2 hours ago, MBS206 said:
It wasn't a pandemic in 2019 either. Someone said that statement, and how'd that turn out for us?! 😛
In beginning of March 2020 it was still a running joke, mid March it went to shit
Shit box survived all 7 sessions of hooning and circuit.
Didn't get a clean run on any of the sessions as there was a bit of traffic. Camber changes did make a massive difference and ended up going into T1 at 160km/h without the front washing out so happy with that!
Some eFame shots of the shit box.
348604191_1627263241111145_6932192459068028973_n2.thumb.jpg.6601db55192b3c2890b5bedefa7d1def.jpg
347620379_2212839058920237_4999811960215461977_n.thumb.jpg.f40e39d9f4b6dd97ec936f470c74bcf6.jpg
  • Like 5
Just now, ActionDan said:
Racing is all about WOTIF
Guess you better go race again ;)
haha next All Jap Day!
Meanwhile, I'm trying to work out what night I can go attack SMSP again, I am keen on a low 1m50s around the circuit with RS-4 tyres.
I feel that I am happy with how the car handles now, the front camber made a massive difference! Now it's just practice and more of it.
  • Like 3
I'm just glad to see you using the car.
I'm feeling slightly more motivated again, but wont get back to tub work until the XR5 engine is sealed to avoid contaminating it.
1 minute ago, Jasoncauser said:
Sweet, this is why you built it man! Go send it :)
I dont have headlights on the 32 so cant do the night runs :(
I suppose so, I also still hate the car. If someone walked up to me and asked for a straight swap with a M2/3 Comp I would do it in microseconds.
LOL... why aren't there headlights?
It's a bit like that, you see another working car and it gives you a bit more motivation. I did cheat and drop it off at a shop to do all the heavy lifting this time round.
Is that just a refresh on the XR5 OR full build?
The bucket I picked up for $500 with multiple spun bearings so I could try my hand at an engine build and teach the kids. It's just a stock refresh with some added block mod shims between the liners for if someone wants to lean on it harder later.
If it runs it'll cost me easy 5-6k in the end by the time I replace DMF/Clutch setup etc but could end up with a semi cool car to daily then swap/sell off for something else rinse/repeat as I'm sick of driving the 4wd daily.
It's manual, turbo, bucket seats, nice electrics etc and running is hopefully worth more than it cost me.
If it blows up on first start or I dont get it running, I will part it out, go back to Silvia and buy something else to daily (335i? 545i?).
Anyway, learning lots, I think?
  • Like 2
I should add, bad choice for a learning platform, FWD, 5cyl, Euro... not the easiest car to work on at all, it was like 10hrs to remove the entire front subframe with engine/box attached to get the engine out, I am dreading reinstall...
I really should have bought an XR6T or something, shit even an NA one.
  • Like 1
I
Funny story,
it was at the mechanics workshop sitting in the carpark and the drivers glass just fell off, he got it on his security camera lol. and the price of a replacement is just a joke, so we did this
@ActionDan well it is a Volvo afterall lolol
Hopefully home stretch to get it back on the road and dose city.
@Jasoncauser LOL how does a headlight just fall off lolol
Nope, I'm still mic'ing bearings because I "had to be sure" and double check the machine shops work.
That meant buying a mic and learning how to use it and associated tools lol
Oh then there was the 12hrs or so I spent weight matching the piston/rod assemblies because I "had to be sure" and weighed them all and found up to 8g difference....
Could've stopped at 3g like the machine shop said for a street engine, but "had to be sure" and went to 1g....
Shoot me.
  • Like 1
  • Haha 1
Because someone's been in there before you. They are a pain to pull apart from factory, no chance factory goop stopped gooping suddenly
Just now, Duncan said:
Because someone's been in there before you. They are a pain to pull apart from factory, no chance factory gooped stopped gooping suddenly
Yeah we thought the same when we looked at the glass channel lol
we did toy with the idea of putting lights in the panels we made but will just get those Motive headlight ducts down the track
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
