10 hours ago, admS15 said:
Man these low km RB25s are less reliable than a VW motor. Part of me is saying a C63 AMG is more reliable lol
Yeah nah, you need more RB in your life but I won't argue against a C63 either. Do both, lol :)
  • Like 1
Funny you say that, I own a RB25 but mainly tune SR20s lol.
Rebuild plans so far, still indecisive about a few items:
Spool rebuild kit with the CP Pistons, Spool Sump, Camtech 264 mini-brappers, Performance Springs
Now the indecisive items:
Spool spline oil pump gears with an N1 pump, and Spool head drain.
Also my thoughts, if I run the head drain there wouldn't real need to run oil restrictor right? or wrong?
  • Like 1
I was under the impression many people had seen the head "drain" was actually just a sump vent in effect.
I'd do both if I had it all apart, never think about it again.
Yeah I had a good chat to Piggaz about it, looks like I'll run the restrictors still.
Funny it seems people are against running the spline driven pump gears say there isn't enough "movement" for slight crank imperfections and could chew up the pump. sigh.....
Yeah looks like I'll get the Nitto pump, it's only a bee's dick more than the Spool spline billet gears and a N1 Oil Pump housing.
I was trying to make the motor bullet proof, and that means rev limiter abuse proof like 1JZ and 2JZ, but I've read that the poor harmonics of the RB crank itself is enough to cause the crank snout to move and exceed it's normal circular travel cause any form of spline driven pump to misalign and go chomp. "Apparently" through Facebook whispers Nitto did the whole spline drive thing and abandoned it because it worked out more reliable keeping that Nissan oil pump drive style.
  • Like 1
2 minutes ago, ActionDan said:
How that limiter behaves has a bit of an impact too, if only you knew a good tuner.
I do, he is me lol. Like Scarface once said, I trust me lol.
My limiter has a soft cut at 7400rpm followed by a hard cut at 7700rpm with timing pulled before it hits the limiter.
This is an interesting point. You'd think Nissan spent a great deal of effort on engineering something reliable, but I guess something went slightly wrong with the crank. Even after 20 years, Nitto found that sticking with Nissan's final design choice was the 'best'. I guess all those Group C experiences didn't go to waste :P
BTW, what about Reimax gears vs. Nitto pump?
Have done a bit of reading on the spline drives, they seem to be used in the UK a fair bit.
Think someone on here (in the build threads somewhere) is doing a build with the spline, and put up the fitting instructions. I think it mentioned removing the dowels that locate the oil pump to the block, nip up the bolts, rotate the crank a few times (guess to "centre" the splines) then torque bolts to spec.
    • I've looked up the parts number (41011AL501). It's around $700 OEM. Usually our Infiniti G35 here in Canada have interchangeable parts with my Stagea but the parts number are not the same. I have looked around and it seems the JDM 2005 V35 Skyline (which is the same as our G35) has the same caliper but I cannot confirm. And I can't find a repair kit. The inner brake pads drags on the rotor, seems to be rusty piston. Thanks for the info by the way
    • This coupled with 6-9 speed autos with ridiculously short gearing is why these modern shitbox cars always seem so fast off the line. If it wasn't for those things, Raptors would not seem fast. The problem we have is there is a driveability gap between a more gentle take off and a wheelspinning sideways launch. The difference between ankle flex required to achieve one and ankle flex required to achieve the other is about 0.5°.
    • Yeah I think I'm also with the opposite here. It's 'hard to keep up with traffic' because in the real world I'm accelerating with 15% throttle and they are pinning it. It feels like I'm being an overt dickhead at anything above 15% throttle, so the car sounds like I'm being an overt dickhead to keep up with/get ahead of traffic when I'm really just trying to drive with traffic. There would be no issue 'keeping up with traffic' if we used the same level of throttle input/aggression to drive around. People really do just drive around with their foot nearly pinned in econoboxes.
    • To be fair it's the other way around. 300kw is boring in a modern Golf or BMW. They are so competent / well-engineered / devoid of emotion that you have to go stupid fast to feel anything. Whereas the <300kw RB still makes all the right noises and it feels good to drive. Can pull off at the lights with the turbo whooshing and the blow-off pssshing and feel like the coolest kid on the block. Just don't look to the side where you'll see the bored housewifes in their shitbox Yaris/Corolla/Camry that kept up because you didn't go fast at all
    • 300kW is so boring in a Skyline, you'll get spanked by someone's mum's Golf with Alibaba pipes, and an email tune.
