CAR won't start after POD SWAP
So I originally had a BLITZ Pod filter on and decided to change it to a K&N Pod, and it was driving okay till about 20mins after a spirited run, at a red light it jumps into some sort of limp mode where I can't rev it over 2000Rpm even on Neutral. Had to make it home on 40kms. Engine light came on as well :S
Its a R34 GTT Automatic 98
I have tryed resetting the ECU (battery disconnect) same results.
I then swapped back my BLITZ Pod and now the car won't start at all, could it be my AFM ??
Edited by Jonic
https://www.sau.com.au/forums/topic/468069-car-wont-start-after-pod-swap/
You ask for help and then ignore most suggestions. Work methodically and properly eliminate each potential problem. About every third suggestion is the MAF, Did you actually get a new one? If not try this:
http://skylinefiles.blogspot.co.nz/2009/07/how-to-fix-your-rb-afm.html
and if that doesn't help then check the plug.
I just got my new AFM genuine and nope still same problem what a load of shitz, I tried starting without the AFM and it idles perfectly and with the AFM it readjusted itself and stayed on after I plugged it in while the car was running. Still won't let me go over 2000rpms zz
  • 4 weeks later...
2 hours ago, Jonic said:
It was the coolant temp sensor. Everyone is so clueless lol
Considering you created three threads for issues, don't expect further help with attitude like that. Remember, the people on here helping you are regulars and will remember you.
my apologies to everyone, i did everything you guys told me but i still couldn't diagnose it and got frustrated cause it felt like I was the only one getting this problem on a Skyline and nothing was working. So excuse my attitude if you guys got insulted in anyway. Peace
  • Like 1
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
