Shit Box Specs:
  • Garrett GTX3576R Gen 2, divided 1.01
  • Tomei 260/9.15mm Poocams
  • Sinco Twinscroll manifold, single gate (pulses split all the way to the gate)
  • Turbosmart Gen V 50mm Gate
  • 3.5" TBE with 5" 100 cell cat, mid muffler and rear muffler
    • Gate plumbed in after cat
  • Built blah blah.
I think the power range I guess will be fine then?
Or should I bump the range to 440rwkw to be safe?
Close to 600rwhp seems about right?
Edited by ActionDan
1 hour ago, Dose Pipe Sutututu said:
Shit Box Specs:
  • Built blah blah.
Are you going to fully send it ? What kind of Dyno?  And fuel system big enough to support full send (thinking 1300cc injectors?)
Edited by Lithium
@LithiumMainline roller dyno, will be using 255 semi slicks too LOL.. don't have any other tyres/wheels to use.
Fuel system will be good :)
  • Bosch 1480cc (aka 1500 or 1550 or 1650cc depending who you talk to)
  • 2x Walbro 460L in surge
  • 1x DW200 in tank (lift)
  • 8AN from surge to rail
  • OEM feed & return as return
Not too sure about full send, however let's see. A bit scared the gearbox will go bang instead lol.
  • Like 1
1 minute ago, admS15 said:
452kw and an exploded gearbox within 2 hours of finished dyno session.
LOL as I was typing the above response about gearbox going ka-blam lol
Just stay out of 3rd gear, she'll be right. Otherwise, i have a brand spanking new in box r34gtt gearbox sitting in my shed that may or may not be for sale. Actually, i better hold onto it.
That should be a very solid setup all around if it all cooperates and you aren't shy.   I'll go with 452kw but more or less wouldn't shock me
@admS15 will need to, will find a pair before the dyno day.
@Lithium kind of pulling my finger out because I have a track day to attend (gift from the S15 owner I tuned recently).
1 minute ago, ActionDan said:
Just saw your fuel system, downgraded power now because using pleb brands.
I know, at least 50kW less now because not ID injectors and mechanical pump.
On 5/30/2020 at 4:13 PM, Dose Pipe Sutututu said:
Why not, celebrate driving the R33? Great excuse to open it.
We are coffee pals. I have the same machine (well actually the cheaper one without an LCD).
Mine has been going strong for 5 years. It's been through three offices and now makes my morning coffee without fail.
Literally the greatest little coffee machine i could have asked for. I trust yours is going just as strong?
  • Like 1
    • Wanted to add some of my R33 GTST  R34 GTR wheels, 18x9 ET30 with 255/35/R18 PS4S'   BBS RE-V7 029 18x9.5 ET22 with 255/35/R18 PS4S' Needs a bit of camber
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
