10 hours ago, admS15 said:
Man these low km RB25s are less reliable than a VW motor. Part of me is saying a C63 AMG is more reliable lol
Yeah nah, you need more RB in your life but I won't argue against a C63 either. Do both, lol :)
  • Like 1
Funny you say that, I own a RB25 but mainly tune SR20s lol.
Rebuild plans so far, still indecisive about a few items:
Spool rebuild kit with the CP Pistons, Spool Sump, Camtech 264 mini-brappers, Performance Springs
Now the indecisive items:
Spool spline oil pump gears with an N1 pump, and Spool head drain.
Also my thoughts, if I run the head drain there wouldn't real need to run oil restrictor right? or wrong?
  • Like 1
I was under the impression many people had seen the head "drain" was actually just a sump vent in effect.
I'd do both if I had it all apart, never think about it again.
Yeah I had a good chat to Piggaz about it, looks like I'll run the restrictors still.
Funny it seems people are against running the spline driven pump gears say there isn't enough "movement" for slight crank imperfections and could chew up the pump. sigh.....
Yeah looks like I'll get the Nitto pump, it's only a bee's dick more than the Spool spline billet gears and a N1 Oil Pump housing.
I was trying to make the motor bullet proof, and that means rev limiter abuse proof like 1JZ and 2JZ, but I've read that the poor harmonics of the RB crank itself is enough to cause the crank snout to move and exceed it's normal circular travel cause any form of spline driven pump to misalign and go chomp. "Apparently" through Facebook whispers Nitto did the whole spline drive thing and abandoned it because it worked out more reliable keeping that Nissan oil pump drive style.
  • Like 1
2 minutes ago, ActionDan said:
How that limiter behaves has a bit of an impact too, if only you knew a good tuner.
I do, he is me lol. Like Scarface once said, I trust me lol.
My limiter has a soft cut at 7400rpm followed by a hard cut at 7700rpm with timing pulled before it hits the limiter.
This is an interesting point. You'd think Nissan spent a great deal of effort on engineering something reliable, but I guess something went slightly wrong with the crank. Even after 20 years, Nitto found that sticking with Nissan's final design choice was the 'best'. I guess all those Group C experiences didn't go to waste :P
BTW, what about Reimax gears vs. Nitto pump?
Have done a bit of reading on the spline drives, they seem to be used in the UK a fair bit.
Think someone on here (in the build threads somewhere) is doing a build with the spline, and put up the fitting instructions. I think it mentioned removing the dowels that locate the oil pump to the block, nip up the bolts, rotate the crank a few times (guess to "centre" the splines) then torque bolts to spec.
    • Wanted to add some of my R33 GTST  R34 GTR wheels, 18x9 ET30 with 255/35/R18 PS4S'   BBS RE-V7 029 18x9.5 ET22 with 255/35/R18 PS4S' Needs a bit of camber
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
