37 minutes ago, Dose Pipe Sutututu said:
That's how the NBN is being rolled out lol
lol no, the NBN is being rolled out equivalent to you just saying f**k it and using the cracked o-rings
48 minutes ago, Dose Pipe Sutututu said:
So close yet so far, typical NBNish delivery lol.. Over budget and project schedule blown out of the water.
This is EVERY Government funded project
  • Like 1
  • Haha 2
1 hour ago, iruvyouskyrine said:
Those bolts go at the very back of the head on either side. Do you even RB bro?
No :(
I SR20 more lol...
where exactly????
1 hour ago, Dose Pipe Sutututu said:
are those the cylinder head to block bolts that go on the outside??
That's what I thought they were when I saw the pic. I thought there was one front and one rear though not both at the same end?
Yes correct. 2x M6 bolts
1 at front intake side and 2 at rear either side.
I should note that i never put them back in any of my engines. With RB25's you can't access the front bolt without taking the inlet manifold off which is a shit job which annoys me as i would rather take the inlet manifold off when the head is out of the car.
Yea they didn't go back on my engine either lol
ahhh I installed coppery colours ones back into those holes.. interesting those bolts I took a photo of, I wouldn't' think they would fit as they're wider than the golden/copper ones I used from the R33 motor.
mad, no fear - didn't fk up
Update but no photos (taking inspiration from @luke gtr lol).
Removed R33 plenum, installed bottom half of R34 plenum.
Now awaiting 1550cc Bosch injectors and a Plazmaman rail. The initial plan was to use the 875cc Siemen DEKA V I had from my old motor but anticipating the power this motor will make there's no way those injectors would cut it, even if I ran 4 bar base pressure.
Been trying to order parts again from Andrew @kudos.motorsports but he isn't replying to my emails :(
Update but no photos (taking inspiration from [mention=37584]luke gtr[/mention] lol).
Been trying to order parts again from Andrew [mention=1172]kudos.motorsports[/mention] but he isn't replying to my emails [emoji20]
Nawww, thanks brosef.
1 hour ago, ActionDan said:
Side feed in that boat anchor engine aren't they?
yeah nah cuz.. I had top feeds in there under the stock plenum before they were even mainstream :)
http://www.trak-life.com/diy-converting-top-feed-injectors-r33-gts-t-skyline-rb25det/
Yah... stainless internals, not modified by any laser cutter/mill/bench grinder/side cutters
US guys usually refer to them as Siemens DEKA V 80lb
I hate modified injectors, those "Bosch 1250cc" are milled.
    • I've looked up the parts number (41011AL501). It's around $700 OEM. Usually our Infiniti G35 here in Canada have interchangeable parts with my Stagea but the parts number are not the same. I have looked around and it seems the JDM 2005 V35 Skyline (which is the same as our G35) has the same caliper but I cannot confirm. And I can't find a repair kit. The inner brake pads drags on the rotor, seems to be rusty piston. Thanks for the info by the way
    • This coupled with 6-9 speed autos with ridiculously short gearing is why these modern shitbox cars always seem so fast off the line. If it wasn't for those things, Raptors would not seem fast. The problem we have is there is a driveability gap between a more gentle take off and a wheelspinning sideways launch. The difference between ankle flex required to achieve one and ankle flex required to achieve the other is about 0.5°.
    • Yeah I think I'm also with the opposite here. It's 'hard to keep up with traffic' because in the real world I'm accelerating with 15% throttle and they are pinning it. It feels like I'm being an overt dickhead at anything above 15% throttle, so the car sounds like I'm being an overt dickhead to keep up with/get ahead of traffic when I'm really just trying to drive with traffic. There would be no issue 'keeping up with traffic' if we used the same level of throttle input/aggression to drive around. People really do just drive around with their foot nearly pinned in econoboxes.
    • To be fair it's the other way around. 300kw is boring in a modern Golf or BMW. They are so competent / well-engineered / devoid of emotion that you have to go stupid fast to feel anything. Whereas the <300kw RB still makes all the right noises and it feels good to drive. Can pull off at the lights with the turbo whooshing and the blow-off pssshing and feel like the coolest kid on the block. Just don't look to the side where you'll see the bored housewifes in their shitbox Yaris/Corolla/Camry that kept up because you didn't go fast at all
    • 300kW is so boring in a Skyline, you'll get spanked by someone's mum's Golf with Alibaba pipes, and an email tune.
