Shit Box Specs:
  • Garrett GTX3576R Gen 2, divided 1.01
  • Tomei 260/9.15mm Poocams
  • Sinco Twinscroll manifold, single gate (pulses split all the way to the gate)
  • Turbosmart Gen V 50mm Gate
  • 3.5" TBE with 5" 100 cell cat, mid muffler and rear muffler
    • Gate plumbed in after cat
  • Built blah blah.
I think the power range I guess will be fine then?
Or should I bump the range to 440rwkw to be safe?
Close to 600rwhp seems about right?
Edited by ActionDan
1 hour ago, Dose Pipe Sutututu said:
Shit Box Specs:
  • Built blah blah.
Are you going to fully send it ? What kind of Dyno?  And fuel system big enough to support full send (thinking 1300cc injectors?)
Edited by Lithium
@LithiumMainline roller dyno, will be using 255 semi slicks too LOL.. don't have any other tyres/wheels to use.
Fuel system will be good :)
  • Bosch 1480cc (aka 1500 or 1550 or 1650cc depending who you talk to)
  • 2x Walbro 460L in surge
  • 1x DW200 in tank (lift)
  • 8AN from surge to rail
  • OEM feed & return as return
Not too sure about full send, however let's see. A bit scared the gearbox will go bang instead lol.
  • Like 1
1 minute ago, admS15 said:
452kw and an exploded gearbox within 2 hours of finished dyno session.
LOL as I was typing the above response about gearbox going ka-blam lol
Just stay out of 3rd gear, she'll be right. Otherwise, i have a brand spanking new in box r34gtt gearbox sitting in my shed that may or may not be for sale. Actually, i better hold onto it.
That should be a very solid setup all around if it all cooperates and you aren't shy.   I'll go with 452kw but more or less wouldn't shock me
@admS15 will need to, will find a pair before the dyno day.
@Lithium kind of pulling my finger out because I have a track day to attend (gift from the S15 owner I tuned recently).
1 minute ago, ActionDan said:
Just saw your fuel system, downgraded power now because using pleb brands.
I know, at least 50kW less now because not ID injectors and mechanical pump.
On 5/30/2020 at 4:13 PM, Dose Pipe Sutututu said:
Why not, celebrate driving the R33? Great excuse to open it.
We are coffee pals. I have the same machine (well actually the cheaper one without an LCD).
Mine has been going strong for 5 years. It's been through three offices and now makes my morning coffee without fail.
Literally the greatest little coffee machine i could have asked for. I trust yours is going just as strong?
  • Like 1
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
