  • 3 weeks later...
Round 2 on the oil pump, this time started with a brand new N1 pump, took out N1 gears and popped in Rev. 2 of the Spool Import gears.
Fingers crossed everything goes to plan this time round.
  • Like 3
Didn't take photos, but I realised when I was hanging a shit I popped the rear shim behind the crank timing belt pulley backwards. Spoke to a few people and @NEO25T and they said it should be ok backwards as the belt is front bias and as long as the front (outter most) shim is facing the right way it should be fine. But... Me being me, tore it all down and fitted it properly.
Also last night tightened the sump up, installed cross member, unstrapped the motor, installed castor rods, anti roll bar and all the over bullshit.
Sinco manifold should get here by end of week, just got the shipping details.
Once the turbo rear turbine housing comes, I'll bolt up the lot and work out how I will do the lines. Thinking of fitting a turbo oil filter on the chassis with a P clamp so it's out of the way.
More money to waste, and I am being made redundant end of March lol.
I dont know how u get that back one off without bending it, i just had a quick look on kudos at a new one lol.
After some massaging with the hammer and a few squeezes in the vice to straighten it, mine is uni directional and can go on either way ?
  • Haha 1
Nice! Is this an AWD Stagea motor? noticing the second lot of bolt holes.
Also, have heard in passing before that there's some oil pump installation hack to locate it ideally, as it has a bit of intentional wiggle room that one needs to use, to allow for differences in things like line boring moving your crank location - any ideas if it's true, or an unsubstantiated old wives tale? If true, what's the pro tip to get it optimal.
Edited by Stribs
typo.net
Sure is! Came from an auto Stagea with 168k but the oil looked like tar lol.
So started with some basic item refreshes then somehow a few people twisted my arm a little and eBay had 18% off sitewide then ended up with a built motor ?
The oil pump mating face has 2x locating towels for the oil pump to slide on. I believe the hack is to remove them so you can move the oil pump into the right location using a dealer gauge, however that's only if you need to - which comes from when you tunnel bore the block which "may" shift the crank upwards ever so slightly. I didnt and also using stock bearing clearances so fingers crossed, no more silly oil issues ?‍♂️
  • Like 1
New shit turbo, hopefully doesn't spit out a turbine when I smash the limiter and thrash it's mum.
Still waiting on the rear housing, Sparesbox said may be next week
  • Like 4
1 hour ago, WantGTR said:
Twin scroll fag. Where's your twin gates?
Meh, no need. Waste of money, a single 50mm is plenty for this shit box.
  • Like 1
I hear the 2871 internal gate is a good responsive turbo. Don't get the big rear tho. Too laggy.
Gay turbo, too much compressor wheel vs turbine wheel. Even more gay sex as twins on a GT-R.
Full homo.
    • Whilst the brewery had good beer, I didn't rate the pork knuckle, the meat was good, but, there was no crackling, the skin was just thick and chewy Will return at some stage for the beer, but, I will wash the beer down with chips Plus, no sauerkraut, in what world do people serve pork knuckle without sauerkraut, they did serve apple slaw with it, which was nice, but.......#sauerkraut the world
    • Wow yeah ok. Given how specific you are about your car, I'm very surprised you are happy to do that.  As a bare minimum, without having a wideband gauge in the car or running it up on the dyno to check mixtures, there is no way I'd do that to my car.  You beat me to it, was going to say just this.
    • Yeah - that's not true. Larger turbos flow more at the same boost. By definition. I've always found it funny when the claim of same flow same power because same boost is made. The turbine is larger, therefore will put up a lower restriction to flow at any given flow, cf the stock one. Hence, you need less boost to make the same flow through the whole system. Hence, when you have the same boost as before, you must have more flow. -5s are a pretty decent bit bigger than stock.
    • That's basically how I've been driving my R33 for a while now. GTIII-SS running wastegate boost. It makes no more power than stock because the turbos aren't flowing any more air than stock. Eventually though I need to fix this so it can actually drive as it should.
    • If this was my own car, I would pull about 5 degrees off the CAS, run a wideband, and if that seems ok, send it.
