Nek level steering wheel lock, saw this in Naples, Italy. Gosh what a shit hole lol... I suggest for anyone considering on visiting not to stay there, if you're going to the beautiful islands just go direct, don't waste your time in Naples (however the pizzas are so cheap it makes no sense, a double scoop of gelato cost more).
I'm back in Australia, didn't get deported or stopped at boarder security!
Needed high heat for this dish and the induction stove top just won't cut it. Used a butane camping stove (with the holes drilled out), and I'm sure now the R33 is covered in oil splatter but at least it smells good.
  • Haha 1
Prev owner was into Auto Salon, hence the car is purple and he used a hammer to roll the guards (the car had wanky 19s on it) he didn't reseal the cracked paint and rust took over. Then when I needed to fit the 18x9.5 +22 with 255 wide semis, I went to town with a guard roller and destroyed both guards.
Also going to reshell next year so don't care :)
Hasn't moved in 2 months, just gets started, rev it a few times. Once it's warm, I commence a few anti-lag hits to spool the turbo and it gets turned off.
  • Like 1
Did one ages before but on shitty tyres, I fear trying in such a small space with semis might propel the car into the Tiguan lol
  • Like 2
  • Haha 3
Rest it up against the tiguan. Then skid.
  • Haha 1
PowerFC delete, Nistune install, upgrade to Z32 street tuna. Ready for dyno in a few weeks, runs an Auto Salon special Garrett GT2871 from the 90s and Tomei Procams.
Owner wants it on 98RON only, should see 230kW to 240kW on crap all timing to preserve the motor.
  • Like 3
Who's keen on buying the car as-is? I cbf, I can tune it before it goes too if the price is right.
OR is anyone keen on the car minus the motor, electronics (ecu, wiring, sensors) and fuel system? I'll leave the rest in (MCAs, KAAZ diff, all the suspension shit,  Bride seat, hectic ulleh stereo.
Clearly over it.
Straight up swap for a 335i F30 M-Sport with under 70k kms.
Getting that modern VW has changed me man, I didn't think it would affect me that much but it has.
The sheer lowdown torque, ridiculous gear shift speeds and luxuries has changed me for good.
    • Hello everyone, I'm glad to join you.
    • Definitely do-able haha. I will give it a try if the fuel pump hanger does not solve the issue. Just need to find some quiet time in the area, Malta is like a big city and I live right next to the main hospital so it is very busy during the day. I'll be installing it in about 2 weeks, found a garage that is pretty knowledgeable and has the necessary tools. This garage has worked on multiple builds, even for competitions. They even asked me to stay with, so I should be fine.
    • Just to add, I found the r32 gtr ecu the most forgiving, the r33 one would get the shits.
    • For what it’s worth I drove my gtr for over a decade with gt-ss as a true daily after I pulled off the -5s, I had it engineered and went with stock ecu etc.  never skipped a beat.    I would only worry if you can’t get good fuel all the time in a tropical paradise
    • I bought an engine from a friend of a friend many years ago, it was sold to me as a RB25det Neo.    recently I started pulling it apart and noticed that the intake manifold was pretty different from others that I had seen on RB engines so did a bit of research and found that it was a non turbo manifold. So I’m sceptical now that it is a NEO DET and just thinking it’s a NEO DE (it does have a turbo strapped to it currently).    can you identify the engine model from the numbers on the block?
