rb26 rebuilt engine with exceptional attention to detail
Hi,
I've had my r33 rb26 engine totally rebuilt including head.
Unlike many rebuilds, nothing has remained untouched and all screws, metal parts, springs have been cleaned, polished, electrocoated.
Some components have been sandblasted and painted or powder coated.
All machining work performed by orger who worked on the r32s that ran in the v8 championships.
New end spring plastic brackets were machined for throttle bodies.
The motor has not been started and sits in a RWD 300zx.
The project has blown out and while in no rush, I'm considering selling and SEEKING EXPRESSIONS OF INTEREST.
Engine owes me over 30k, so will say asking for 30 and open to reasonable offers.
Located near chadstone in VIC.
Please no low ballers as you will be ignored :-(
Engine details;
Ferrea OS Valve set rb26
ferrea double valve spring set rb26
ARP head studs RB26
Camtech camshafts - 274 degree with 9.35mm lift
OEM Timing Belt
Timing Belt Tensioner (both)
2 x RPM Adjustable Camshaft Pulley
Nitto I-beam conrods
Nitto Oil Pump
headgasket nitto drag series
nitto intake & exhaust gasket
ITB block water fitting
exhaust studs x 10
3x water hoses
Davies craig EWP alloy
JE Pistons & Rings
Main studs ARP
Head studs ARP
Main bearing set
piston ceramic coating
Misc
Acid clean block
welsh plugs
crack test block
crack test crankshaft
remove crankshaft oil gallery plugs
clean & linish crankshaft
Modify oil galleries for NPT plugs
Strainer plate
line hone
conrod alignment
conrod size check
check s/e clearance
check bearing clearance
Mock Assemble
squish areas in chambers
dismantle final clean & re assemble
check compression 8.5 - 1
block surface
balance full engine
check and dispatch
NO SUMP.
Accessories;
BPP fuel rail is twin entry 14mm rail
6 x Bosch EV14 1000cc injectors adaptors filters seals plugs (Flow Matched)
Heat treated manifold
Precision 6466 and 46mm dual gates plumbed back into dump
Stick with the project mate. Unfortunately you'll never get your money back for what you've spent so finish it off and get some enjoyment out of it!
  • 3 weeks later...
What sort of boost/bar is this engine designed for? I spent $14k on my engine and no one will buy it. Just keep it! Never get money back on engine builds. The engine is worth 10-12k worked.
  • Like 1
Hi guys, yeah selling anything is an undesirable experience these days.
Reasonable offers are within reach of asking price.
Prior to starting this build thought long and hard as knew it would be expensive, but as most have experienced it somehow always blows out.
I also looked high and low on here and the web for 12+ months so know that what i have is special and wont be replaceable if i sell this so in no rush.
Motor and parts are capable of big power but i went for injectors that would supply more than enough initial power.
If you look up my turbo setup on youtube its very impressive on an rb26.
So while listed for sale as many before me will attest to, not overly excited about selling it, but will if price is right.
Cheers
Paul
  • 3 weeks later...
  • 1 month later...
  • 1 month later...
  • 2 months later...
Currently not listed anywhere else nor have I been pushing to sell it. That said open to reasonable offers.
Not interested in splitting up motor, but will consider selling motor without hotside or clutch..
I've seen a lot of builds and only 1 other motor was to this standard.
Not only is this built for power but every single piece has been cleaned, polished or re-coated making it look new again.
  • 1 month later...
Hi, the motor has not been started as still needs to be wired up and needs a custom sump for its RWD application.
Its sitting in a z31, so would be much cheaper and faster dropping this into a GTR.
Its capable of much more but my end goal was around 550-600kw. Current injectors will apparently give you around the 400kw mark which build will do with ease.
There have been no shortcuts taken on this motor as there was no intention of selling it.
Cheers,
Paul
    • Hi from Canada, Both of my calipers are starting to fail. My car is a 2005 M35 Stagea ARX and I can't seem to find any parts or any cross reference caliper that would fit my car. Is there a company or a similar caliper that would fit and I could replace the OEM one. Or if anyone knows where I can find a new OEM. Any help is very appreciated. Let me know!
    • Maf is a question mark but TPS  I have set at 0.47, the fact that I’m getting proper voltage range out of it with the key on leads me to believe it’s functioning properly. I’m getting proper voltages on basically everything. I still need to look up voltage ranges for z32 maf and test that
    • Honestly no not at all, but it’s a very basic tune, it’s stock injectors q45 tps and z32 maf. Other than that it’s a completely stock base map. The file is from nistune and from my understanding if it was tune related I would be able to unplug maf and tps and it would still start even if it was a really shitty start. I have tried starting it with coolant temp, maf, and tps unplugged none of those 3 togethor or individually changes anything
    • 🏆 Skyline Supremacy Meets Mount Panorama Magic 🏆 Join SAU NSW as we take the long way to Bathurst, the home of GTR greatness. Saturday 30th August 2025 7:00AM Meeting Hanna Park North Richmond 7:30AM Departure Cruise Via Bells of Line Road 9:00AM Arrival to Stop 1: Golden Poplars Meadow Flat 9:45AM Arrival to Final Destination: Mount Panorama Motor Racing Circuit Meet Location: Hanna Park North Richmond Stop 1: Golden Poplars Meadow Flat Final Destination: Mount Panorama Motor Racing Circuit   *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • What does it look like with highway driving? And yes, I had a similar thought as Duncan. It looks quite similar in my Stagea and I have made myself accept it as normal. Might have to look into it some day   Highway gets as low as 10l/100km on my end so I'm not as worried about it being a mechanical issue. More likely just the tune on the haltech.
