trick I used was a small falt screwdriver to push down on the release tab, then a larger flat screwdriver to lever the plug out of the fan unit....be careful with how much force you apply! If you need to remove the shroud altogether for some reason you will have to deal with all the plugs (tight) and clips (brittle)....good luck. I removed all of the clips and replaced them with cable ties that I will just cut next time. Also, in the Red Sport / 400R at least, the intake heat exchanger reservoir hose is bolted to the shroud in 2 places with 10mm headed bolts; so remove them (the hose stays in the car; no need to undo it at the t fittings down at the radiator lower mount. Once you've dealt with the HX hose and the wiring loom, there are 3x 10mm headed self tappers holding the top of the shroud to the radiator; remove those.   The shroud then lifts out of the bottom mounts where it sits on the radiator, up and onto the engine out of the way. Simples
    • Ok, disregard my “rate them” comment, sorry for my unrealistic input
