  • 3 weeks later...
Round 2 on the oil pump, this time started with a brand new N1 pump, took out N1 gears and popped in Rev. 2 of the Spool Import gears.
Fingers crossed everything goes to plan this time round.
  • Like 3
Didn't take photos, but I realised when I was hanging a shit I popped the rear shim behind the crank timing belt pulley backwards. Spoke to a few people and @NEO25T and they said it should be ok backwards as the belt is front bias and as long as the front (outter most) shim is facing the right way it should be fine. But... Me being me, tore it all down and fitted it properly.
Also last night tightened the sump up, installed cross member, unstrapped the motor, installed castor rods, anti roll bar and all the over bullshit.
Sinco manifold should get here by end of week, just got the shipping details.
Once the turbo rear turbine housing comes, I'll bolt up the lot and work out how I will do the lines. Thinking of fitting a turbo oil filter on the chassis with a P clamp so it's out of the way.
More money to waste, and I am being made redundant end of March lol.
I dont know how u get that back one off without bending it, i just had a quick look on kudos at a new one lol.
After some massaging with the hammer and a few squeezes in the vice to straighten it, mine is uni directional and can go on either way ?
  • Haha 1
Nice! Is this an AWD Stagea motor? noticing the second lot of bolt holes.
Also, have heard in passing before that there's some oil pump installation hack to locate it ideally, as it has a bit of intentional wiggle room that one needs to use, to allow for differences in things like line boring moving your crank location - any ideas if it's true, or an unsubstantiated old wives tale? If true, what's the pro tip to get it optimal.
Edited by Stribs
typo.net
Sure is! Came from an auto Stagea with 168k but the oil looked like tar lol.
So started with some basic item refreshes then somehow a few people twisted my arm a little and eBay had 18% off sitewide then ended up with a built motor ?
The oil pump mating face has 2x locating towels for the oil pump to slide on. I believe the hack is to remove them so you can move the oil pump into the right location using a dealer gauge, however that's only if you need to - which comes from when you tunnel bore the block which "may" shift the crank upwards ever so slightly. I didnt and also using stock bearing clearances so fingers crossed, no more silly oil issues ?‍♂️
  • Like 1
New shit turbo, hopefully doesn't spit out a turbine when I smash the limiter and thrash it's mum.
Still waiting on the rear housing, Sparesbox said may be next week
  • Like 4
1 hour ago, WantGTR said:
Twin scroll fag. Where's your twin gates?
Meh, no need. Waste of money, a single 50mm is plenty for this shit box.
  • Like 1
I hear the 2871 internal gate is a good responsive turbo. Don't get the big rear tho. Too laggy.
Gay turbo, too much compressor wheel vs turbine wheel. Even more gay sex as twins on a GT-R.
Full homo.
    • Was that with the cas upside or correct way up?
    • Did and sync timing with light
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
