13 hours ago, niZmO_Man said:
What company? That looks like lazy courier.
Couriers Please, turns out Sparesbox put the wrong address on the box.
I don't even know how that's even possible? The turbo got sent to thr correct address yet thr turbine goes somewhere else?
What the actual frak. Clearly Sparesbox is worse than Mwave
Geeeeee you're a lucky man, it's the world's first Variable Geography Turbo
  • Like 1
  • Haha 2
Got my manifold back from Hi Octane Racing, they powder coated it for $280. Not a bad price, but felt a bit ripped off when I dropped it off and they were like umm can't give you a price now but it will be about $200 to $300.. like a $100 spread? Anyhow $280 later I have a ceramic coated manifold lol.
Started to trim the studs on the head as advised by Sinco, turns out I only needed to trim only 1 not 2, mini win?
Looking the part now, because Shitbox/Spareshit/karntbox aka Sparesmoron sent my friggen turbine housing elsewhere I decided to test fit this turbo.
  • Like 4
3 hours ago, UWISSH! said:
Don’t hi-octane do this shit on a daily basis so they should know exactly how much a 6 cylinder manifold will cost
Yeah I know right? Oh wells, it is what it is but the coating is bloody good though so pretty happy about that.
Now to wait for the rear turbine housing to arrive (whenever that happens), then I'll mock up the lines with some left over bits and bobs  and put together shopping list and go to MSCN for a rape lol.
After that, off to the fabricators then hopefully some skids.
And update, Sparesbox only just realised the housing is just sitting at Couriers Please's depot instead of being returned to Sparesbox ?‍♂️?‍♂️?‍♂️
Is this a 3 Stooges episode?
11 hours ago, admS15 said:
ETA to activities in Mexico?
2 more weeks at work till my redundancy, then it's R33 time till it's done.
Aiming for the shitbox running in 3 to 4 weeks, will test skid then dyno.
  • Like 4
Popped on some studs and trying to determine how to clock the turbo to make sure the oil feed and oil drain clears the manifold.
Looks like I might have to go hard lines, oh wells lol.
  • Like 2
Called in "sick" then went to MSCN to get fittings, hard lines for the turbo setup.
Left wondering why I didn't go to work instead lol.20190320_131440.thumb.jpg.04468a53e276eab286919bba1ba799e4.jpg
  • Like 1
    • It's funny, as Ive seen plenty of people use them in cheap builds on YT. And they actually go okay, even though a lot of other maxspeedingrods stuff is terrible. Those turbos seem reliable enough, the only part being, a good quality turbo that is "identical" to it, will out perform it day in and day out. In both a lower boost threshold, and the ability to flow more air at the same boost pressure. As a cheap cheap replacement, not a terrible choice. For cheap and shouldn't blow in a day, not terrible (like other eBay/Temu turbos) for low cost and still decent performance, that's where the question comes in to play from the results I've seen. I'd actually find it hilarious to buy one, and strap it to a paddock basher or some other cheap as POS originally NA car, and send it to the moon!
    • The maxpeedingrods turbo is cheap and bolts on to stock parts. I think you just need a bigger silicone coupler for the intake. Its a cheap china turbo, but it's been running on mine for almost 3 years at 16-19 psi.
    • What do they look like right after you've tried to start it with everything connected? Also post photos of what they actually look like.
    • Also wanted to say, my new spark plugs are blackened looks like it's very rich. I have splitfire coilpacks but stock coilpack loom and ignitor. I tried directly grounding the ignitor ground to body as well.
    • What do the spark plugs look like after you tried to start it with everything connected?
