20 hours ago, Dose Pipe Sutututu said:
 Also got my cam trigger to sync quicker,l on crank, the arming voltage was too highPXL_20221015_102840698.thumb.jpg.f5dbd8e6f2089655b32d6f91ddec66c1.jpg
Waiting to fit one of these NZ cam triggers to the white 32. I see your post on the Haltech forum when you were having problems getting it to work. I take it the problem was they were sending the sensor out pinned to the cam signal instead of crank correct ?
16 hours ago, Piggaz said:
If you know it’s going to sit for a while, why not drain the e85 and run some 98 through it. A fitting off your fuel rail and some hose into a Jerry can.
It gets driven once a month lol...
Even if I drive it once a week, I still add in that additive. So far (past motors, setups, etc.) I've never had injectors gum up or seize, so it might work? (Or it's a scam and I'm donating money to the Lucas Oil execs)
It was initially pinned wrong by NZ Wiring then as I was troubleshooting, Haltech support advised to feed the reluctor 5V power, which is actually incorrect.
The reluctor actually generates it's own voltage.
I will confirm how I've wired it in a bit. Actually can't remember right now lol.
I got mine after @Dose Pipe Sutututu and had no issues with the pinning of it so may have a been an early issue or someone was a bit lazy that day.
Cheers for posting the arming voltage too as mine takes a few goes to fire on first crank. Fuel and timing haven't helped so will try this.
You use a link right ? The link you can reassign the cam signal cable to actually be the crank reference signal. On an Elite you can't as it is a fixed pin on the ECU, so they were sending them out preconfigured for link wiring on cas wiring pins 1 and 3.
Yes a reluctor generates its own voltage. Can't believe Haltech told you to supply it 5v !
From what I can see the neg reluctor side needs to be pinned to ground and the pos side signal output pinned to the Elite TRIGGER +, so on a cas loom that would be the 2 outside pins 1 and 4.
The way NZ wiring is sending them out appears that they are pinning the signal to the HOME + which will never work on an Elite unless you swap the pins at the ECU end which you don't need to do.
  • Like 1
Okay so some slight digging, you essentially pin it to GND and Trigger 1 (Link ECU reference). Trigger 2 is unused, I suspect that's the home signal.
Rb25Det Cas S1/s2 - Forced Induction Performance - SAU Community
12V is unused in this instance.
@robbo_rb180 got mine to start first go yesterday, but it does need a fair amount of cranking. I suspect it "might" want more fuel on crank.
I also went to town with the pulse prime, get those runners nice and moist when it's cold lol
Also tried adding more timing on crank, I think it makes it a bit harder to crank, will drop it all to 0s this week and try again
  • Like 1
5 minutes ago, BK said:
They way NZ wiring is sending them out appears that they are pinning the signal to the HOME + which will never work on an Elite unless you swap the pins at the ECU end which you don't need to do.
I'll go have a look and take a photo in a bit
That's the problem for the Haltech that they pin it to Trigger 1, which is actually your home + reference in physical wiring. This needs to be pinned to trigger 2 in the above diagram which is physically crank trigger position +.
I’m interested in this also..
just FYI, these are my wiring notes:
Elite 2500 wiring:
pin B1 = trigger + (black wire on sensor)
pin B5 = trigger - (white wire on sensor)
I also checked this with Scott from Haltech..
is this how you have it?
B5 Trigger - is not pinned from the rb Elite patch loom to the engine harness, but shouldn't matter as the ground wire on the cas loom is also a common signal ground which is also what the Link uses as its signal ground. The engine position should only need to be referenced onto B1 Trigger + so no ECU repining needs to be done.
Ah, sorry I am using one of their terminated harnesses. I checked continuity with multimeter back to the ECU pins to confirm they are connected
Elite 2500 wiring:
Just went to take a photo, I'm colour blind too so can't really tell what the 4th wire is, it's blue and something? LOL..
I'm using 1st wire as sensor GND and the 3rd wire (which is covered in heat shrink) as Trigger.
And yes, I should re-terminate that plug, I have a spare one to go on too - just forgotten about it.
in pic
Top - Black, then cream (white at some stage lol), then thick black, then bottom blue with green stripes (or green with blue stripes haha)
  • Haha 1
At least I’m not the only one they color blind, going to make it a nightmare wiring the engine up when the time comes lol
  • Haha 1
When I used to do quite a bit of wiring (when I was younger, didn't have back pain and had plenty of spare time) I would actually take photos and send it to my girlfriend at the time (wife now) and ask her what the colours were LOLOLOL.
  • Like 2
  • Haha 1
That’s basically my plan, every time I cant work it out I’ll get my mrs to tell me what it is
  • Haha 2
it's true we are hopeless without the missus!
    • You now say stumble, but you said cut out before. Will it slow rev through the cut/stumble? What gap were your spark plugs set to when you them in?
    • I had double clamped all the pipes but I checked them over any way, everything tight and secure. feels and sounds like a electrical short/failure, as it is an abrupt and aggressive stumble, that instantly comes and goes right at 4k mark...like clock work fuel pump and filter are new new coils and plugs injectors where cleaned and tested 200 miles plus ago no black smoke cleaned MAF   same results, other ideas? some other sensor?
    • Yes, just without the annoying use of the word hybrid. We stopped using that term 20 years ago when we realised it meant different things to different people. Even "highflow" can represent more than one way of achieving the goal of getting more flow out of a turbo. But at least it says what it does on the box.
    • OH, when they say "solid buckets", I always interpeted that as "shimless". (Which is not the same as the "shimness word I invented above to represent the same idea that the buckets act as shims also!!). Still the same problem though. So it appears that buying a "kit" from Tomei is a two step process. Makes sense. Doesn't make sense in the context of a "kit" though.
    • Wanted to add some of my R33 GTST  R34 GTR wheels, 18x9 ET30 with 255/35/R18 PS4S'   BBS RE-V7 029 18x9.5 ET22 with 255/35/R18 PS4S' Needs a bit of camber
