I can probably hook u up for dyno time but its in Wollongong lol.
Dyno dynamics 4wd dyno raised above ground so can be an issue if mega low front ends, but can ramp up if needed
  • Like 1
thanks Jase!
See how despo I get, car needs to be done for mid Nov but I'm going OS soon so leaves me with this weekend only
Time for a build update, so now moved onto the bathroom upstairs.
This build I've enlisted a builder as we only have 1x bathroom so efficiency is important and working on Johnny time isn't going to work out especially as we only have 1x shower in our house.
Tiles and all the shit have been purchased. 1.2m vanity wall hung, 20mm stone top for vanity. 30x60 Porcelain tiles for floor, 30x60 Ceramic for the walls and 10x30 ceramic for the feature wall (vertical brick pattern).
New toilet suite and all taps, fittings and shit. Next to get it built then tuned (taps adjusted lol).
Oh yeah lowered its mum.
Oh no ! No cruising for you for a while cause your cash is going into your bathroom reno !
And the same for me as a alloy Holden 6 Duggan head has popped up on for sale for my other project !
A bit of mould on the beams, but nothing worth replacing as it's not structural.
Next, to re-jig the piping to suit the new shower and all.
Btw, I'm not doing the reno this time. Paying a builder and now heading to the airport to use a bathroom/shower overseas for a week lol.
Made it to the land of Samsung and Korean Fried Chicken.
Also, you're free to help yourself to the beer fridge here and drink as much and as little as you want.
Here's a breakfast beer
And back to build thread, went off topic a bit.
Going full copper tray this time, no more leaks, no more cracked water proofing. This bathroom will outlive me!
Hmmmm . . . . beer and chicken . . .served on what looks like news paper !
Now that takes me back to my childhood with the old fish and chip shop serving the fish and chips wrapped in the Sydney Morning Herald. . . nothing tasted better . . . than news ink with your chips !
Free beer you say, next time I'm peering in your bathroom window I'll knock on the window, or you can just leave a beer on the window sill.
I'm waiting......
So good having the father in law sending updates.
Must say this guy is quick! Now 2x days for it to dry and Monday he's going to tile it's mum.
2 hours ago, Shyboy said:
Coming up nicely ?
No waterproofing?!!
That's next, once the screed dries up!
Living on the edge here, no shaft speed sensors ???
    • neither stumble or cut really seem to be an appropriate term....hard to explain its like a rev limiter but at 4k, but it violently shakes engine and entire vehicle as the rpms will not rise over 4k, even with slow acceleration. as soon as it hits 4k, it sounds like entire spark is lost entirely. plugs were 1.1 which I used as such, but later put in new plugs gapped down to .8 changed back after issue arose when I replaced the coils, still does it with either plug gap...damn and it was all running so good.
    • Oh how times have changed! I actually lean it out relative to my water/methanol injector duty cycle. The methanol adds a lot of fueling and you can then lean it out even more due to reduced knock.
    • Yeah my thoughts are the same, a well thought out WMI setup, would be slightly ahead of just straight E85 and you're also chemically intercooling the charged air, dropping it even further. This is why you need to add so much more fuel as soon as you spray. I remember someone taking me through their set up before (Dennis, has a R33, lives around Cabramatta - no idea if he's still around on this forum). He would target AFR 10:1 on 98, then as WMI ramped on, AFR would lean back up to 11:1. Amazingly, he did this all through his PowerFC, a relay to cut power to his EBC solenoid if there was not enough line pressure on his WMI kit. And of course, if there wasn't any boost made above gate pressure, you wouldn't be accessing the load cells with heaps of timing for WMI. One downside to that rudimentary setup, once the WMI came on, the EBC would unleash the dragon, and of course all the timing. Tyres would fry lol.
    • Shimmed or shimless, still solid, no hydraulic pump up stuff.
    • They have said food will be limited. Mainly meat pies and sausage rolls from memory. But they have a coffee van!
