35 minutes ago, Murray_Calavera said:
What's the news?
The ic7 will be firmware updated to allow 2-way CAN communication allowing additional inputs for the ECU. It will also be a master device now, so I believe it can act as a controller for the PDM. You can also customise logos etc.
  • Like 2
Pretty much no need for an I/O expanded if you have a dash.
Also, there may be a new Haltech dash coming in the future, I hope they update the housing lol.
That's the only reason why I didn't buy an IC-7, I know it's silly, sure it's ugly but the car itself is pretty ugly too LOL.
Yeah, I think they are bringing out a bigger display. I think a 10”??
the ability to programme the buttons on the display is pretty good too.
One can hope, if not I'll just get an IC-7 and stop sooking.
Loaded up the latest firmware, oh wow... went for a drive and it's like I've setup Alpha-N and MAP compensation. I thought the transient table I built was good, but wow... this just brought it to another level.
@R3N3 this is how I make the car brap lol.. sounds better than rotational idle
Nice little timing hole lol
And for the idle control you want it to not much between -50 ~ -100 RPM
Awesome! I will compare the sound. I ended up dialling in the launch and rotational idle 100% many bangs and flames were had. Although I’m a little worried about my stock oil pump gears…
  • Haha 1
1 minute ago, Dose Pipe Sutututu said:
Didn't you want to build a new motor? LOL.
Haha, true! The plan is to switch out a working motor with another working and better motor…
Last time @admS15 used his launch control, he lost a turbine LOL.
On 08/10/2023 at 1:38 PM, Dose Pipe Sutututu said:
Washed the shit box, forth wash since the start of 2021 when the respray was done.
As much as you like to complain about it, your car is a looker! Is this photo with new tints? Which ones did you end up going with?
It's on my list of things to do, though not at the top. Being able to see nothing at all out of the windows when it's dark and wet outside gets old very quickly.
I work in IT, complaining is a prerequisite LOL.
I went with a legal 35% tint, it's some ceramic bullshit (apparently good?). Got it done by Tint a Car in Moorebank.
  • Like 1
Haha, fair enough. Yeah ceramic is meant to be better with keeping off heat. Or so I learned doing all of five minutes of research.
But for some reason the extra photos you included in your post that show the new tint don't load.
    • You now say stumble, but you said cut out before. Will it slow rev through the cut/stumble? What gap were your spark plugs set to when you them in?
    • I had double clamped all the pipes but I checked them over any way, everything tight and secure. feels and sounds like a electrical short/failure, as it is an abrupt and aggressive stumble, that instantly comes and goes right at 4k mark...like clock work fuel pump and filter are new new coils and plugs injectors where cleaned and tested 200 miles plus ago no black smoke cleaned MAF   same results, other ideas? some other sensor?
    • Yes, just without the annoying use of the word hybrid. We stopped using that term 20 years ago when we realised it meant different things to different people. Even "highflow" can represent more than one way of achieving the goal of getting more flow out of a turbo. But at least it says what it does on the box.
    • OH, when they say "solid buckets", I always interpeted that as "shimless". (Which is not the same as the "shimness word I invented above to represent the same idea that the buckets act as shims also!!). Still the same problem though. So it appears that buying a "kit" from Tomei is a two step process. Makes sense. Doesn't make sense in the context of a "kit" though.
    • Wanted to add some of my R33 GTST  R34 GTR wheels, 18x9 ET30 with 255/35/R18 PS4S'   BBS RE-V7 029 18x9.5 ET22 with 255/35/R18 PS4S' Needs a bit of camber
