On 11/24/2019 at 8:42 PM, Dose Pipe Sutututu said:
This week only, $240 for full set of Intima SR brake pads OR $250 for Elig Sports brake pads shipped with Invoice for Sumitomo caipers, i.e. Benshit DB1170 and DB1220.
Happily knock off $30 if you bank transfer (still get invoice, ShitPal takes a massive percentage for payment - so try and avoid)
I'll hit you up in after xmas for a full set of pads & rotors for race car.
  • Thanks 1
Hopefully this is the issue why I keep throwing belts and NOT because of crank harmonics *fingers and testicles crossed*
  • Like 1
3 hours ago, niZmO_Man said:
Should've went all gears setup, remove the belts altogether :P
Should have many thing, such as never getting into cars and putting that money aside for another property, sigh
but where is the fun in that!
Just think about all those memories you wouldn't have
All those near misses that scared the shit out of you at the time, but you laugh at now :)
That's why we drive cars!
You don't get that same feeling from a house
You've obviously never had to swap out a broken valve on a full water tank...
  • Haha 1
Does your house dose? Well unless you get your air conditioning unit or something to dose...
Bloody capable motor with some tinkering. Lots of hate around for VW but they build a brilliant car.
Was surgery for cosmetic enhancement?
Always gotta look sexy behind an ugly R33 lol.
Had some cosmetic work done to my appendix, deleted the useless organ then that followed with a minor bacterial infection with my small intestines so yeah went back to ED 2x days later lol.
Weight reduction ?
  • Like 1
No good mate, glad you're feeling better.
I've had plenty of people say VW make a good car, but I've seen plenty of shit online about them falling to bits.
Do they make anything that isn't a hair dresser car?
  • Like 1
8 minutes ago, Count Grantleyish said:
And does it dose now?
No dose, but I can make it dose lol... probably wife will stab me.
Make it dose and the wife'll forgive you.
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
