10 hours ago, admS15 said:
Man these low km RB25s are less reliable than a VW motor. Part of me is saying a C63 AMG is more reliable lol
Yeah nah, you need more RB in your life but I won't argue against a C63 either. Do both, lol :)
  • Like 1
Funny you say that, I own a RB25 but mainly tune SR20s lol.
Rebuild plans so far, still indecisive about a few items:
Spool rebuild kit with the CP Pistons, Spool Sump, Camtech 264 mini-brappers, Performance Springs
Now the indecisive items:
Spool spline oil pump gears with an N1 pump, and Spool head drain.
Also my thoughts, if I run the head drain there wouldn't real need to run oil restrictor right? or wrong?
  • Like 1
I was under the impression many people had seen the head "drain" was actually just a sump vent in effect.
I'd do both if I had it all apart, never think about it again.
Yeah I had a good chat to Piggaz about it, looks like I'll run the restrictors still.
Funny it seems people are against running the spline driven pump gears say there isn't enough "movement" for slight crank imperfections and could chew up the pump. sigh.....
Yeah looks like I'll get the Nitto pump, it's only a bee's dick more than the Spool spline billet gears and a N1 Oil Pump housing.
I was trying to make the motor bullet proof, and that means rev limiter abuse proof like 1JZ and 2JZ, but I've read that the poor harmonics of the RB crank itself is enough to cause the crank snout to move and exceed it's normal circular travel cause any form of spline driven pump to misalign and go chomp. "Apparently" through Facebook whispers Nitto did the whole spline drive thing and abandoned it because it worked out more reliable keeping that Nissan oil pump drive style.
  • Like 1
2 minutes ago, ActionDan said:
How that limiter behaves has a bit of an impact too, if only you knew a good tuner.
I do, he is me lol. Like Scarface once said, I trust me lol.
My limiter has a soft cut at 7400rpm followed by a hard cut at 7700rpm with timing pulled before it hits the limiter.
This is an interesting point. You'd think Nissan spent a great deal of effort on engineering something reliable, but I guess something went slightly wrong with the crank. Even after 20 years, Nitto found that sticking with Nissan's final design choice was the 'best'. I guess all those Group C experiences didn't go to waste :P
BTW, what about Reimax gears vs. Nitto pump?
Have done a bit of reading on the spline drives, they seem to be used in the UK a fair bit.
Think someone on here (in the build threads somewhere) is doing a build with the spline, and put up the fitting instructions. I think it mentioned removing the dowels that locate the oil pump to the block, nip up the bolts, rotate the crank a few times (guess to "centre" the splines) then torque bolts to spec.
    • I had double clamped all the pipes but I checked them over any way, everything tight and secure. feels and sounds like a electrical short/failure, as it is an abrupt and aggressive stumble, that instantly comes and goes right at 4k mark...like clock work fuel pump and filter are new new coils and plugs injectors where cleaned and tested 200 miles plus ago no black smoke cleaned MAF   same results, other ideas? some other sensor?
    • Yes, just without the annoying use of the word hybrid. We stopped using that term 20 years ago when we realised it meant different things to different people. Even "highflow" can represent more than one way of achieving the goal of getting more flow out of a turbo. But at least it says what it does on the box.
    • OH, when they say "solid buckets", I always interpeted that as "shimless". (Which is not the same as the "shimness word I invented above to represent the same idea that the buckets act as shims also!!). Still the same problem though. So it appears that buying a "kit" from Tomei is a two step process. Makes sense. Doesn't make sense in the context of a "kit" though.
    • Wanted to add some of my R33 GTST  R34 GTR wheels, 18x9 ET30 with 255/35/R18 PS4S'   BBS RE-V7 029 18x9.5 ET22 with 255/35/R18 PS4S' Needs a bit of camber
    • Lamb roast on Saturday will be different 🥲
