Oil - RB26
Hi Guys,
After a confusing couple months as a new GTR owner, trying to seek information on the best oil to use for daily (and occasional spirited) driving on a stock as a rock rb26, i ended up with the biggest headf**k of the century.
Basically this is what i got:
Reputable tuner recommendations: Castrol Edge 10w-60
Reputable workshops: Motul x8100 or H-tech 10w-40 (or if you can afford it Nismo oil)
Nissan track enthusiasts: Motul 300v 10w 40
Autobarn: Motul 10w-40, castrol edge 10w-60, Penrite 15w-50 racing
SAU Forums: All of the above + penrite hpr, royal purple, redline etc.... (keep in mind some of these topics were from 10+ years ago, im sure there have been advancements since then)
So i decided to do my own investegation and research on the oils and how they behave in my car.
Firstly i eliminated the motul 300v/nismo oils from the list as it would have limited return on investment, especially if you change your oils every 2500-5000ks, in addition the 300v oils do not have the proper detergents for daily driving, From what i can see i believe the 300v is engineered for track use only.
I decided to try 3 most commonly recommended oils: Castrol edge 10w-60, Motul x8100 and Penrite 15 racing. All 3 oils possess marginal differences in terms of lubrication qualities, espeically with daily driving. Things i tested was oil pressure (normal and spirited driving), oil temperature (25 degree day), engine noise, oil burned.
Here are the results so far:
Motul x8100 10w-40:
Oil temp: 79 degrees normal driving minimal traffic
Oil pressure: 2.2kg idle, 4kg @ crusing speeds
engine noise (once warmed up): ?
Oil burned(end of 5000ks service): None
Castrol edge 10w-60
Oil temp: 81 degrees normal driving
Oil presusre: Same as above
Engine noise: Quieter lifter noise than motul - Viscosity or forumla?
Oil burned: None
Oil pressure: Same as above
Engine Noise: same as Motul
Oil burned: None.
Fuel economy was the same across all oils. I tried keep the tests as consistent as possible, obviously its not the most reliable of tests but it can be used as a good initial reference to newbie GTR owners like myself .. One thing i found strange was that the oil pressure was the same across all brands and viscosity, unless theres some oil pressure regulator system im unaware of ,it is puzzling.. That being said by the end of it, i came to the conclusion that all 3 are good as they provide similar results. I have kept the bottle of the oils i have tested and will probably get some samples professionally tested and post them here to see which oil would be best suited for a rb26.
Edited by Deza3000
Grammar
https://www.sau.com.au/forums/topic/468940-oil-rb26/
There's plenty of information in the current oils thread if you haven't already had a read.
My thoughts are that you can use any group IV oil and buy whichever is on special as some can be nearly double the cost (Motul vs Castrol etc)... I'm skeptical that you would find a major difference between any of the big brands in terms of wear/performance. Fuel economy is going to be similar with most oils, it's not a factor even worth considering as the improvement will be 2-3% at best.
In saying that, I wouldn't mind seeing the tests. But what would you use as an indicator for the 'best' oil?
Edited by owen1r
  • Like 2
https://www.sau.com.au/forums/topic/468940-oil-rb26/#findComment-7809184
Yep read the forums, everyone has their own opinions and different modifications (i.e. built motor) done to their car, which led me to believe that there is a reason they chose a particular oil brand for their car. That being said, i agree it was all the same anyway.
I used the term "best" very loosely, coming from an evo, most drivers use similar spec oil (10w-40 for street, 50 weight for track), where as the GTR, oil recommendations were very broad, and reading up on oil starvation issues i was getting rather paranoid as to whether i chose the right oil for my car, hence why i went my own way and tested the top 3 recommended oil. Seeing as castrol edge 10w-60 is always on sale, ill probably just opt for that from now on.
https://www.sau.com.au/forums/topic/468940-oil-rb26/#findComment-7809190
I use Motul 300V and unlike apparently most of you I change it after 20,000km (including track days). I have sent samples for oil analysis and the results have suggested there is no reason to change it more often.
  • Like 2
https://www.sau.com.au/forums/topic/468940-oil-rb26/#findComment-7809361
I covered the range of scenarios with running Penrite Premium 5 (5W-60) muhuhahaha. But that oil harder to find these days.
I also ran Racing 10 (10W-40), which overheated (twice) on the track. Oil held pressure fine the whole time, so I use Racing 10 now on my Subaru as well (buy a few bottles when on special).
  • Like 1
https://www.sau.com.au/forums/topic/468940-oil-rb26/#findComment-7809367
Got those oil analysis results by any chance? Wouldn't mind a look.
https://www.sau.com.au/forums/topic/468940-oil-rb26/#findComment-7809389
This is the only one I can find ATM. When they email them to me I ring them back to get them to explain them to me.
Oil Test 2011.09.28 1000km.PDF
  • Like 2
https://www.sau.com.au/forums/topic/468940-oil-rb26/#findComment-7809520
Same here but i do mine at 10k ish instead of the 3-5 k change. . And that's also on semi synthetic and not fully :)
https://www.sau.com.au/forums/topic/468940-oil-rb26/#findComment-7809557
Dessa.
Re your topic on best oil for gtr.
I heve been using nulon ow_40 engine oil in my gtr for some years.found it to be an excellent oil.. no need to top up oil in car. Change oil every 5000 ks
Oil pressure remains constant
Would highly recommend
Cheers
Sent from my SM-G928I using SAU Community mobile app
  • Like 1
https://www.sau.com.au/forums/topic/468940-oil-rb26/#findComment-7809632
I like that you dont throw away expensive oil that's in good condition. There should be more of this good sense.
  • Like 2
https://www.sau.com.au/forums/topic/468940-oil-rb26/#findComment-7809778
yes, but "if in doubt, throw it out!"
without doing an oil analysis, it's just guessing. While I appreciate OP's effort to bring some science through looking at oil temp, pressure and lost oil, that is really only scratching the surface. On the other hand, an oil analysis is a hell of a lot cheaper than an unnecessary change of these expensive oils.
BTW, for road use....use anything and change it often. No point spending $100 on oil changes when it's not getting tested at all.
  • Like 2
https://www.sau.com.au/forums/topic/468940-oil-rb26/#findComment-7809782
    • The other problem was one of those "oh shit we are going to die moments". Basically the high spec Q50s have a full electric steering rack, and the povo ones had a regular hydraulic rack with an electric pump.  So couple of laps into session 5 as I came into turn 2 (big run off now, happily), the dash turned into a christmas tree and the steering became super heavy and I went well off. I assumed it was a tyre failure so limped to the pits, but everything was OK. But....the master warning light was still on so I checked the DTCs and saw – C13E6 “Heat Protection”. Yes, that bloody steering rack computer sitting where the oil cooler should be has its own sensors and error logic, and decided I was using the steering wheel too much. I really appreciated the helpful information in the manual (my bold) POSSIBLE CAUSE • Continuing the overloading steering (Sports driving in the circuit etc,) “DATA MONITOR” >> “C/M TEMPERATURE”. The rise of steering force motor internal temperature caused the protection function to operate. This is not a system malfunction. INSPECTION END So, basically the electric motor in the steering rack got to 150c, and it decided to shut down without warning for my safety. Didn't feel safe. Short term I'll see if I can duct some air to that motor (the engine bay is sealed pretty tight). Long term, depending on how often this happens, I'll look into swapping the povo spec electric/hydraulic rack in. While the rack should be fine the power supply to the pump will be a pain and might be best to deal with it when I add a PDM.
    • And finally, 2 problems I really need to sort.  Firstly as Matt said the auto trans is not happy as it gets hot - I couldn't log the temps but the gauge showed 90o. On the first day I took it out back in Feb, because the coolant was getting hot I never got to any auto trans issues; but on this day by late session 3 and then really clearly in 4 and 5 as it got hotter it just would not shift up. You can hear the issue really clearly at 12:55 and 16:20 on the vid. So the good news is, literally this week Ecutek finally released tuning for the jatco 7 speed. I'll have a chat to Racebox and see what they can do electrically to keep it cooler and to get the gears, if anything. That will likely take some R&D and can only really happen on track as it never gets even warm with road use. I've also picked up some eye wateringly expensive Redline D6 ATF to try, it had the highest viscosity I could find at 100o so we will see if that helps (just waiting for some oil pan gaskets so I can change it properly). If neither of those work I need to remove the coolant/trans interwarmer and the radiator cooler and go to an external cooler....somewhere.....(goodbye washer reservoir?), and if that fails give up on this mad idea and wait for Nissan to release the manual 400R
    • So, what else.... Power. I don't know what it is making because I haven't done a post tune dyno run yet; I will when I get a chance. It was 240rwkw dead stock. Conclusion from the day....it does not need a single kw more until I sort some other stuff. It comes on so hard that I could hear the twin N1 turbos on the R32 crying, and I just can't use what it has around a tight track with the current setup. Brakes. They are perfect. Hit them hard all day and they never felt like having an issue; you can see in the video we were making ground on much lighter cars on better tyres under brakes. They are standard (red sport) calipers, standard size discs in DBA5000 2 piece, Winmax pads and Motul RBF600 fluid, all from Matty at Racebrakes Sydney. Keeping in mind the car is more powerful than my R32 and weighs 1680, he clearly knows his shit. Suspension. This is one of the first areas I need to change. It has electronically controlled dampers from factory, but everything is just way too soft for track work even on the hardest setting (it is nice when hustling on country roads though). In particular it rolls into oversteer mid corner and pitches too much under hard braking so it becomes unstable eg in the turn 1 kink I need to brake early, turn through the kink then brake again so I don't pirouette like an AE86. I need to get some decent shocks with matched springs and sway bars ASAP, even if it is just a v1 setup until I work out a proper race/rally setup later. Tyres. I am running Yoko A052 in 235/45/18 all round, because that was what I could get in approximately the right height on wheels I had in the shed (Rays/Nismo 18x8 off the old Leaf actually!). As track tyres they are pretty poor; I note GTSBoy recently posted a porker comparo video including them where they were about the same as AD09.....that is nothing like a top line track tyre. I'll start getting that sorted but realistically I should get proper sized wheels first (likely 9.5 +38 front and 11 +55 at the rear, so a custom order, and I can't rotate them like the R32), then work out what the best tyre option is. BTW on that, Targa Tas had gone to road tyres instead of semi slicks now so that is a whole other world of choices to sort. Diff. This is the other thing that urgently needs to be addressed. It left massive 1s out of the fish hook all day, even when I was trying not too (you can also hear it reving on the video, and see the RPM rising too fast compared to speed in the data). It has an open diff that Infiniti optimistically called a B-LSD for "Brake Limited Slip Diff". It does good straight line standing start 11s but it is woeful on the track. Nismo seem to make a 2 way for it.
    • Also, I logged some data from the ECU for each session (mostly oil pressures and various temps, but also speed, revs etc, can't believe I forgot accelerator position). The Ecutek data loads nicely to datazap, I got good data from sessions 2, 3 and 4: https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-2?log=0&data=7 https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-3?log=0&data=6 https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-4?log=0&data=6 Each session is cut into 3 files but loaded together, you can change between them in the top left. As the test sessions are mostly about the car, not me, I basically start by checking the oil pressure (good, or at least consistent all day). These have an electrically controlled oil pump which targets 25psi(!) at low load and 50 at high. I'm running a much thicker oil than recommended by nissan (they said 0w20, I'm running 10w40) so its a little higher. The main thing is that it doesn't drop too far, eg in the long left hand fish hook, or under brakes so I know I'm not getting oil surge. Good start. Then Oil and Coolant temp, plus intercooler and intake temps, like this: Keeping in mind ambient was about 5o at session 2, I'd say the oil temp is good. The coolant temp as OK but a big worry for hot days (it was getting to 110 back in Feb when it was 35o) so I need to keep addressing that. The water to air intercooler is working totally backwards where we get 5o air in the intake, squish/warm it in the turbos (unknown temp) then run it through the intercoolers which are say 65o max in this case, then the result is 20o air into the engine......the day was too atypical to draw a conclusion on that I think, in the united states of freedom they do a lot of upsizing the intercooler and heat exchanger cores to get those temps down but they were OK this time. The other interesting (but not concerning) part for me was the turbo speed vs boost graph: I circled an example from the main straight. With the tune boost peaks at around 18psi but it deliberately drops to about 14psi at redline because the turbos are tiny - they choke at high revs and just create more heat than power if you run them hard all the way. But you can also see the turbo speed at the same time; it raises from about 180,000rpm to 210,000rpm which the boost falls....imagine the turbine speed if they held 18psi to redline. The wastegates are electrically controlled so there is a heap of logic about boost target, actual boost, delta etc etc but it all seems to work well
    • hahah when youtube subscribers are faster than my updates here. Yes some vid from the day is up, here:  Note that as with all track day videos it is boring watching after the bloopers at the start.  The off was a genuine surprise to me, I've literally done a thousand laps around the place and I've never had instability there; basically it rolled into oversteer, slipped, gripped and spat me out. On the way off I mowed down one of the instructor's cones and it sat there all day looking at me with accusing cone eyes as I drove past. 1:13:20 was my fastest lap, and it was in the second session, 3rd lap.  It (or me!) got slower throughout the day as it got hotter.
